We are using SMAX as SaaS and upgraded to latest version on 17th Nov. I cannot find below rendering rule set in Studio "Processes and Rules" or offering "Rules"
Is this removed or is it moved to any other section?
Cybersecurity
DevOps Cloud
IT Operations Cloud
Hello,
It has not been removed, just renamed to "Define suggested values for entity link based on filter". The reason for it is because a similar rule has been added for MANY2MANY relationships and needed to differentiate between the two.
Best regards,
Brindusa
Thanks for the reply. But how can we apply expression rule for ENUM with filter condition (Not list to list)?
No, for ENUMs you have to use "Define suggested values by a list to list mapping". This rule has not changed.
Even in previous releases, the rule you mentioned never covered ENUMs.
How can we do for ENUM with PhaseID?
PhaseID is not an ENUM, it is SMALL_TEXT
Yes, I agree, How can I write a rule to display only "TWO" ENUM values out of "FIVE" if the request is Resolve phase?
Please follow the instructions in this example from the documentation:
