We need to install IdM and following the below document:
https://docs.microfocus.com/doc/Service_Manager/9.80/InstallIdmService
We followed the exact steps but getting error on the browswer.
BR,
Haniyya Rehan
Cybersecurity
DevOps Cloud
IT Operations Cloud
BR,
Haniyya Rehan
Please verify entries in the seeded folder. Also if possible please post server.xml (mask sensitive data). Check DB accessibility using external tool for idm db.
I have attached the server.xml and seeded files.
Please let me know if I have done something wrong here?
Or what do the json parameters mean in the seeded files?
BR,
Haniyya Rehan
I suspect a small mis configuration or incompatibility of jar file. Faster way to resolve would be to open a support call with HPSM support. As they may be able to share a session with you in your timezone. I will need to test your config in my lab to see if something I missed so that will take time unfortunately.
You are failing at section where webapp is not able to load(in tomcat 10) and failing listener due to a mismatch(in 9.x). Documentation specifically mentions Tomcat 10.x because some of the files are compiled in Java 17(60x). SO the failure is around database connection and webapp early stages before it starts a listener.
Will update if find something else.
I tested your seeded files with 10.x , work without issues. So please double check your db setting may be there is issue there. As suggested earlier pls open a support case to let them review your other setup.
Also do make sure to follow this step as sometimes it also is referenced.
Hi Misaq,
Thank you so much for your effort, much appericiated.
Could you please let me know how to encrypt the the password in applicationContext.properties? Maybe, I am making a mistake here by simply giving a password:
I already have opened the case with opentext but haven't received any proper update as yet.
BR,
Haniyya Rehan
There are usually different way of encrypting based on conf file. I will check if I have my notes from old days. Although I dont see this as issue here as I am also using unencrypted password.
If its a test instance , can you try one more thing . Stop tomcat, wipe log files then restart it. Verify if the issue is still there , then post all the new logfiles(zip them) here.
Also post the screen capture of contents of webapps folder.
Hi Misaq,
We can do this again but would it be feasible for you to have a quick session with us?
Best regards,
Haniyya Rehan
Hi Misaq,
Attached are the log files and screenshot.
We restarted the tomcat after deleting logs and issue still persists.
BR,
Haniyya Rehan
Can connect using my email (fix the domain its for spam block)..
I will go thru and update if any interesting things found
