We are having On-prem UCMDB synced to SaaS UCMDB using CMDBtoSaaS adapter.
I was trying to set this attribute to true in the CMDB to SaaS adapter with the idea that if an attribute from the Query Element layout is changed it will be pushed in the next delta.
For example if i add LastDiscoveredTime in the element layour attrbutes even if the node LastModifiedTime is not changed I was expecing the DeltaSync to push the CI and update LastDiscoveredTime.
Any idea how this really suppose to work ? Does the Last Modified Time should be always changed for the Delta to detect changes, or Delta can be triggered based on a change on any attribute if push.changes.based.on.attributes" is set to true.
Here is the actual setting.
<adapter-setting name="push.changes.based.on.attributes">true</adapter-setting>
Here is the documentation
https://docs.microfocus.com/doc/UCMDB/24.4/IntegDeltaSync
Kind Regards
Emil Dutsov
