The selected values from a multi-relational and multi-selection fields are saved in the database in the alphabetical order. Is there a solution to be saved in the entry order?
The version of SBM I'm using is 11.7.1. The order in which the selected values in the multi-relational field are stored is the alfabetical one, from SBM 11.4 (please see D24348). My client want to see the selected values in a multi-relational field in the order of entry. It is very important because this field contains the name of packages to be deployed and the order is crucial. Maybe an appscript or a javascript can be used to resolve this. Any idea will be appreciated.
