Is there any way to change the order of the icons in the ZAPP window from alphabetized to customizable?
Cybersecurity
DevOps Cloud
IT Operations Cloud
If an answer to your question is correct, click on "Verify Answer" under the "More" button. The answer will now appear with a checkmark. Please be sure to always mark answers that resolve your issue as verified. Your fellow Community members will appreciate it! Learn more
Not really but there are some tricks...
#1 - You can place devices into folders so they are sorted that way.
#2 - You can edit the "Display Name" of a Bundle and insert one or more leading spaces so among the first alphabetically. Perhaps mix and match other characters such as a period, dash, exclamation point, etc.... so you could create "ordering groups". I did this many years ago as an admin using the ZENworks product that pre-dated ZCM.
If you found this post useful, give it a “Like” or click on "Verify Answer" under the "More" button
