Issues with "Offline" files - Nothing is cached and no errors! 25.1
On at least one client we have a big issue with Filr.
Trying to switch some folders shared with the user to be available offline via Windows File explorer.
Nothing happens. In the Filr Console it says it creates the folder and nothing else. When I click synchronize
it says in Console that it deletes the same folder.
Disconnect LAN/WiFi and nothing have been cached as expected as it does not sync.
Uninstalled a very old version of Filr and then Installed latest version 25.1.
Also deleted the Filr Storage folder in the user profile.
Windows 11 24H2.
Tried running the installer as admin and the software as admin and not.
Tried reinstalling Filr. Nothing helps.
