We need to install IdM and following the below document:
https://docs.microfocus.com/doc/Service_Manager/9.80/InstallIdmService
We followed the exact steps but getting error on the browswer.
BR,
Haniyya Rehan
Cybersecurity
DevOps Cloud
IT Operations Cloud
BR,
Haniyya Rehan
Can you attach a screenshot of error message and if any other logs.
Hi Misaq,
This is the message we get on browser
Hi Misaq,
catalina.2024-08-27.log is showing the errors below:
BR,
Haniyya Rehan
I had similar issue with tomcat 10.x while installing HPSM9.80 war. Are you running web-tier also on same server (tomcat 10)?
There should be more info in other tomcat logs.
Yes, we are running it on sme server.
Hi Misaq,
I tried tomcat 9.
But still issue persists, however, errors are somewhat different.
Also:
Failed to migrate the application specific seeded data
I suspect there may be issue with configuration. Can you post the jdk version you are using. Also 9.x shows more progress.
Please check if your idm database has tables showing up and in logs folder you should idm related logs(idm-xxx logs). They should carry more information.
I was using jdk-8u202-linux-x64.tar for 9.x
and for 10.x
There are no logs created in idm logs:
BR,
Haniyya Rehan
