Hi
Can I prevent the attachments I add using data domain from being seen?
Cybersecurity
DevOps Cloud
IT Operations Cloud
Hi
Hi Omer,
Normally with Data Domain segmentation it's done at the Record level. So all the attributes within the record would have the same data domain assignment. A potential way you could try to limit access to the Attachments is to use a Business Rule for Rendering forms. You could use the Hide Section rule and then look at maybe preventing certain group/user etc from being able to see the attachments. The only thing by doing that is that all attachments for that Record type would be hidden to that group/user depending on how you define the rule.
a simple example is something similar to this:
Then the user with that Id will no longer see Attachments in the Record type you place the rule in. So if its a specific group you dont want to see the attachments that would work. However, if its a specific attachment that you want to hide that type of rule wouldn't help.
Thank you for your answer. In addition, I would like to ask the following. Can it be prevented from seeing attachments added using Data Domain?
Hi Omer,
You could do something similar to this:
So with that I've assigned the request to a service Desk group called UserGroupB which my logged in current user does not have access to. They have a primary domain of UserGroupA. So within the Request Record the Data Domain is public but the current_user is the value that is hiding the Attachments for that request:
Whereas, if the same user looks at another request they will see the attachments section:
So, Yes you can hide attachments using DataDomains, it's just a matter of setting up the Business rule that best fits for your scenario.
Hi Dave
Thank you for your reply and suggestions. I will work on the subject.
