Schedule/Alert does not work ZAM 7.5 Webconsole
I tried to configure a "Achedule/Alert", but I get the following message:
Unable to complete .
Details:
I configured the mailserver as I did in ZAM 7, but I get the same error. It doesn't matter if I only want to store a report or mail it also.
In the logfile (ColSvrCoreEvent20091009) I find this message:
<EVENT AT="9-10-2009 9:58:43" SEVERITY="Warning">
Message Layer Error in Message Server Error Event Service Host
Implementation specific reason., Host = 00000000-0000-0000-0000-000000000000
Message Layer Error in Message Server Control Layer Service Remote Host
Unrecoverable error, connection aborted.
Message Layer Error in Message Server Control Layer Receive Message
Message Layer Error in Message Server Control Layer Receive Data
Message Layer Error in Socket Receive
Message Layer Error in WinSock Library recv
Socket: 1232, Error Code: 0
</EVENT>
I can't pinpoint the cause with this message.
Is there someone who has tackled this problem within ZAM 7.5 and windows 2003 server?
Parents
    Have you verify with your Exchange folks (or other if non Exchange) that the SMTP settings you entered are correct and that the Exchange server (or other) will permit the relaying of email messages?
    Also check your Task Server log, as alerts I believe are essentially scheduled tasks.
    Thanks, Bryant
    The problem also occurs when I choose only to save the report. Maybe there is a configuration issue or database field missing ...
    Thanks, Bryant
    Here is an examplescreen.
    Can you supply your Task Server logs? That might shed some light on this for us. I am going off memory here but they will be on the your task server under Program Files, Novell, Asset Management in a folder callled logs. It will be date time stamped and have the work TaskSvr in the title of the text file.
    Read what you find in there to see what error messages are coming back.
    Bryant
Reply
    Bryant
Children
    I don't know if this is helpful. I still get the same messages since I started this thread. I hope you can see what is going wrong.
    In the browser-window I see this:
    Details:
    .. when I try to make an alert. It doesn't make a difference if I wan't to mail the alert or store it on the server. I always get the same message in the browser-window.
    Thanks for your expertise,
    Paul
    Bryant
