Hi All,
We are using version 24.1 of SMAX.
The requirement is to add roles to the assignment group through an offering, through an automated task. Is this possible?
Thank you in advance.
Cybersecurity
DevOps Cloud
IT Operations Cloud
Hi All,
You can try below business rule
Create relationship of type ${'PersonToGroup'} between ${entity.UserOptions.USERFIELD.Id} and ${entity.UserOptions.GROUPFIELD.Id}
This will add the user selected in one of the USER options field to the GROUP which is selected in another field of user options.
Thank you, Hemanth, for your reply.
Yes, this is possible, but the request is to add Roles to the group through an automated task in SMAX. Is this possible?
