Groupwise client calls for proxy authentification at every start
Groupwise 2023.4
Hello,
every time GW-client ist started it shows a dialog box for to authenticate to our internet proxy:
There is  no need for authentication. I can insert anything I want, after "Ok" I can use GW-client in normal way.
Our last version (GW 18.3) didn't show this (!)
Any idea where I can stop GW showing this annoying dialog at every start?
Holger
Tags:
Parents
  • Suggested Answer
    This is a HTTP/HTTPS request from GW so indeed as Andy mentioned Filr or Vibe but also the less used panel folder with an URL/website. If you want to see how/what it tries to do a wireshark LAN trace on the workstation will probably show the request causing this
    Ok, Filr is integrated, but it was in last version of our GW too.
    Filr asked once for authentification using a similar dialog box, but after doing this it never appeared again.
    The internet proxy didn't change and needs no authentification. The dialog box on every gw client start makes no sense.
  • 0   in reply to
    as i mentioned seeing what it is trying to access in a wireshark LAN trace might explain
  • 0   in reply to
    Wireshark, one of the swiss army knives in IT. In system environments that I am allowed to support, a split DNS is generally used and care is taken to ensure that the same suffix is used internally as it is externally. At this point, please no for or against. In IT today, we find ourselves in a situation that is best described by the term fog computing (CISCO term). It is something fundamental that the name service is structured in the same way internally and externally and that the corresponding service is presented to the client with the IP / DNS that corresponds to the location of the client via suitable procedures (DDI). If the client is inside the perimeter network, automatic proxy rules must be set accordingly. A DDI can also solve this problem. With DNSSEC and Pihole, DDI can offer a very good approach for DNS / DHCP IP security.
    In this case, the solution is to get the WinProxy to provide appropriate exceptions for Filr, Vibe or whatever via policies. Thank you for bringing a Swiss army knife of IT back to mind
    George
    “You can't teach a person anything, you can only help them to discover it within themselves.” Galileo Galilei
Reply
  • 0   in reply to
    George
Children
  • Suggested Answer
    0 in reply to
    I inserted the filr and vibe http addresses into the proxy settings as "no proxy for" on the server, where GW is installed. Now the dialog box doesn't appear anymore.
    No solution, because our internet proxy didn't change and it needs no authentification.
    But i'ts a workaround that works now.
    Thanks for your helpful suggestions!
    Holger
