Integration between OBM and OPSB failed
Hi Experts,
I face this issue during integration between obm and opsb to enable AEC and metric collection when i run obm_configurator.jar as is shown the attached output
can anyone help me what is the caus of issue
E:\HPBSM\JRE\bin>java -jar E:\obm-configurator.jar --configuration-type AEC --endpoint-id stc_obm --suite-service-hostname bvd.stc.com.sa --obm-ca-cert-alias CA_62edcc02-346b-75e5-0db6-8e5d509b8803_2048 --admin-user admin -w "OBM Webserver CA Certificate"  -f
Please enter password for admin:
---- exporting web service certificate ...
---- web service certificate exported
---- checking provided admin credentials ...
---- OK
---- checking if already configured ...
---- found installed suite certificates:
----   - MF CDF RIC CA on cluster-87f45ba4aa
---- '--force' parameter set - proceeding with configuration ...
---- OK
---- exporting CA certificate ...
---- exporting certificate: 'CA_62edcc02-346b-75e5-0db6-8e5d509b8803_2048' ...
---- CA certificate exported
---- configuring end point ...
---- patching 'di.receiver.endpoint' in infrastructure settings ...
---- patching 'di.data.access.endpoint' in infrastructure settings ...
---- patching 'di.admin.endpoint' in infrastructure settings ...
---- patching 'di.idm.authentication.endpoint' in infrastructure settings ...
---- patching 'di.idm.tenant.id' in infrastructure OPTICDL settings ...
---- attempting to patch 'des.receiver.endpoint' in infrastructure settings ...
---- end point configured
---- establishing trust ...
---- installing suite certificates ...
---- installing C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_5857170118158134160\opsb_issue_ca.crt certificate ...
---- trust established
---- uploading forwarding content-pack ...
---- checking if content-pack ContentPack(name=COSO_Data_Lake_Event_Integration, version=9.06) is already deployed
---- content-pack already deployed
---- forwarding content-pack uploaded
---- configuring forwarding content-pack ...
---- checking if forwarding content-pack is already correctly configured
---- getting forwarding rule
---- getting connected server with id ce3a079c-ecc9-42f4-b750-23f18e9ae953
---- forwarding content-pack not configured
---- creating connected server
---- Integration failed: client error occurred - URI: localhost:443/.../connectedServer - check log file for details.. See log file 'E:\HPBSM\JRE\bin/obm-configurator-<date>-<time>.log' for
Tags:
    please post the details from the log or attach the log file mentioned
    2024-11-27T17:49:57,055+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --resource-dir not set - using
    2024-11-27T17:49:57,164+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.ResourcesUnpackerImpl:37 [main] C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519 empty. unpacking resources ...
    2024-11-27T17:49:57,195+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.ResourcesUnpackerImpl:44 [main] unpacking to C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519
    2024-11-27T17:49:57,539+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.Runner:34 [main] properties file found at C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519/conf.txt. loading
    2024-11-27T17:49:57,555+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:20 [main] * configuring AEC
    2024-11-27T17:49:57,555+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --admin-client-cert not set - using
    2024-11-27T17:49:57,555+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --admin-password not set - using
    2024-11-27T17:49:57,555+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --admin-client-password not set - using
    2024-11-27T17:49:57,555+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --zip-password not set - using
    2024-11-27T17:49:57,555+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --client-cert not set - using
    2024-11-27T17:49:57,555+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --client-key not set - using
    2024-11-27T17:49:57,570+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --suite-service-port not set - using 443
    2024-11-27T17:49:57,570+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --integration-password not set - using
    2024-11-27T17:49:57,586+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.SimpleSetting:32 [main] --uif-context-root not set - using /ui
    2024-11-27T17:50:05,492+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] exporting web service certificate ...
    2024-11-27T17:50:05,492+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:86 [main] running command: [E:\HPBSM\bin\opr-cert-mgmt.bat, -e, OBM Webserver CA Certificate, PEM, C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519\obm_web.crt] ...
    2024-11-27T17:50:10,133+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:120 [main] command exit value: 0
    2024-11-27T17:50:10,133+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:122 [main] command stdout: Successfully exported certificate to C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519\obm_web.crt
    Process exited with error code: 0
    2024-11-27T17:50:10,133+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:123 [main] command stderr:
    2024-11-27T17:50:10,148+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] web service certificate exported
    2024-11-27T17:50:10,148+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] checking provided admin credentials ...
    2024-11-27T17:50:10,148+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:58 [main] connecting using basic authentication with user admin
    2024-11-27T17:50:10,352+03 DEBUG com.microfocus.footils.http.AbstractHttpClientProvider:142 [main] Added certificate with alias=[OBM_WEB] to trust store.
    2024-11-27T17:50:10,352+03 DEBUG com.microfocus.footils.obm.rest.ObmHttpClientProvider:76 [main] Establishing connection.
    2024-11-27T17:50:10,352+03 DEBUG com.microfocus.footils.http.AbstractHttpClientProvider:184 [main] Added cookie store to builder.
    2024-11-27T17:50:11,461+03 DEBUG com.microfocus.footils.http.AbstractHttpClientProvider:195 [main] Adding SSL context.
    2024-11-27T17:50:11,508+03 DEBUG com.microfocus.footils.obm.rest.ObmHttpClientProvider:82 [main] Executing authentication GET at /opr-web/rest
    2024-11-27T17:50:11,523+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000001 preparing request execution
    2024-11-27T17:50:11,523+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000001 target auth state: UNCHALLENGED
    2024-11-27T17:50:11,523+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000001 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:11,523+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000001 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:11,523+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000001 acquiring endpoint (3 MINUTES)
    2024-11-27T17:50:11,523+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000001 endpoint lease request (3 MINUTES) [route: {s}->https://localhost:443][total available: 0; route allocated: 0 of 5; total allocated: 0 of 25]
    2024-11-27T17:50:11,539+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000001 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:11,539+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000001 acquired ep-0000000001
    2024-11-27T17:50:11,539+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000001 acquired endpoint ep-0000000001
    2024-11-27T17:50:11,539+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:130 [main] ex-0000000001 opening connection {s}->https://localhost:443
    2024-11-27T17:50:11,539+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:160 [main] ep-0000000001 connecting endpoint (10000 DAYS)
    2024-11-27T17:50:11,539+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:444 [main] ep-0000000001 connecting endpoint to https://localhost:443 (10000 DAYS)
    2024-11-27T17:50:11,539+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:138 [main] localhost resolving remote address
    2024-11-27T17:50:11,555+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:144 [main] localhost resolved to [localhost/127.0.0.1, localhost/0:0:0:0:0:0:0:1]
    2024-11-27T17:50:11,555+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:177 [main] localhost:443 connecting null->localhost/127.0.0.1:443 (10000 DAYS)
    2024-11-27T17:50:11,555+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:226 [main] Connecting socket to localhost/127.0.0.1:443 with timeout 10000 DAYS
    2024-11-27T17:50:11,570+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:299 [main] Enabled protocols: [TLSv1.3, TLSv1.2]
    2024-11-27T17:50:11,570+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:300 [main] Enabled cipher suites: [TLS_AES_256_GCM_SHA384, TLS_AES_128_GCM_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_EMPTY_RENEGOTIATION_INFO_SCSV]
    2024-11-27T17:50:11,570+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:301 [main] Starting handshake (null)
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:59 [main] Secure session established
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:60 [main]  negotiated protocol: TLSv1.3
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:61 [main]  negotiated cipher suite: TLS_AES_256_GCM_SHA384
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:71 [main]  peer principal: CN=obmgw2.stc.com.sa, O=OpenText, C=CA
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:80 [main]  peer alternative names: [localhost, scprwsmr34, obmgw2.stc.com.sa, smartmonitoring.stc.com.sa]
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:84 [main]  issuer principal: CN=OBM Certification Authority, O=OpenText, C=CA
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-0 set socket timeout to 3 MINUTES
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:185 [main] localhost:443 connected null->localhost/127.0.0.1:443 as http-outgoing-0
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:456 [main] ep-0000000001 connected http-outgoing-0
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ep-0000000001 endpoint connected
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000001 executing GET /opr-web/rest HTTP/1.1
    2024-11-27T17:50:11,711+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000001 Cookie spec selected: relaxed
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000001 start execution ex-0000000001
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000001 executing exchange ex-0000000001 over http-outgoing-0
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-0 >> GET /opr-web/rest HTTP/1.1
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-0 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-0 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-0 >> Host: localhost:443
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-0 >> Connection: keep-alive
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-0 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 >> "GET /opr-web/rest HTTP/1.1[\r][\n]"
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:11,727+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 >> "[\r][\n]"
    2024-11-27T17:50:11,789+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Date: Wed, 27 Nov 2024 14:50:11 GMT[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Upgrade: h2,h2c[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Connection: Upgrade, Keep-Alive[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Cache-Control: no-cache,no-transform[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Set-Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; Path=/; Secure; HttpOnly;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Set-Cookie: LWSSO_COOKIE_KEY=Zb0yy6LNnzmq43ScoE9apZwY6FKUPQSVAMjn2BE_mLd8k0jCeeCZ21IqPPHzywuJPfKw2JFowvjxwVVGCN9twzxBiVl3fj9Olm4jYz2jr3C78S6pnHnuK-6qZeKS2KvHU6vDlhP-ReaiAERj8uGtyPDJYkB5Da7nJybt84nC-KWeG7kOIgo86Nkh5kLdaxPD3V1OKACRbUxfaR71zQdUtg..; Path=/; Secure; HttpOnly;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "Content-Type: application/atomsvc+xml[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "1ff8[\r][\n]"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-0 << "<?xml version="1.0" encoding="UTF-8" standalone="yes"?><app:service xmlns:app="http://www.w3.org/2007/app" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns="http://www.hp.com/2009/software/opr/data_model" xmlns:atom="http://www.w3.org/2005/Atom" xmlns:xhtml="http://www.w3.org/1999/xhtml" xmlns:v="urn:x-auto-version:version" xmlns:os="http://a9.com/-/spec/opensearch/1.1/"><app:workspace><app:collection><app:accept>application/x-www-form-urlencoded</app:accept><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/atom+xml;type=entry</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.0/event_list</app:href><atom:title>Event Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/atom+xml;type=entry</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.0/event_list/{event}</app:href><atom:title>Event Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/annotation_list</app:href><atom:title>Event Annotation Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/annotation_list/{annotation}</app:href><atom:title>Event Annotation Service:</atom:title></app:collection><app:collection><app:accept>*/*</app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/auto_action</app:href><atom:title>Event Auto Action Service:</atom:title></app:collection><app:collection><app:accept>*/*</app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/user_action</app:href><atom:title>Event User Action Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/custom_attribute_list</app:href><atom:title>Event Custom Attribute Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/custom_attribute_list/{custom_attribute}</app:href><atom:title>Event Custom Attribute Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/symptom_list</app:href><atom:title>Event Symptom Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/symptom_list/{symptom}</app:href><atom:title>Event Symptom Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/history_line_list</app:href><atom:title>Event History Line Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.0/event_list/{event}/history_line_list/{history_line}</app:href><atom:title>Event History Line Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.0/event_change_list</app:href><atom:title>Event Change Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.0/event_change_list/{event_change}</app:href><atom:title>Event Change Service:</atom:title></app:collection><atom:title>OPR Event Services 9.0</atom:title><v:version>9.0</v:version></app:workspace><app:workspace><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/atom+xml;type=entry</app:accept><app:accept>application/json</app:accept><app:accept>application/xml;type=collection</app:accept><app:accept>text/xml;type=collection</app:accept><app:accept>application/atom+xml;type=feed</app:accept><app:accept>application/json;type=collection</app:accept><app:accept>application/x-www-form-urlencoded</app:accept><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/atom+xml;type=entry</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.10/event_list</app:href><atom:title>Event Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/atom+xml;type=entry</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}</app:href><atom:title>Event Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/annotation_list</app:href><atom:title>Event Annotation Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/annotation_list/{annotation}</app:href><atom:title>Event Annotation Service:</atom:title></app:collection><app:collection><app:accept>*/*</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/auto_action</app:href><atom:title>Event Auto Action Service:</atom:title></app:collection><app:collection><app:accept>*/*</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/user_action</app:href><atom:title>Event User Action Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/custom_attribute_list</app:href><atom:title>Event Custom Attribute Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/custom_attribute_list/{custom_attribute}</app:href><atom:title>Event Custom Attribute Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/atom+xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.10/e"
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-0 << HTTP/1.1 200 200
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Date: Wed, 27 Nov 2024 14:50:11 GMT
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Server: Apache
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Upgrade: h2,h2c
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Connection: Upgrade, Keep-Alive
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Cache-Control: no-cache,no-transform
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Set-Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; Path=/; Secure; HttpOnly;SameSite=none;Secure
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Set-Cookie: LWSSO_COOKIE_KEY=Zb0yy6LNnzmq43ScoE9apZwY6FKUPQSVAMjn2BE_mLd8k0jCeeCZ21IqPPHzywuJPfKw2JFowvjxwVVGCN9twzxBiVl3fj9Olm4jYz2jr3C78S6pnHnuK-6qZeKS2KvHU6vDlhP-ReaiAERj8uGtyPDJYkB5Da7nJybt84nC-KWeG7kOIgo86Nkh5kLdaxPD3V1OKACRbUxfaR71zQdUtg..; Path=/; Secure; HttpOnly;SameSite=none;Secure
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Keep-Alive: timeout=15
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Transfer-Encoding: chunked
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-0 << Content-Type: application/atomsvc+xml
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000001 Cookie accepted [JSESSIONID="E8B64E947D01E8EE061CC4B48DA78FD8", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000001 Cookie accepted [LWSSO_COOKIE_KEY="Zb0yy6LNnzmq43ScoE9apZwY6FKUPQSVAMjn2BE_mLd8k0jCeeCZ21IqPPHzywuJPfKw2JFowvjxwVVGCN9twzxBiVl3fj9Olm4j...", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000001 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:11,805+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000001 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-0 << "vent_list/{event}/symptom_list</app:href><atom:title>Event Symptom Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/symptom_list/{symptom}</app:href><atom:title>Event Symptom Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/history_line_list</app:href><atom:title>Event History Line Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/history_line_list/{history_line}</app:href><atom:title>Event History Line Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.10/event_change_list</app:href><atom:title>Event Change Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/9.10/event_change_list/{event_change}</app:href><atom:title>Event Change Service:</atom:title></app:collection><app:collection><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web"
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "[\r][\n]"
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "a2f[\r][\n]"
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "/rest/9.10/event_list/{event}/forwarding_info_list</app:href><atom:title>Event Forwarding Information Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/forwarding_info_list/{id}</app:href><atom:title>Event Forwarding Information Service:</atom:title></app:collection><app:collection><app:accept></app:accept><app:accept>application/xml</app:accept><app:accept>text/xml</app:accept><app:accept>application/json</app:accept><app:href>/opr-web/rest/9.10/event_list/{event}/forwarding_info_list/{id}</app:href><atom:title>Event Forwarding Information Service:</atom:title></app:collection><atom:title>OPR Event Services 9.10</atom:title><v:version>9.10</v:version></app:workspace><app:workspace><app:collection><app:accept></app:accept><app:href>/opr-web/rest/10.10/direct_execution</app:href><atom:title>Action Web Service POST request:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/10.10/direct_execution/{contextId}</app:href><atom:title>Action Web Service GET|DELETE:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/10.10/direct_execution/{contextId}/{resultId}</app:href><atom:title>Action Web Service GET details:</atom:title></app:collection><atom:title>OPR Action Web Services 10.10</atom:title><v:version>10.10</v:version></app:workspace><app:workspace><app:collection><app:accept></app:accept><app:href>/opr-web/rest/10.11/tool_execution/execution/{contextId}</app:href><atom:title>Tool Web Service POST|GET|DELETE:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/10.11/tool_execution/execution/{contextId}/{resultId}</app:href><atom:title>Tool Web Service details GET|DELETE:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/10.11/tool_execution/execution_preview/{contextId}</app:href><atom:title>Tool Web Service preview POST:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/10.11/tool_execution</app:href><atom:title>Tool Web Service query tools POST:</atom:title></app:collection><app:collection><app:accept></app:accept><app:href>/opr-web/rest/10.11/tool_execution/preparation</app:href><atom:title>Tool Web Service preparation POST:</atom:title></app:collection><atom:title>OPR Tool Web Services 10.11</atom:title><v:version>10.11</v:version></app:workspace></app:service>[\r][\n]"
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-0 << "0[\r][\n]"
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000001 releasing valid endpoint
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000001 releasing endpoint
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000001 connection http-outgoing-0 can be kept alive for 15 SECONDS
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000001 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:247 [main] Shutdown connection pool GRACEFUL
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:174 [main] http-outgoing-0 close connection GRACEFUL
    2024-11-27T17:50:11,820+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:250 [main] Connection pool shut down
    2024-11-27T17:50:11,820+03 DEBUG com.microfocus.footils.http.AbstractHttpClientProvider:184 [main] Added cookie store to builder.
    2024-11-27T17:50:11,820+03 DEBUG com.microfocus.footils.http.AbstractHttpClientProvider:195 [main] Adding SSL context.
    2024-11-27T17:50:11,836+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: GET /opr-web/admin/rest/connectedServer
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000002 preparing request execution
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000002 target auth state: UNCHALLENGED
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000002 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000002 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000002 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000002 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 0; route allocated: 0 of 5; total allocated: 0 of 25]
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000002 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000002 acquired ep-0000000002
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000002 acquired endpoint ep-0000000002
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:130 [main] ex-0000000002 opening connection {s}->https://localhost:443
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:160 [main] ep-0000000002 connecting endpoint (null)
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:444 [main] ep-0000000002 connecting endpoint to https://localhost:443 (3 MINUTES)
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:138 [main] localhost resolving remote address
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:144 [main] localhost resolved to [localhost/127.0.0.1, localhost/0:0:0:0:0:0:0:1]
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:177 [main] localhost:443 connecting null->localhost/127.0.0.1:443 (3 MINUTES)
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:226 [main] Connecting socket to localhost/127.0.0.1:443 with timeout 3 MINUTES
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:299 [main] Enabled protocols: [TLSv1.3, TLSv1.2]
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:300 [main] Enabled cipher suites: [TLS_AES_256_GCM_SHA384, TLS_AES_128_GCM_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_EMPTY_RENEGOTIATION_INFO_SCSV]
    2024-11-27T17:50:11,836+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:301 [main] Starting handshake (null)
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:59 [main] Secure session established
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:60 [main]  negotiated protocol: TLSv1.3
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:61 [main]  negotiated cipher suite: TLS_AES_256_GCM_SHA384
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:71 [main]  peer principal: CN=obmgw2.stc.com.sa, O=OpenText, C=CA
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:80 [main]  peer alternative names: [localhost, scprwsmr34, obmgw2.stc.com.sa, smartmonitoring.stc.com.sa]
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:84 [main]  issuer principal: CN=OBM Certification Authority, O=OpenText, C=CA
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 3 MINUTES
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:185 [main] localhost:443 connected null->localhost/127.0.0.1:443 as http-outgoing-1
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:456 [main] ep-0000000002 connected http-outgoing-1
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ep-0000000002 endpoint connected
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000002 executing GET /opr-web/admin/rest/connectedServer HTTP/1.1
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000002 Cookie spec selected: strict
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000002 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer]
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000002 Cookie [name: LWSSO_COOKIE_KEY; value: Zb0yy6LNnzmq43ScoE9apZwY6FKUPQSVAMjn2BE_mLd8k0jCeeCZ21IqPPHzywuJPfKw2JFowvjxwVVGCN9twzxBiVl3fj9Olm4jYz2jr3C78S6pnHnuK-6qZeKS2KvHU6vDlhP-ReaiAERj8uGtyPDJYkB5Da7nJybt84nC-KWeG7kOIgo86Nkh5kLdaxPD3V1OKACRbUxfaR71zQdUtg..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer]
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000002 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer]
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000002 start execution ex-0000000002
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000002 executing exchange ex-0000000002 over http-outgoing-1
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> GET /opr-web/admin/rest/connectedServer HTTP/1.1
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; LWSSO_COOKIE_KEY=Zb0yy6LNnzmq43ScoE9apZwY6FKUPQSVAMjn2BE_mLd8k0jCeeCZ21IqPPHzywuJPfKw2JFowvjxwVVGCN9twzxBiVl3fj9Olm4jYz2jr3C78S6pnHnuK-6qZeKS2KvHU6vDlhP-ReaiAERj8uGtyPDJYkB5Da7nJybt84nC-KWeG7kOIgo86Nkh5kLdaxPD3V1OKACRbUxfaR71zQdUtg..; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "GET /opr-web/admin/rest/connectedServer HTTP/1.1[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; LWSSO_COOKIE_KEY=Zb0yy6LNnzmq43ScoE9apZwY6FKUPQSVAMjn2BE_mLd8k0jCeeCZ21IqPPHzywuJPfKw2JFowvjxwVVGCN9twzxBiVl3fj9Olm4jYz2jr3C78S6pnHnuK-6qZeKS2KvHU6vDlhP-ReaiAERj8uGtyPDJYkB5Da7nJybt84nC-KWeG7kOIgo86Nkh5kLdaxPD3V1OKACRbUxfaR71zQdUtg..; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:11,852+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:11 GMT[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Upgrade: h2,h2c[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Upgrade, Keep-Alive[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-store, no-cache, must-revalidate[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: Thu Jan 01 03:00:00 AST 1970[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Link: </opr-web/rest>; rel="service"[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; Path=/; Secure; HttpOnly;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; Path=/; Secure;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "49f[\r][\n]"
    2024-11-27T17:50:11,914+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffffec]WMo[0xffffffe3]6[0x10][0xffffffbd][0x17][0xffffffe8][0x7f][0x10]|,"[[0xffffffdf][0xffffff94][0xc][0x14]mws)[0xffffffd0][0xffffffc5].[0xffffffea][0xffffffa0]=,[0x2]aD[0xffffff8e]l"[0xffffff92]([0xffffff90]T[0xffffffd2]`[0xffffff91][0xffffffff]^[0xffffffea]#[0xffffffb6]e[0xffffffcb][0xffffffc9][0xffffffba][0xffffffe9][0x6][0xffffffbb]E[0x3][0xfffffff8][0x10][0xfffffff1]q[0xffffff86]3[0xfffffff3]f[0x1e][0xfffffff9][0xffffffe9][0xfffffffb][0xffffffef],[0xffffffcb][0xffffff9a]QQUH5[0xffffffb2]T[0xffffffa1][0xffffffbc]E[0xffffff99][0x16]\[0xffffffe9][0xffffff99][0xffffffb5][0xffffffb4]>u[0xffffffeb]-[0xffffffe4]g[0xffffff85]E[0xffffffde]~[0xffffff9a]m[0xffffffb4][0xffffffae][0xffffffd5]r[0xffffffb1]P%H][0xffffff8a][0xffffff8a]k!y[0xffffffb5][0xffffff9e]+M[0xffffffe7]T[0xffffff94]s[0x5][0xffffffcb] [0xfffffff0][0x17][0xffffffa2][0xffffff96][0xfffffff6][0x1d]f[0xb]`%[0xffffffaf][0x16][0x12][0xffffff95]^l[0xffffffdd][0xffffffac]:/[0xffffffb3][0xffffff8b][0xffffffad][0xfffffff5][0xffffffc3][0x3][0xffffffb4][0xffffff8e]>[0xffffffee][0xffffffbc][0x7f][0xffffffa1][0x3], [0xfffffff7]"[0xc][0xffffff93][0xffffffc8]&[0xffffff81][0xffffff83]v[0xffffffe0][0xffffff85][0xffffff99][0x1d][0xffffffb3][0xffffff9c][0xffffffd8][0xffffffc4]c$J[0x18][0xffffff84]4[0xffffffc9]w[0xffffffa7][0xffffffec]N![0xffffffb1][0x0][0xffffffcd]E[0xffffffa5]6[0xffffffbc]V)[0xffffffaf]h[0xffffffd1]0d[0xffffffed][0xffffffb9][0xffffffb4]lp[0xffffff84][0xffffffe5][0xffffffdd][0xffffffe7][0xffffffd9][0xfffffff9]N[0xffffffcc][0xffffffd1][0xffffff94]q[0xffffffd1][0xffffffee]vF[0xb][0x15][0xffffff94][0xffffffd8][0xffffffd9]|[0xfffffff3][0xffffffc7][0xffffffe5]xK[0x1][0x19][0x16][0xffffffd3]K@5[0xffffffbf][0xffffffc5][0xffffffc9][0x13][0xe][0xffffffd5][0xffffffd6][0xfffffff7]uo6[0xffffffbb]e[0xffffffe3][0xffffffbd]&a9_7[0xffffffb2][0xb]9[0xffffffe5][0x1a][0xffffffcb][0x11]+[0xfffffff6]K[0xffffffb3][0xffffffb3][0xffffffd2][0xffffffc8]j[0xfffffff9][0xffffff97][0xffffffbd][0xffffffa9][0xffffff97][0xffffff9e][0xffffffe3]$K%r}[0x7][0x12][0xffffff97][0xc]4[0xffffffa4][0xffffffa5]`X,[[0xffffffe8]r[0xffffffc2][0xfffffff6][0xffffffc5][0xffffffa1][0xffffffe1][0xffffffbd]L[0xffffffcc][0xffffffdc][0xffffffb9]w[0x4][0x18]R[0xffffffcc][0xffffffb2]<[0x1]'[0xfffffff0][0xffffff93]8H[0xffffff82][0x0][0xffffffe2][0xffffffd8]g@c[0xffffff96][0xffffff99]\[0xffffffa3][0xffffffe7][0xffffffba][0xffffffc9][0xffffffd1][0xffffffbe]][0xffffffc4][0xffffff8d][0xffffffe2][0x15]*[0xffffff95][0xffffffde]B[0xffffffd1]`[0xffffffca]@m2[0x1][0xffffffd2][0xfffffff0][0xfffffff0]^[0xffffffb5]'[0xffffffda][0xffffffdb][0xfffffff7]0[0xffffffca][0xc][0xffffffab]T[0xffffffba]-[0xffffff87][0xffffffc9][0xffffffdb][0x1e][0xfffffffb][0xffffff8e]R[0xffffffd8]r[0xffffffae][0xffffff8d][0xffffffb1][0x16][0xffffffb2][0xffffffeb]*[0xffffffc3][0xffffffce][0x11][0xffffffa4]QhxO[0x1b][0xffffff89]i[0xffffffcb][0xffffffed][0xffffffc9]RI!t[0xffffffda][0xffffffc8]"[0xffffffad]Ao:[0xffffffa7][0xb][0xffffffe3][0xffffffd5][0xffffff96]H[0xffffff91]wT[0xffffffae][0xfffffff9]B5Y[0xffffffc9][0xfffffff5][0xffffffc2]qIN[0xfffffff3][0xffffffdc][\r][0x2]$[0x1][0xffffffb8]Q[0xffffff82]9[0xffffff81][0xc][0xffffffc0]P$A/[0xffffffa2]?iX[0xffffffab][0x1f][0xffffffdf][0xffffffbf]ywD[0x15][0xffffff8a]R[0xfffffff3][0xffffff9c]S[0xffffffd0][0xffffff98][0xe][0xffffffa9][0xffffffcd][0xffffffa3][0xffffffd0][0xb][0xffffffb2]<[0xffffffb3][0xffffff9d][0xffffff90][0xffffffba]v[0xffffff90]{[0xffffff8e][0x1d]CBm[0xffffff97][0xffffffd2][0x0][0x12]c6&[0xfffffffe][0x1][0xffffffdf]Z[0x1b][0xffffff86]t[0xffffffa9][0xffffffe9][0xffffffca]5[0xffffffef]kG[0x1b][0xffffffa5][0xffffffc5][0xffffffb8][0xffffffbe][0xffffffdb][0xc][0xffffffaa][0xffffffbe][0xffffffd9][0xf][0xffffff93]h]?[0xffffff82][0x1f].[0xffffffbe][0xfffffffc]$[0xffffffa0][0xffffffe8][0xffffff83]CL\Hib[0xffffff9a]4[0xf][0xffffffec][0xffffff8c][0xffffff84][0xffffff8e][0xffffffed][0xfffffff9][0xffffffb9][0x1b]c[0x2][0xffffff98][0xffffff84][0xfffffffe][0xffffff8b]'[0xffffffc1][0xfffffff9]N[0xffffff9e][0xffffff9f][0x4]o[0xffffffdf][0xffffffaf][0xffffffde][0xffffffa7][0xffffff97]mk[0xfffffffd][0x6]7[0xffffff98][0xfffffffe]RpP[0xffffffa7]FC[0xffffff8b][0xffffffb5]Z[0xffffffac][0xffffffd5]b[0xffffffad][0x9][0xffffffec]nV[0xffffffe4]P[0xffffffa8][0xffffffa7][0xffffff87][0x5]Ll?][0xfffffffa][0xffffffd7],f[0xffffffe2]`[0x18]ff[0xffffffce]"[0xffffffd2][0xffffffcc][0xffffffe4][0xffffffd9][0x10]7&[0xffffff98][0xffffffd8][0xffffffb1][0xffffffcb][0xffffffe2][0x8]|[0xffffffc8]\[0x8]^\[0xffffffcc][0xfffffff3][0xffffff9d][0xffffffec][0x15][0xffffffd3][0xffffff9b].[0xffffffe6][0xffffffca]LAEE[0xffffff8d][0xffffffe9][0xffffffaf][0xffffff95][0xffffffc6]u?[0x1a]OUs[0xb][0xffffffb6]N[0xffffff82][0xffffffcf])[0xffffffa7]2[0xffffffe6][0xffffffd2][0xffffffce][0xffffffde]7)[0x1]Y[0xffffffec][0xffffffba][0xffffff94][0x4]!8[0xffffffb1][0x1b][0xfffffff8][0xe]&A[0x1c]:[0xffffff89]O[0xffffffe2][0xffffff8c][0x10]F[0xffffff80][0xffffff9d][0xffffff96][0x0][0xffffffb5]M[0xfffffffa]Y3_q[0xffffffe5][0xffffffed]qsn[0xffffff8c][0xffffffe8][0x7f]2[0xfffffff9][0xffffffe5][0xffffffd6]b[0xffffffc7][0xffffffe8][0xffffffb1][0xffffff89][0x1a][0xffffff94][0xffffffba][0x13][0xffffffb2][0xf][0xfffffff1][0xffffff87][0xffffffbd][0xffffffbf][0xffffffd9][0xffffffd9][0x2][0xfffffff2][0xffffffd9]c[0x19]sh[\n]"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xffffff9d]J[0xffffffd1]h[0xffffffd3]~)[0x13]%[0xc][0xfffffff0][0xffffffcb]~[0xffffffe9][0xffffffb2][0xffffffff]2[0xffffff96]'T[0xfffffff7][0x15]M5/[0xffffff8d]r[0x18]:J[0xffffffa3][0xffffffa7][0xffffffed][0x1e]2B[0xffffff89][0xffffff92][0xffffffa7][0xffffffcf][0xffffff85][0xffffffdc]b>3[0xffffffec]C[0x5][0xffffff99],[0xffffff89]u}[0xffffffd4][0x12][0xffffffa6] G[0x17][0xffffffdc]ay[0xffffffe8][0xffffff8a][0x1e]u|[0xb][0x1d]Pg[0xffffffb3][0xffffffdd][0xc][0xffffffad][0xffffff9e][0xfffffff1]c[0xfffffffb][0x17][0x13][0xffffffa6][0xffffffc7]|w[0xffffffa7]0[[0xffffffc7][0x3][0xffffffc3]R[0x13][0xfffffff8][0x14]Ni#[0xffffffe4][0xffffffbd][0xffffff8a][0x3]/[0xfffffff0][0xffffffa8][0x7]Z[0xffffff8c][0xffffffc9][0xffffff9e][0xffffff82][0xfffffff5][0xffffffa0]%[0xffffff8f]s[0xffffffd4][0xffffffea][0x7][0xffffffa9][0xfffffff5]qr ][\YfH[0xffffffdf][0x18] (k [0xffffff8c][0xffffffd5][0xffffff87]fA[0xffffffc5],[\n]"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "U%[0xffffffb4][0xffffff95][0xffffffa1]Y[0xffffffec]f[0xffffff90]9[0x7][0xffffff9b][[0x1f][\n]"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x4][0xffffff85][0xffffffdd]V[0x3][0x13]zc[0xffffffe0][0xffffffad][0xffffff87]U7[0xffffffc5][0x1e][0xfffffff7][0x1f]Y[0xffffffcc]0[0x17]r[0xffffffcf][0xffffff94]a[0xffffffe5][0xffffffe3][0xffffffd2][0xffffff89][0x3][0xffffffce]g[0xffffffe3]@[0x1f]v[0xffffff97][0xffffff89][0xfffffff6][0xffffffbf][0xffffffd7][0xffffffd4][0xffffffa2],[0x4][0xc][0x1d]?[0xffffffb6][0x19][0xffffff9a][0xffffffab]S[0xffffffe0][0xffffffc5][0xffffffd4][0x6]$[0xffffffc4]6[0xffffffbf][0xffffff84][0xffffff90][0xffffff90]A[0xffffffec]G/[0xffffffd6][0xffffffa2][0xfffffff3][0xffffff9d][0xffffffec][0xffffffb1][0xffffff8c][0xffffff9c][0xffffffd4][0xffffffa2]>[0xffffffb1]W[0xffffffa2][0x16][0xffffff85]X[0xffffffdf]?[0xffffffa1]CO[0x1][0xffffffcf]x~|[0xffffffeb][0x12][0xffffffe4][0xffffff86][0xe][0xffffffc9]C?[0xffffff8c][0xffffff93](`[0xffffffb9][0xffffffb9]p[0xffffff9b][0xb][0x1d][0xffffff86][0xffffff9e][0xffffff9b][0xffffffbb][0xffffff80]xpM[0xffffffb6][0xfffffffe][\r][0x9][0xffffffa2][0xffffffb5][0xffffffbc]S[0xffffffa5][0xfffffff4][0xffffff9d][0xffffff81][0xffffff98][0xffffffb2][0xfffffffe][0xffffff9a][0x15][0xffffff88]I^[0x14]L[0xffffffdc]Uie[0xfffffff2][0xffffffdf]s[0xffffffe7][0xffffffed][0x7][0xfffffff9][0xffffffe7][0xffffffea][0xffffffdd][0xffffffef]'#[0xfffffff8][0xf][0xffffffaa]V;[0xffffff8b]E[0xffffffcb][0xfffffffb]Q-[0xffffff9f][0xffffffcd][0xffffffc4][0xffffff91][0xffffffd8]M[0x15][0x7f][0xffffffda][0xffffffce][0xffffffff][0x12][0xffffffd8]6KC)"{^[0x5][0xffffffbf][0x1e][0xffffffed][0xffffffa0][0xffffffae]G[0xffffffc2][0x18][0xffffff89]M]f[0xffffffde][0xffffffde][0xffffff89]c^[0x17][0xffffffe6]*k[0xffffffe7]n[0xffffffe4]D[0xffffff94]D1#[0xffffffde][0xffffff8b][0xffffffb5][0xffffffe3]|'[0xffffffcf]?J[0xffffffaf]L[0x1b]f[0x5]^qz[0xffffff83]z[0xffffffd5][0xffffff8f][0xffffffb4][0x13][0xffffffea]1@[0xffffffad][0x1e]kM[0xffffff81]_[0xffffffe1]Q:[0xffffffd4][0xffffffd8]T[0xfffffff7][0xffffffe1]o[0x0][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:11 GMT
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Upgrade: h2,h2c
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Upgrade, Keep-Alive
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-store, no-cache, must-revalidate
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: Thu Jan 01 03:00:00 AST 1970
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Link: </opr-web/rest>; rel="service"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; Path=/; Secure; HttpOnly;SameSite=none;Secure
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; Path=/; Secure;SameSite=none;Secure
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000002 Cookie accepted [LWSSO_COOKIE_KEY="oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-ly...", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000002 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000002 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0] [0xffffffc9][0xffffffb9]C[0x13][0x15][0x0][0x0][\r][\n]"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000002 releasing valid endpoint
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000002 releasing endpoint
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000002 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:11,930+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000002 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:11,930+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] OK
    2024-11-27T17:50:11,930+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] checking if already configured ...
    2024-11-27T17:50:11,930+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:86 [main] running command: [E:\Program Files\HP\HP BTO Software\\bin\win64\ovcert.exe, -list, -ovrg, server] ...
    2024-11-27T17:50:12,305+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:120 [main] command exit value: 0
    2024-11-27T17:50:12,320+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.CertificateHandler:23 [main] found installed suite certificates:
    2024-11-27T17:50:12,320+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.CertificateHandler:23 [main]   - MF CDF RIC CA on cluster-87f45ba4aa
    2024-11-27T17:50:12,320+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.ConfigChecker:23 [main] '--force' parameter set - proceeding with configuration ...
    2024-11-27T17:50:12,320+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] OK
    2024-11-27T17:50:12,320+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] exporting CA certificate ...
    2024-11-27T17:50:12,320+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.CACertificateExporter:23 [main] exporting certificate: 'CA_62edcc02-346b-75e5-0db6-8e5d509b8803_2048' ...
    2024-11-27T17:50:12,320+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:86 [main] running command: [E:\Program Files\HP\HP BTO Software\\bin\win64\ovcert.exe, -exporttrusted, -file, C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519\client_stc_obm_ca.crt, -alias, CA_62edcc02-346b-75e5-0db6-8e5d509b8803_2048] ...
    2024-11-27T17:50:12,711+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:120 [main] command exit value: 0
    2024-11-27T17:50:12,711+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:122 [main] command stdout: INFO:    Trusted certificate has been successfully exported to file 'C:\Users\
             client_stc_obm_ca.crt'.
    2024-11-27T17:50:12,727+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:123 [main] command stderr:
    2024-11-27T17:50:12,727+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] CA certificate exported
    2024-11-27T17:50:12,727+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] configuring end point ...
    2024-11-27T17:50:12,742+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.EndPointConfigurator:23 [main] patching 'di.receiver.endpoint' in infrastructure settings ...
    2024-11-27T17:50:12,742+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: PATCH /topaz/api/urest/v1/settingContexts/di/di.receiver.endpoint
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000003 preparing request execution
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000003 target auth state: UNCHALLENGED
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000003 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000003 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000003 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000003 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000003 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000003 acquired ep-0000000003
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000003 acquired endpoint ep-0000000003
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000003 executing PATCH /topaz/api/urest/v1/settingContexts/di/di.receiver.endpoint HTTP/1.1
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000003 Cookie spec selected: strict
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000003 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.receiver.endpoint]
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000003 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.receiver.endpoint]
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000003 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.receiver.endpoint]
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000003 start execution ex-0000000003
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000003 executing exchange ex-0000000003 over http-outgoing-1
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> PATCH /topaz/api/urest/v1/settingContexts/di/di.receiver.endpoint HTTP/1.1
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Type: application/json
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Length: 132
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:12,742+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "PATCH /topaz/api/urest/v1/settingContexts/di/di.receiver.endpoint HTTP/1.1[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Type: application/json[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Length: 132[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "{[\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "@type":"setting",[\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "context":"di",[\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "name":"di.receiver.endpoint",[\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "value":"https://bvd.stc.com.sa:30001/itomdi/receiver"[\n]"
    2024-11-27T17:50:12,758+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-1 >> "}"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:12 GMT[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-cache,no-transform[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: 0[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; Path=/; Secure; HttpOnly;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "154[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffff84]RKK[0x3]1[0x10][0xffffffbe][0x17][0xfffffffa][0x1f][0xffffffc2][0xffffff9e]5[0xffffffe9]VQ[0xffffffe9][0xffffffa9][0xffffffc5][0x16]Y[0xffffffb0][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xffffffb5][0xffffffed]}[0xffffff9a][0xffffff9d][0xffffffb6][0xffffff81][0xffffffdd]M[0xffffffc8][0xffffffcc].V[0xfffffff1][0xffffffbf][0xffffffbb][0xffffff8f]tQ[0x14][0xffffffbd][\r][0xffffffdf]|[0xffffff8f]If[0xffffffde][0xffffff87][0x3]![0xffffffa2])[0xffffff9f][0x1c]Fb""BfS[0x1c][0xffffffa2][0xffffff8b][0x16][0xffffffd7][0xffffffb6]`|[0xffffffe5][0xffffffb6][0xffffff93][0xffffff9a][0x0][0x12]j6[0xffffffb6][0x8][0xfffffff4][0xffffffb6][0xffffff96][0xffffffa9][0xffffff91][0xffffffd6][0xffffffd1].0[\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xffffffc8]1h[0xffffffa4]G[0xffffff8d][0xffffffa6]B/[0xffffffb1]H[0xffffff9d]5[0x5][0x7]N[0x6];[0xffffffcc]Z[0xffffffd2][0x1c][0x18][0xffffffc4]*[0xffffffd0][0xffffffc4][0xffffffe2];-E[0xffffffd2][0xffffffde][0xffffffb8]>[0xfffffff0]7G[0xffffffd9][0xffffff90]~[0xfffffff2][0x1f][0xfffffffb][0xffffff84][\r][0xffffffa1][0xffffffe0][0xffffffa3]![0xffffffe1][0xffffffc0][0xffffffd7][0xffffffa3]q[0x1d][0xffffffc3]VP[0xffffffad][0x17]i[0x13][0xffffffbe][0xfffffff7]6[0x17][0xffffffd0][0xffffffd5]dK[0xffffffaf]QP[0xffffffa9][0xffffff8f][0x2]H<;[0xfffffff4][0xffffffd0][0xffffffb8][0xffffff91][0xffffff98][0x1d][0xffffffb0][0xffffffe0]F[0xffffffb8]E[0xffffffcf]F[0xffffff83][0x14]![0xffffffb3][0xffffff82][0xffffffac][0xffffffec][0xffffffde]{dv4QjW[0xffffffa5][0xffffff92]XKmsI0[0xffffffb9][0x1a][0xffffff8d]F[0xffffffb1]2l[0xfffffff3][0xffffffd4][0xffffffa8][0xfffffff3][0xfffffff8][0xfffffffd][0xffffffc0]{(3[0xffffffde][0xfffffff6][0x1e]g[0xffffffdc][0xffffff90][0xffffffcb][0xffffffe0][0xffffff94][0x14][0x1b][0xffffffd3][0xffffffc0][0xffffffec]K[0xfffffffc][0xffffff92][0xffffffb6]>[0xffffffef][0xffffffeb]e[0xffffffbd]J[0xffffff9e][0x1e][0xffffff82][0xffffffc6][0xffffffe3][0xffffffde]#[0x1d]W[0xffffffc0]]3Y.[0x17][0xfffffff3]d[0xffffffb6]^[0xffffff84][0xffffffbe]I[0xffffffc3][0x1f][0xffffffaa]?[0x16]3-}[0xffffff9b][0x18])[0xffffffb6][0xe][0xffffffde][0x14]8[0xffffffa3][0xffffffca][0xffffffda][0xffffff96]U[0x15][0xffffffab]p[0x1e][0xfffffff7][0xffffffdd]][0xffffff90][0xfffffffa][0xffffffc7][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xffffffd7]ph[0xffffffbd].[0xffffffe3][0xffffff9b][0xffffffd1]8[0xffffffbe][0xffffff8b]o[0xffffffaf][0xffffffc7][0xffffffd1]p[0xfffffff0]1[0x1c]|[0x2][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:12 GMT
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-cache,no-transform
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: 0
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; Path=/; Secure; HttpOnly;SameSite=none;Secure
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000003 Cookie accepted [JSESSIONID="E8B64E947D01E8EE061CC4B48DA78FD8", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000003 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000003 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0][0xffffffda]T[0xffffffd7]ox[0x2][0x0][0x0][\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000003 releasing valid endpoint
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000003 releasing endpoint
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000003 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000003 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:12,867+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.EndPointConfigurator:23 [main] patching 'di.data.access.endpoint' in infrastructure settings ...
    2024-11-27T17:50:12,867+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: PATCH /topaz/api/urest/v1/settingContexts/di/di.data.access.endpoint
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000004 preparing request execution
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000004 target auth state: UNCHALLENGED
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000004 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000004 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000004 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000004 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000004 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000004 acquired ep-0000000004
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000004 acquired endpoint ep-0000000004
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000004 executing PATCH /topaz/api/urest/v1/settingContexts/di/di.data.access.endpoint HTTP/1.1
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000004 Cookie spec selected: strict
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000004 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.data.access.endpoint]
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000004 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.data.access.endpoint]
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000004 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.data.access.endpoint]
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000004 start execution ex-0000000004
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000004 executing exchange ex-0000000004 over http-outgoing-1
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> PATCH /topaz/api/urest/v1/settingContexts/di/di.data.access.endpoint HTTP/1.1
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Type: application/json
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Length: 154
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "PATCH /topaz/api/urest/v1/settingContexts/di/di.data.access.endpoint HTTP/1.1[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Type: application/json[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Length: 154[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "{[\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "@type":"setting",[\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "context":"di",[\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "name":"di.data.access.endpoint",[\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "value":"https://bvd.stc.com.sa:30003/urest/v1/itom-data-ingestion-store"[\n]"
    2024-11-27T17:50:12,867+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-1 >> "}"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:12 GMT[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-cache,no-transform[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: 0[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "14a[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffff84][0xffffff92][0xffffffd1]O[0xffffffc2]0[0x10][0xffffffc6][0xffffffdf]I[0xfffffff8][0x1f][0xffffff9a]=[0xffffffbb]v[0x4]0[0xffffffca][0x13]D[0xffffff88]Y"> [0xfffffff2]~t[0x7]4[0xffffffd9][0xffffffd6][0xffffffa6]w#[0xffffffa2][0xfffffff1][0x7f]w[0x1b]ej[0xffffff8c][0xfffffffa][0xffffffd6]|[0xfffffff7][0xffffffbb][0xffffffef][0xffffffbb]k[0xfffffffb][0xffffffd6][0xffffffef][0x9][0x11]M[0xfffffff9][0xffffffe4]0[0x12][0x13][0x11][0x11]2[0xffffff9b]r[0x1f]][0xffffffb5][0xffffffba][0xffffffb6]%[0xffffffe3][0xb][0xffffffb7][0xffffff95][0xffffffcc][0x4][0xffffff91]P[0xffffffb3][0xffffffb1]e[0xffffffc0][0xffffffdb][0xffffffb3][0xffffffcc][0xffffff8c][0xffffffb4][0xffffff8e][0xffffffb6][0xffffff81]([0xffffffa1][0xffffffc0][0xffffffd0]#3`[0xffffff90][0xffffffa0]5[0x12]I,3gM[0xffffffc9][0x1][0xffffffcb]a[0xffffff8b]y[0xffffffcb][0xffffffcd]kH[0xffffffcc]ZH,[0xffffffbe]C[0x19][0xffffff92][0xfffffff6][0xffffffc6]u[0xffffff89][0xffffffbf]X[0xffffffca][0xffffff86][0xfffffffb][0xffffffd9][0xfffffff2][0xffffffd0]E<[0x13][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << ">[0x18][0x12][0xe]|=[0x1e][0xffffffa3][0x17]l[0xffffffc5][0x1e]Y4vb[0xffffffe7]m!6[0xffffffe8][0xffffffd9]h[0xffffff90][0xffffffc1][0xffffffe7][0x8]yu[0xffffffde][0xffffffe3][0xffffffc0][0xffffffec]h[0xffffffa2][0xffffffd4][0xfffffff6][0xffffff98]Ib-[0xffffffb5]-$[0xffffffc1]d[0xffffff98]$[0xffffffc9]PU[0x1e][0xffffff89][0xffffffd5]q[0xffffffa0][0xc][0xffffffdb]"n[0xffffffdc][0xffffffe2][0xfffffffa][0x6]k[0xffffffad][0xffffffce][0xffffff8f][0xffffff89][0xffffffad][0xffffffc7]n[0xffffffae][0x1d]T9o:[0xffffffdb][0xffffff8b]n[0xffffffc8][0xffffffe5]pJ[0xffffffcb]g[0xffffffd3][0xffffffc8][0xffffffec]+[0xfffffffc]2[0xffffffc0][0xfffffffa][0xfffffff2]4O[0xffffffeb]U[0xfffffffa]x[0x1f]z<[0xffffffee][0xffffffea][0xffffffd8][0xffffffc3][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xfffffff8]\L[0xffffff97][0xffffffcb][0xffffffc5]<[0xffffff9d][0xffffffad][0x17][0xffffffa1]n[0xffffffb2]p[[0xffffffea][0xffffffef]7[0xffffff98]V[0xffffffbe][\r][0xffffff8d][0x14][[0x7][0xffffffaf][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xffffff9c][0xfffffff9]\(|[0xffffff86][0xffffffbb][0xfffffff3]/ [0xfffffff5][0xffffffbf][0x1b][0xffffffae]a[0xffffffdf][0xffffffda][0xffffffc5][0xffffff83]qr3[0x1a][\r][0xffffffc7][0xffffffd7][0xffffffb7]Q[0xffffffbf][0xfffffff7][0xffffffde][0xffffffef]}[0x0][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:12 GMT
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-cache,no-transform
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: 0
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000004 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000004 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0].Y[0xffffffab][0x8]i[0x2][0x0][0x0][\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000004 releasing valid endpoint
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000004 releasing endpoint
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000004 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000004 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:12,937+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.EndPointConfigurator:23 [main] patching 'di.admin.endpoint' in infrastructure settings ...
    2024-11-27T17:50:12,937+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: PATCH /topaz/api/urest/v1/settingContexts/di/di.admin.endpoint
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000005 preparing request execution
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000005 target auth state: UNCHALLENGED
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000005 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000005 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000005 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000005 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000005 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000005 acquired ep-0000000005
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000005 acquired endpoint ep-0000000005
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000005 executing PATCH /topaz/api/urest/v1/settingContexts/di/di.admin.endpoint HTTP/1.1
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000005 Cookie spec selected: strict
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000005 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.admin.endpoint]
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000005 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.admin.endpoint]
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000005 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.admin.endpoint]
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000005 start execution ex-0000000005
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000005 executing exchange ex-0000000005 over http-outgoing-1
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> PATCH /topaz/api/urest/v1/settingContexts/di/di.admin.endpoint HTTP/1.1
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Type: application/json
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:12,937+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Length: 157
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "PATCH /topaz/api/urest/v1/settingContexts/di/di.admin.endpoint HTTP/1.1[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Type: application/json[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Length: 157[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "{[\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "@type":"setting",[\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "context":"di",[\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "name":"di.admin.endpoint",[\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "value":"https://bvd.stc.com.sa:30004/urest/v1/itom-data-ingestion-administration"[\n]"
    2024-11-27T17:50:12,952+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-1 >> "}"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:12 GMT[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-cache,no-transform[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: 0[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "161[\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3]|R[0xffffffc1]N[0x2]1[0x10][0xffffffbd][0xffffff93][0xfffffff0][0xf][0xffffffcd][0xffffff9e][0xffffffa1]]#$[0xffffffca][0x9][0x2][0xffffffc4]l[0x4]5[0xffffffb8]p[0x1f][0xffffffb6][0x3]4.m[0xffffffd3][0xffffffce][0x12][0xffffffd1][0xfffffff8][0xffffffef][0xffffff96][0xffffffa5][0xffffffa0][0xffffff84][0xffffffe8][0xffffffad]y[0xfffffff3][0xffffffe6][0xffffffbd]y3[0xfffffffd]l6[0x18]K[0xfffffffa][0xffffffb4][0xffffffb7][0xffffff98][0xffffffb0][0x1e]K<[0x12])[0xffffffbd]NZ5^[0x18]M[0xfffffff8]NuE[0xffffffaa][0x8]z,H[0x19][0x1d][0xffffffe9][0xfffffff5][0xffffff9b]K[0xffffffc5][0xffffff8d][0xfffffff5][0xffffffcb][0xffffffc8][0xffffffd0][0xffffffb0][0xffffffc5][0xffffffd8][0xffffffc3]An[0xffffff95][0xffffffe6][0xffffffa8][0xffffffa5]5JS$[0xffffff94][0xffffffb0][0xffffffc4][0xffffffb2]f[0xc][0xe]e[0xffffffe5][0xffffffc9][0xffffffc1]A[0xffffff87][0xffffff8d]/y[0x12]}[0xffffffe1][0xffffff94]=[0xffffffdb]][0xffffffe9][0xfffffff1][0x3][0xffffffe3][0xffffff9a]<9[0xffffffeb][0xffffffcf]=2[0xffffffda]([0xffffffcf],[0xffffffb8]0[0x15][0xffffffa1]cdX[0xffffffc8][0xffffffb5]R[0xffffffeb][0xffffffca]!{~[0xffffffc9][0xffffffb3]![0x1b]M[0x2][0xffffffb4][0xffffffb5]F[0xffffffa3]&[0xffffffcf]|Ul[0x18]x[0xfffffff6][0x8][0xffffffab]7h[0xffffffb1][0x5]:R[0x5][0xffffffb0][0xffffffd2][0xffffff80]D[0xffffffc7][0xffffffa3][0xffffffdb][0xe][0xffffffca][0xffffffea][0x18]rCd}O[0xffffff88][0xffffffe5]NrO[0x5][0xf]J[0xffffffdc]C[0xffffffef]6M[0xffffffd3][0xffffff8e][0x8][0x1e][0xffffff9e][0xffffffc4][0xffffffee]F(2[0xffffffdb][0xffffffb6][0x4][0xffffff82]vXo[0xffffffc0][0xffffffc2][0xffffff94]m[0xffffffb8][0x8][0x7f][0xffffff8e][0xffffffb1][0xffffff82][0xffffffaa][0xffffffa4][0xffffffc5]Y[0xffffffff][0xffffff84]+oK[0xffffffd8]gz[0xffffffae][0xe]0[0xffffffb9][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x7f]M[0xffffff92][0xffffff9f][0xe][0xfffffff8][0xffffff9a][0xffffffcf][0xffffffb2][0xffffffa7][0xffffff87][0xffffffd8][0xffffffe3]p[0x15][0xfffffffc]73[0xffffffa0]c1[0xffffff9b]N[0xffffffc7][0xffffffa3]l[0xffffff90][0xffffff8f]c][0xffffffc9][0xffffffb8]V[0xfffffff1][0xffffffd7][0xffffffa5][0xfffffffa][0xffffff95][0xffffffab][0xffffffed][0x12]A[0xffffffc6][0xffffffc2][0xffffff87][0x0][0xffffffab]~2[0xffffffc5][0xffffffcf]2<[0xfffffffe][0x12]/[0xfffffffe][0xffffffd3][0xffffffc1][0x1c][0xffffffd6][0xffffffb5]P[0xffffffbb][0xffffffdb]M[0xffffffef][0xffffffd3][0xffffffce]][0xffffffa7][0xffffff93]4[0x1b]_[0xffffffcd][0xffffffc6]7[0x0][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:12 GMT
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-cache,no-transform
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: 0
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:12,992+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000005 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000005 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0][0xffffffdf]ftD[0xffffff82][0x2][0x0][0x0][\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000005 releasing valid endpoint
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000005 releasing endpoint
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000005 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000005 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,000+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.EndPointConfigurator:23 [main] patching 'di.idm.authentication.endpoint' in infrastructure settings ...
    2024-11-27T17:50:13,000+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: PATCH /topaz/api/urest/v1/settingContexts/di/di.idm.authentication.endpoint
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000006 preparing request execution
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000006 target auth state: UNCHALLENGED
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000006 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000006 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000006 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000006 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000006 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000006 acquired ep-0000000006
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000006 acquired endpoint ep-0000000006
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000006 executing PATCH /topaz/api/urest/v1/settingContexts/di/di.idm.authentication.endpoint HTTP/1.1
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000006 Cookie spec selected: strict
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000006 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.idm.authentication.endpoint]
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000006 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.idm.authentication.endpoint]
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000006 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.idm.authentication.endpoint]
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000006 start execution ex-0000000006
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000006 executing exchange ex-0000000006 over http-outgoing-1
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> PATCH /topaz/api/urest/v1/settingContexts/di/di.idm.authentication.endpoint HTTP/1.1
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Type: application/json
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Length: 136
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "PATCH /topaz/api/urest/v1/settingContexts/di/di.idm.authentication.endpoint HTTP/1.1[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Type: application/json[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Length: 136[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "{[\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "@type":"setting",[\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "context":"di",[\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "name":"di.idm.authentication.endpoint",[\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "value":"https://bvd.stc.com.sa:443/idm-service"[\n]"
    2024-11-27T17:50:13,000+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-1 >> "}"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:13 GMT[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-cache,no-transform[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: 0[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "160[\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffff8c][0xffffff92]Qk[0xffffffc2]0[0x14][0xffffff85][0xffffffdf][0x5][0xffffffff]C[0xffffffe8][0xfffffff3][0xffffff96][0xffffffb0])[0xe][0xffffffcb][0x10]E[0xffffffcb]([0xffffffe8]&Z[0xfffffff7][0x1e][0xffffff93][[\r][0xffffffb4]MHn[0xffffff8b]n[0xffffffec][0xffffffbf][0xffffffaf][0xffffffd6]X[0x1c]c[0xffffffc3][0xffffffb7]p[0xffffffee]wrn[0xffffffee][0xffffffcd]g[0xffffffb7]CH0[0xffffffc6][0xffffffa3][0xffffff81][0xffffff80][0xffffff84]$p[0xffffff80][0xffffffa8][0xffffff8a]]p[0xffffffd7][0xffffffe8]B[0x17][0x8][0x7]l*Ry[0xffffffd1][0xffffff81]@[0xffffffa5][0xb][0xffffff8f]7g*[0x15]U2[0xfffffff7]@[0xffffffc1]s[0xfffffff0][0xffffff96][0xffffff93]Jy[0xffffff89]{(P[0x9][0xffffffde][0xffffffb0]PH[0xffffffa3]U[0xffffff81][0xffffff9e][0xffffffce][0xfffffff8][0x16][0xffffffb2][0x6][0xffffff9f][0xfffffffc][0xffffffe0]H[0xffffffe4]9[0xffffffb2]Y[0xffffffcd]=+[0xffffffc1][0x9][0xffffffab]L[0x1b][0xffffffff][0x7f][0x0]=[0xffffffe1][0xffffffbf][0xffffff9d][0xfffffff3][0xffffffbf][0x2][0xffffffe1]*[0xffffff90][0xffffffa4][0xffffffda][0x12][0xb]h[0x15]T[0xfffffff5]<[0xffffff88][0xffffffe4][0xffffffc8]IjuN[0xffffffde][0xffffff96]I<%[0xffffffb3]9[0xffffff99][0xffffff9d][0xffffffa4][0xffffff89][0x10][0xffffffe0]\[0xffffffdb]+%[0xffffffd1][0xffffff81][0xffffffe7]&[0xffffff83][0xffffff90][0xffffffec][0x11][0xffffff8d][0xb][0x19]{^[0xffffff83][0xffffffad][0xffffffc0][0xffffff8e][0xffffffc2][0xffffffe7][0xffffffa5][0xffffffb6]8bu[0xffffffc3][0xfffffff7][0xffffffae][0xffffff96][0xffffff94][0x0][0xffffffea][0xffffff9b][0xffffffab]xV[0xffffff9e]'v1m+I[0x1d][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "*tN[0x1d][0xf][0xfffffffb][0xfffffffd][0xffffffde][0xffffffb5][0xffffffaf]}S[0xffffffca][0xffffffcb][0xc][0xffffffdf][[0xfffffff7]EW[0xffffffce]d[0xfffffffc][0x18][0x17][0x1b]u[0xffffff92][0xffffffd1][0xffffff96]p[0xffffff95][0xffffff93]\V[0xffffffbd]NV[0xfffffff1][0xffffffeb][0xffffff8b][0xfffffff7]XH-[0xffffffb8][0xfffffffd][0xffffff8a][0xffffffe3][0xffffffb9][0x18]/[0x16][0xffffffd1],[0xffffff9e]$[0xffffff91][0xffffffaf]+[0xffffffe9][0x7][0xffffffce]nZ[0xffffffea][0xffffffb8][0xffffffb4]Mv[0xffffffc0]P[0x1b][0xfffffffe][0xffffffc1][0xffffffb8]Q[0xffffffac][0xffffffac][0x3][0xffffff90]U[0xf][0xffffffcc][0xffffffff][0xffffffb1][0xffffffe9][0xfffffff9]s9v[0xfffffff3][0xffffffa5][0xffffff90][0xfffffff0]]s[0xffffffeb][0xffffffb0][0xfffffff7]4[0xffffffe8]=[0xe][0xfffffffa][0xffffffc3][0xffffffa0][0xffffffdb][0xfffffff9][0xffffffea]v[0xffffffbe][0x1][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:13 GMT
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-cache,no-transform
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: 0
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000006 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000006 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:13,055+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0][0xffffffda]z"[0xffffffcb][0xffffffc5][0x2][0x0][0x0][\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000006 releasing valid endpoint
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000006 releasing endpoint
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000006 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000006 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,064+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.EndPointConfigurator:23 [main] patching 'di.idm.tenant.id' in infrastructure OPTICDL settings ...
    2024-11-27T17:50:13,064+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: PATCH /topaz/api/urest/v1/settingContexts/di/di.idm.tenant.id
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000007 preparing request execution
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000007 target auth state: UNCHALLENGED
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000007 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000007 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000007 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000007 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000007 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000007 acquired ep-0000000007
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000007 acquired endpoint ep-0000000007
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000007 executing PATCH /topaz/api/urest/v1/settingContexts/di/di.idm.tenant.id HTTP/1.1
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000007 Cookie spec selected: strict
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000007 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.idm.tenant.id]
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000007 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.idm.tenant.id]
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000007 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/di.idm.tenant.id]
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000007 start execution ex-0000000007
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000007 executing exchange ex-0000000007 over http-outgoing-1
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> PATCH /topaz/api/urest/v1/settingContexts/di/di.idm.tenant.id HTTP/1.1
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Type: application/json
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Length: 92
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "PATCH /topaz/api/urest/v1/settingContexts/di/di.idm.tenant.id HTTP/1.1[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Type: application/json[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Length: 92[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "{[\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "@type":"setting",[\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "context":"di",[\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "name":"di.idm.tenant.id",[\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "value":"provider"[\n]"
    2024-11-27T17:50:13,064+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-1 >> "}"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:13 GMT[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-cache,no-transform[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: 0[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "125[\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3]|[0xffffff91]AK[0xffffffc3]@[0x10][0xffffff85][0xffffffef][0xffffff85][0xfffffffc][0xffffff87]!g[0xffffffc9][0xffffffda]T<xji[0xffffff82][0x4]Z[0xffffff95][0x1a][0xffffffbd][0xffffffaf][0xffffffd9]I]Hv[0xffffff97][0xffffffdd]I[0xffffffb0][0xffffff8a][0xffffffff][0xffffffdd]d[0xffffffb3]-[0xffffffd2][0xffffffa2][0xffffffb7][0xffffffe1][0xffffffbd]7[0xffffffdf]03_[0xffffffd1][0xc] ^[0xffffffd2][0xffffffc1]`[0xc]w[0x10];$[0xffffff92]j[0x1f]_y[0xffffffbd][0xffffffd2][0xffffff8a][0xfffffff0][0xffffff83][0xffffffbc]#d[0x10][0x1d]V$[0xffffffb5][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "q_'B&R[0xffffffb4]![0xffffffa0]x[0xffffff8b][0xffffffa1]eT[0x13]B[0xffffffc5][0x15][\r]e[0xfffffff0][0x1b][0xfffffffe][0xffffff86][0xffffff8d][0xf][0xffffff94][0xffffffde][0xffffff81]"[0xb][0xffffff8e]@WYiN[0xfffffff8]s@2[0x6].[0xffffffb3][0xffffff9b]K [0xffffffd4][0xffffffda][0xffffff82]E[0xffffffb2][0x12][0xfffffffb]a[0x1f][0x10][0xffffff9c]8[0xffffffd4]V[0xffffffb7][0xfffffff0][0xfffffff8]T[0x16]k[0xffffffc8]6[0xffffff90][0xffffff8d][0xffffffd2][0xffffffaa][0xffffffaa][0xffffffd0]9[0xffffffc8][0xffffff95]0Z[0xe]3[0x2][0xffffffbc][0xffffffe7]M7[0xffffffed]`[0xffffffac][0xffffffee][0xffffffa5]@{[0xffffff9a]Z[0xfffffff3][0xffffffae][0xffffffa1][0xffffffd7][0xffffff93][0x7f][0xffffffd4][0xffffffa5]3[\r]?[0x14][0xffffffea]E[0xffffff8e]2[0xffffffd9][0xe][0x7f][0xffffff91][0xffffffca][0xffffffe3]y[0xffffff9f][0xffffffcb]][0xfffffff1]p[0x1f]z,[0xffffffd6][0x16][0xffffffdd][0xfffffffb][0xffffff8e][0xffffffd3]d[0x16][0xffffffdb]m[0xffffff9e][0x15][0xffffffab]2[0xf][0xfffffffe]p[0xffffffb0][0xffffffe9][0x8][0xffffffec][0xffffff8f]C.;[0xffffffeb][0xffffffa7][0xffffffc5][0xffffff8c][0xffffffb4][0xffffffe1][0xffffff9f][0xffffff8c][0x1b][0xffffffc9][0xffffffba][0x1]I[0xffffffac][0xffffff9f][0xffffffb3][0xfffffff0][0xffffffc9][0xfffffff5][0xfffffff4]B[0xffffffc7][0xfffffffe][0xffffffc1]`[0xffffffc9][0xfffffff7][0xffffff9e]s{[0xffffffb3]X[0xffffffcc][0xffffffd3][0xffffffeb]4[0xffffff8d][0xffffffa3][0xffffffd9]w4[0xfffffffb][0x1][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:13 GMT
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-cache,no-transform
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: 0
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000007 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:13,112+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000007 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xffffff9d][0x6]"[0x1d][0x2][0x0][0x0][\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000007 releasing valid endpoint
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000007 releasing endpoint
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000007 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000007 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,117+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.EndPointConfigurator:23 [main] attempting to patch 'des.receiver.endpoint' in infrastructure settings ...
    2024-11-27T17:50:13,117+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: PATCH /topaz/api/urest/v1/settingContexts/di/des.receiver.endpoint
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000008 preparing request execution
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000008 target auth state: UNCHALLENGED
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000008 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000008 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000008 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000008 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000008 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000008 acquired ep-0000000008
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000008 acquired endpoint ep-0000000008
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000008 executing PATCH /topaz/api/urest/v1/settingContexts/di/des.receiver.endpoint HTTP/1.1
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000008 Cookie spec selected: strict
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000008 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/des.receiver.endpoint]
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000008 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/des.receiver.endpoint]
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000008 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/api/urest/v1/settingContexts/di/des.receiver.endpoint]
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000008 start execution ex-0000000008
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000008 executing exchange ex-0000000008 over http-outgoing-1
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> PATCH /topaz/api/urest/v1/settingContexts/di/des.receiver.endpoint HTTP/1.1
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Type: application/json
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Length: 128
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "PATCH /topaz/api/urest/v1/settingContexts/di/des.receiver.endpoint HTTP/1.1[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Type: application/json[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Length: 128[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "{[\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "@type":"setting",[\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "context":"di",[\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "name":"des.receiver.endpoint",[\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "  "value":"https://bvd.stc.com.sa:30010/v1/itomdes"[\n]"
    2024-11-27T17:50:13,117+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-1 >> "}"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:13 GMT[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-cache,no-transform[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: 0[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "14f[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffff84]R[0xffffffcf]O[0xffffffc2]0[0x14][0xffffffbe][0xffffff93][0xfffffff0]?4;k[0xffffffcb][0x4]/[0xffffff9c]0[0xffffff8c][0xffffff98]%[0xffffffa0][0x6][0xffffff86][0xfffffff7][0xffffffd2]=X[0xffffff93][0xffffffad]m[0xffffffda][0xffffffb7])[0x1a][0xffffffff]w[0xffffffbb][0xffffffad],[0x1a][0xffffff8d][0xffffffde][0xffffff9a][0xffffffef]}[0xffffffbf][0xffffff9a][0xfffffff7][0xffffffde][0xffffffc7]#B[0xffffffa2][0x5][0xffffff9e][\r]DdN"[0x7][0xffffff88]R[0xffffff9d][0xffffffa2][0xffffffab][0xe][0x17]Z![0xffffffbc]b7[0xffffffc9]e[0x0][0x1d][0x8][0xffffff94]Z[0x5]z[0xfffffff7][0xffffffa6][0xffffffb9][0xffffffa4][0xffffffda][0xffffffb8]C`(^[0xfffffff5]n98jA[0xffffff80]l[0xffffffc0]RP[0xffffffb9][0xffffffd1]Ra [0xffffff95][0xfffffffc][0x0]e[0xffffffc7]J8r[0xffffffb2]RV[0xffffff8a][0xffffffa2][0x2][0xffffff85]d[0x7][0xffffffb6][0xffffff91][0x2][0xffffffc8]6([0xfffffffd][0xffffffec][0xffffff9b][0xffffffd2][0xffffffbb][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "+[0xffffffcd]P[0xffffffe2][0xffffffd7][0x14][0xffffffda][0xffffffb2]~[\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xffffffd6]C[0xffffffea][0xffffffde][0x1][0xffffffc1]B:b[0xffffffb8][0xfffffff5]}[0xffffffd1][0xffffffe7][0xffffffa0]&[0xffffffce][0xffffffeb]I[0xffffffa2]_[0x14][0xffffffca][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "H[0xffffffde]6[0xfffffff3][0xffffffe8][0xffffffe3]S[0xffffff96].I[0xffffffb2][0xffffffa6]$86[0xffffffbc][0xffffffac][0xfffffffb]/[0x16][0xffffff88][0xffffffc6][0xffffffcd][0x19];49u([0xffffffa8][0xffffffd0][0x15]u|>[0xffffff9d]L[0xffffffe2][0x9]kb&QW>[0x7f]hr[0xffffffe4]u[0xffffff89][0xffffffcf][0xffffff83][0xfffffffc][0xffffff82]KgJ~N[0xffffffd5]^[0xffffffb6]0[0xffffffda][0x1a][0xffffffbe][0x4]e[0xffffff97][0xffffffed][0xffffffec][0xffffffb2]m[0xfffffffa]p[0x1f]4[0x16][0xffffff8e][0x16]\[0xffffffb1][0xffffffe5][0xffffffd8][0xf][0xffffffd3][0xffffffcd]f[0xffffff95][0xffffffa4]w[0xffffffd9]*[0xffffffcc]e[0x1e][0xfffffff6][0xffffffc6][0xfffffffe]Z[0xffffffc3][0xffffffa2][0xffffffb6]]d[0xffffffc4]P[0x1b][0xfffffffe][0xffffffc6][0xffffffb8][0xffffff91][0xffffffac][0xfffffff6][0xffffffbe][0xffffffd8][0xffffff96][0xf][0xffffffd7][0xffffffb0][0xffffffec][0xffffffcf][0xffffffc0][0xffffffb1][0xffffffff][0xffffffbc] [0xffffffe3][0xffffffa7][0xffffffce][0xffffffec]:[0xffffffbe][0xffffff99]M[0xffffffe3][0xfffffff8]6[0xffffff9e]M[0xffffffa3][0xfffffff1][0xffffffe8]c<[0xfffffffa][0x4][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:13 GMT
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-cache,no-transform
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: 0
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000008 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000008 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0]p[0xffffffe4]O[0xffffff9d]h[0x2][0x0][0x0][\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000008 releasing valid endpoint
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000008 releasing endpoint
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000008 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:13,160+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000008 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:13,175+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] end point configured
    2024-11-27T17:50:13,175+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] establishing trust ...
    2024-11-27T17:50:13,180+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.TrustEstablisherWindows:23 [main] installing suite certificates ...
    2024-11-27T17:50:13,180+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.TrustEstablisherWindows:23 [main] installing C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519\opsb_issue_ca.crt certificate ...
    2024-11-27T17:50:13,180+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:86 [main] running command: [C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519\opr-config-idl.bat, -cacert, C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519\opsb_issue_ca.crt] ...
    2024-11-27T17:50:14,617+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:120 [main] command exit value: 0
    2024-11-27T17:50:14,617+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:122 [main] command stdout: WARNING: Certificate with alias 'MF CDF RIC CA on cluster-87f45ba4aa' is
             already installed.
    WARNING: Certificate with alias 'MF RE CA on Vault b1a7e6f0' is already
             installed.
    ERROR: Cannot import certificates from file C:\Users\habdo\AppData\Local\Temp\2\event-forwarding-configuration_2997738313843912519\opsb_issue_ca.crt into LCore truststore
    Please remove the aliases as mentioned above with:
    "E:\Program Files\HP\HP BTO Software\\bin\win64\ovcert" -remove <alias>
    and
    "E:\Program Files\HP\HP BTO Software\\bin\win64\ovcert" -remove <alias> -ovrg server
    or remove the -cacert option if you want to reuse the currently available CA certificates in the LCore truststore
    2024-11-27T17:50:14,617+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.UtilsKt:123 [main] command stderr: ERROR:   Import operation failed. The given certificate(s) could not be
             installed.
    2024-11-27T17:50:14,617+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] trust established
    2024-11-27T17:50:14,617+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] uploading forwarding content-pack ...
    2024-11-27T17:50:14,617+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.ContentPackDeployer:23 [main] checking if content-pack ContentPack(name=COSO_Data_Lake_Event_Integration, version=9.06) is already deployed
    2024-11-27T17:50:14,617+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: GET /opr-web/admin/rest/contentPackDefinition?name=COSO_Data_Lake_Event_Integration&contentPackVersion=9.06
    2024-11-27T17:50:14,617+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000009 preparing request execution
    2024-11-27T17:50:14,617+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000009 target auth state: UNCHALLENGED
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000009 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000009 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000009 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000009 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000009 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000009 acquired ep-0000000009
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000009 acquired endpoint ep-0000000009
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000009 executing GET /opr-web/admin/rest/contentPackDefinition?name=COSO_Data_Lake_Event_Integration&contentPackVersion=9.06 HTTP/1.1
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000009 Cookie spec selected: strict
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000009 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/contentPackDefinition?name=COSO_Data_Lake_Event_Integration&contentPackVersion=9.06]
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000009 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/contentPackDefinition?name=COSO_Data_Lake_Event_Integration&contentPackVersion=9.06]
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000009 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/contentPackDefinition?name=COSO_Data_Lake_Event_Integration&contentPackVersion=9.06]
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000009 start execution ex-0000000009
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000009 executing exchange ex-0000000009 over http-outgoing-1
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> GET /opr-web/admin/rest/contentPackDefinition?name=COSO_Data_Lake_Event_Integration&contentPackVersion=9.06 HTTP/1.1
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: text/xml
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "GET /opr-web/admin/rest/contentPackDefinition?name=COSO_Data_Lake_Event_Integration&contentPackVersion=9.06 HTTP/1.1[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: text/xml[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:14,631+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:14 GMT[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-store, no-cache, must-revalidate[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: Thu Jan 01 03:00:00 AST 1970[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Link: </opr-web/rest>; rel="service"[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; Path=/; Secure;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: text/xml;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "19d[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffffa4][0xffffff93][0xffffffcb]n[0xffffffdb]0[0x10]E[0xfffffff7][0xfffffffd][0xffffff8a][0xffffffd9]q[0xffffffc5][0xffffff9a]"%[0xffffff8b][0x14]l/[0x12]7@[0xffffff80][0x16].j[0xffffffa0][[0xffffff81][0xffffff8f]a,X[0xffffff96][0x4][0xffffff8a]N[0xffffff9b][0xffffffbf]/e%A[0x2]4A[0xffffff80][0xffffffec][0xfffffff8][0xffffffb8][0xffffffbc]<s[0xffffff87]\][0xfffffff7]][0xffffffc4].[0xfffffffe][0xffffffd4][0xfffffff6][0xffffffb8]E[0xffffffdf]tMl[0xfffffffa][0xe][0x1a][0xffffffb7]&%[0xffffff97][0xffffffc6]y[0xfffffff4][0xffffffd4][0xffffff94]F[0xffffffd2]\(Nu[0xffffffc6],[0xffffff95][0xffffffd2][0xffffffb1]LZ[0xffffff81].c[0x4]Zm[0xffffffb0]][0xffffff93][0xffffffeb][0xffffffdd]~[0x7][[0x1d]5|[0xffffffd7]G[0xffffff84]o[0xfffffff7][0xffffffc9][0x13]n[0xffffff93][0xfffffff5]][0xffffffd0][0xffffff93]#[0xffffff81]N[0xffffff9f]p[0xffffffd6][0xffffffd5][0xffffff93][0xffffffae][0xffffff9e]t[0xfffffff5]EW[0xffffffbf][0xffffffd2][0xffffffd9][0xffffffe1]7[0xffffff86]1[\r][0xffffffd7]D}eK[0x2][0xffffffcd][0xffffffb8]?[0xffffffe8][0xffffff80][0xffffff89]([0xffffff86]3[0x12][0xffffffb8][0x7f][0xffffffda]fd[0xfffffff3][0x5]`[0xffffffb5][0xffffffc5][0xffffffd1][0xffffff86]f[0xffffff98]No[0x1e][0xffffffab][0xffffff81][0xffffffd8][0xffffff83][0xffffffef][0xffffffc3][0x1f][0x1d][0x1c][0xffffffec][0xffffffae]~[0xffffffcc]8#4]Z[0xffffff8f][0x7][0xffffff84][0xffffffd7][0xffffffb4][0xffffffab][0xffffffc5]K[0xffffff8b][0xffffffc9]r[0xffffff8f]-[0xffffffda][0xffffff88][0xffffffee]6[0xffffffe2][0x9][0xffffff8e][0xfffffff8][0xffffffb0]&<7^0[0xffffffeb]h[0xffffffb6],4[0xffffffcd][0xffffffb5][0xffffffc9][0xffffffa8][0xfffffff2][0xffffffd2][0xffffffd2]4[0x13][0xffffff85][0xffffffe2]E)2[0xfffffff5][0xffffffe1]0[0xffffffe0][0xffffffa6]i#[0x6][0x2][0xfffffff1]aH[0xffffff99][0xffffff9c]CW[0xfffffffd][0xffffffa5][0xffffff87][0xffffffa1][0xffffffe2][0xffffff8c][0xffffffa9]j[0xffffffec]}L[0xffffffe0]X[0xffffffb9])[0xffffffa5]S[0xffffffef][0xffffffb0][0xffffffad][0xfffffffa]!T[0xffffff93][0xffffffb6][0xffffffb2]s}[0x15]^r[0x1b]Boq[0x1c][0xffffff9b][0xffffffee][0xffffffae][0xfffffff6][0xffffff8f][0xffffff8e][0xffffff8b][0xffffffb7][0xfffffff8][0xffffffb1]T[0xffffffb2]P[0xffffff8c][0x1a][0xffffffa9]s[0xffffff9a][0x17].[0xffffffa3]R$~[0xffffffce][0xffffffac]7[0xffffffce][0x19][0xffffffb7][0x14][0xfffffffc]}[0xfffffffe][0xffffff9b]9[0xffffffcf]t[0x19][0xffffffec]/a}[0x2][0xffffffdf]?{[0xffffffd5]s[0xfffffff0][0xffffffb5]{~{o[0xffffffd7]`[0xffffff84][0xffffffd6][0xffffffce]yN[0xffffffd1][0x16][0xffffff96][0xffffffe6]J![0xffffffd5][0xffffffc2]K[0xffffffca]8J'J[0xffffffb4]nY|[0xffffffbc][0x7][0xffffffbf][0xffffffce]-~[0xffffffba][0x3]/[\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x9][0x17][0xffffffbf][0xffffffc4][0xffffffbe]Z[0xfffffffc][0xfffffff7]Om[0xfffffffe][0x1][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:14 GMT
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-store, no-cache, must-revalidate
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: Thu Jan 01 03:00:00 AST 1970
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Link: </opr-web/rest>; rel="service"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; Path=/; Secure;SameSite=none;Secure
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: text/xml;charset=UTF-8
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000009 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000009 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0]D[0xffffffd9]{[0x11]k[0x3][0x0][0x0][\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000009 releasing valid endpoint
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000009 releasing endpoint
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000009 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000009 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,062+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.ContentPackDeployer:23 [main] content-pack already deployed
    2024-11-27T17:50:21,062+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] forwarding content-pack uploaded
    2024-11-27T17:50:21,062+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:23 [main] configuring forwarding content-pack ...
    2024-11-27T17:50:21,062+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.ContentPackConfigurator:23 [main] checking if forwarding content-pack is already correctly configured
    2024-11-27T17:50:21,062+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.ContentPackConfigurator:23 [main] getting forwarding rule
    2024-11-27T17:50:21,062+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: GET /opr-web/admin/rest/processingRule/b3aaddf2-ec5c-499e-a3f8-02e8d37ecd65
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000010 preparing request execution
    2024-11-27T17:50:21,062+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000010 target auth state: UNCHALLENGED
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000010 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000010 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000010 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000010 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000010 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000010 acquired ep-0000000010
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000010 acquired endpoint ep-0000000010
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000010 executing GET /opr-web/admin/rest/processingRule/b3aaddf2-ec5c-499e-a3f8-02e8d37ecd65 HTTP/1.1
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000010 Cookie spec selected: strict
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000010 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/processingRule/b3aaddf2-ec5c-499e-a3f8-02e8d37ecd65]
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000010 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/processingRule/b3aaddf2-ec5c-499e-a3f8-02e8d37ecd65]
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000010 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/processingRule/b3aaddf2-ec5c-499e-a3f8-02e8d37ecd65]
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000010 start execution ex-0000000010
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000010 executing exchange ex-0000000010 over http-outgoing-1
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> GET /opr-web/admin/rest/processingRule/b3aaddf2-ec5c-499e-a3f8-02e8d37ecd65 HTTP/1.1
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "GET /opr-web/admin/rest/processingRule/b3aaddf2-ec5c-499e-a3f8-02e8d37ecd65 HTTP/1.1[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:21,078+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:21 GMT[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-cache,no-transform[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "278[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffffa4]TMo[0xffffffdb]0[0xc][0xffffffbd][0x17][0xffffffe8][0x7f][0x10]z[0xffffffae][0x6][0x7f]6[0xffffff91]O[0xffffffeb][0xffffff96][0x16]([0xffffffb0]5[0xffffffc3][0xffffffda][0x1d][0xffffff86]a[0x10][0x14][0xffffff89]J[0xffffff84]9[0xffffffb2]![0xffffffc9]Y[0xffffff86]"[0xffffffff]}[0xffffffb6][0xffffff9c][0xffffffd6][0xffffff8e][0xffffffeb][0x14]h{4[0xfffffff9][0xfffffff8]H>>[0xfffffff9][0xffffffe1][0xfffffff4][0x4]!t[0xffffffc6]*W[0xffffffac][0xffffff99]S[0xffffff85][0xffffffa6][0xffffffa6][0xffffffca][0xffffffe1][0xc]e[0xffffffe8][0xffffffc1]g[0xffffff9a][0xffffffe4]G[0xb][0xffffffb9][0xffffffa4][0xffffffee]_[0xffffffe9][0xffffffe3]g[0xffffff95][0xffffffd1][0xffffffd9][0x16][0xffffffaf][0xffffffca],[\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x2][0xffffff92][0xffffffd9]B[0xffffffba][0xffffffbf][0xffffffcc]@&[0xffffff98]ct][0x8][0xffffffc8][0xffffffb3][0xffffffa2]4Y[0x3][0xffffffcf][0xffffff86][0xffffffb4][0xffffffe7][0x1d][0xffffffe7][0x6][0xffffff8c][0xffffffad][0xffffffe3][0xffffff9e]1[0xfffffffc][0x10][0xfffffff4]RJ[0xfffffff8][0xffffffe0]"fL[0x8][0x19]a[0xffffffe0])[0xffffffc7][0x9]![0xffffff80]Y,[0xffffffa7]8[0xffffff88]`*[0xffffffe2][0x9]pq[0xffffff91][0xfffffff6][0xffffffaa]z|A[0x17][0xffffffcd][0xffffffd9][0x2]rO[0xfffffff7]y~7G[0xffffffb3]zF[0xfffffff4][0xffffff85][0xfffffffd][0x1]t[0xffffffb5][0x1][0xffffffed][0xffffffd0][0xffffff8d]v[0xffffffb0]4~@[0xfffffff4][0xfffffffd]p@[0x1][0xffffff96][0x1b]U[0xffffffba][0xffffffc7][0x19][0xffffffaf][0xb]S[0xffffffaf])[0xffffff94]^z$r[0x5]R[0xfffffffb]j@[0xfffffff3]O_[0x11]4[0xffffff8c][0xffffffb6][0x9][0x16][0xffffffc8][0xffffffad][0x0][0x1d]6[0xffffffec]1[0xffffff97][0xffffff95])[0xb][0xffffffdb]j[0xffffffe9][0xffffff8b][0xffffffa8]|[0xffffffe2][0xffffffee][0xffffffc1][0x18]wj[0xffffffe3]Q[0xffffff92][0xffffffe5][0x16][0xffffffba][0xffffff84][0x1][0xb][0xffffffee][0xffffff8e][0xffffffaf]@[0xffffffd4]s[0xffffffcc][0xfffffff5][0xffffffac]*[0xfffffffd]2#HQ[0xffffffb5][0xffffffbb][\r]DY[0xffffffb3]-[0xffffff85]-[0xfffffff0][0xffffffaa][0xffffffc9][0xffffffd9]AR[0xffffffaa][0xffffffdc][0xffffff81][0xffffffa1][0x6][0xffffffe4][0xffffff81][0x9][0xffffffde][0xffffffe7][0xffffff83][0xffffff9a][\r][0xc]h[0xe]YK[0xffffffdf][0xffffffad][0xfffffff9][0xffffffb2][0x17]|[0xffffffd6]1[0xffffffb3][0x4]GM[0xffffff91][0xffffffbf][0xffffffa6][0xffffffaf][0xffffff81][0xffffffdc][0xffffffef]nW[0xffffffaa][0x1c][0xfffffffa]0[0xffffffe3][0xffffff85]vLi;:[0xffffffce][0xffffffbe][0xffffffdf][0xffffffde][0xffffff86]Q[0xffffffb2][0xffffff90]q[0xffffffc0][0x5][0xe]/R[0xffffff86][0x13][0xffffffb6][0x8]1[0xffffff91]S[0xffffff8e][0xffffffeb][0xffffffaf]8%Q:[0xffffff89]C2Z[0xffffffff][0x16][0xffffff9d]^[0x18][0xffffffe7][0x15]N[0xffffffbe]nY[0x1e]Iv[0xffffff87][0xffffff9e][0xffffffaa]5[0xffffffc8][0xffffff95]u[0xffffffcf][0xffffffae];[0xffffffb4]"m[0xffffffc1][\r][0xffffffee][0xffffffd7][0x1][0xfffffff2]MV[0xfffffff0][0xffffffeb][0x1d]kq>d[0x7f][0xffffffc9][0x10][0x1e][0xffffffa0][0xffffffb4][0xffffff80][0xffffffad]O?O[0xffffffee][0xf]7[0xffffffb9][0xffffff88]&1![0x11]Ne[0xffffff9a][0xffffffe0]$[0xffffff80][0x18][0xffffff93]0[0x16][0xffffff98][0xffffffc4]L$r[0x1a]&[0x10]L[0xffffff9f][0xffffffd5]v[0xffffff8f][0xffffffce][0xffffff99][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0xffffff86][0xffffffd9][0xfffffff6][0x14]C[0xffffffe5][0xffffffde][0xfffffffd]:j7j[0xffffffe0][0xe][0x4][0xffffffb5]`6[0xffffff83][0xfffffffb][0xffffff8f]K[0x12][0xffffff8d]b[0xfffffffa][0xffffff9e][0xffffffb7]Ti[0xffffff9e]W[0x2][0xffffffc4][0xffffff91]mzRq[0xffffff88]Y0![0xffffffbc][0xfffffffe][0xffffffd5]r[0xffffff82][0xffffff93]H&x1I[0x3][0x1c][0xffffffc5]2[0xffffff9c][0x2]a@[0xffffffd2]x[0xffffffac][0xffffffa1]fkx[0xffffffb2]$m,I[0x1b]K[0xffffffd2][0xffffffcb]\1;Vp[0xffffffd4][0xffffffc4]G+[0xffffff8e][0xfffffffd][0x5];D[0xffffffab]Y'<[0xfffffff3]T[0xffffff87][0xffffffb8][0xffffffdd][0xfffffff0][0xffffff92]=[0xf]>[0x15][0xffffffde][0xffffffce][0xffffffef]o[0xffffffae][0x7f][0xffffffd2][0xffffffcb][0xffffffdb][0x19][0xfffffffd][0xfffffff1]mvy[0x7f][0xffffffd5]'[0xffffffd9][0xffffffa1][0xffffffdf]c[0xffffffef][0xffffffc9]8%[0xffffffeb][0x11]ia[0xffffffd4]R[0xffffffb5][0xffffffc7])[\r][0x8][0xffffff90]J[0xffffffd7][0xffffffc2]{[0xffffffdc][0xffffffee][0xfffffff4]d[0xfffffff7][0x1f][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:21 GMT
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-cache,no-transform
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd;Path=/;Secure;Version=1;SameSite=none;Secure
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000010 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000010 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0]~[0xffffff86][0x2][0xffffffeb]f[0x7][0x0][0x0][\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000010 releasing valid endpoint
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000010 releasing endpoint
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000010 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:21,492+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000010 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,524+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.ContentPackConfigurator:23 [main] getting connected server with id ce3a079c-ecc9-42f4-b750-23f18e9ae953
    2024-11-27T17:50:21,524+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: GET /opr-web/admin/rest/connectedServer/ce3a079c-ecc9-42f4-b750-23f18e9ae953
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000011 preparing request execution
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000011 target auth state: UNCHALLENGED
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000011 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000011 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000011 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000011 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000011 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000011 acquired ep-0000000011
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000011 acquired endpoint ep-0000000011
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000011 executing GET /opr-web/admin/rest/connectedServer/ce3a079c-ecc9-42f4-b750-23f18e9ae953 HTTP/1.1
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000011 Cookie spec selected: strict
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000011 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer/ce3a079c-ecc9-42f4-b750-23f18e9ae953]
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000011 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer/ce3a079c-ecc9-42f4-b750-23f18e9ae953]
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000011 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer/ce3a079c-ecc9-42f4-b750-23f18e9ae953]
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000011 start execution ex-0000000011
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000011 executing exchange ex-0000000011 over http-outgoing-1
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> GET /opr-web/admin/rest/connectedServer/ce3a079c-ecc9-42f4-b750-23f18e9ae953 HTTP/1.1
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "GET /opr-web/admin/rest/connectedServer/ce3a079c-ecc9-42f4-b750-23f18e9ae953 HTTP/1.1[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:21,524+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:21 GMT[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-store, no-cache, must-revalidate[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: Thu Jan 01 03:00:00 AST 1970[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Link: </opr-web/rest>; rel="service"[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; Path=/; Secure;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "10d[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffff94][0xffffff90][0xffffffcd]n[0xffffff83]0[0x10][0xffffff84][0xffffffef][0xffffff91][0xfffffff2][0xe][0x16][0xffffffe7][0xffffff82]i J[0xffffffe0][0xffffffd4][0xffffffaa]=V[0xffffffca]![0xf]`-fI[0xffffffac][0x1a][0x1b]y[0xffffff97]TU[0xffffff94]w/?R[0xffffff88]r[0xffffffeb]u[0xfffffff6][0xffffff9b][0xffffffd9][0xffffffd9][0xffffffbd][0xffffffae]WB[0xffffff88]H{[0xffffffe7]P3[0xffffffd6][0xffffff8a]0\0D[0xffffffa2][0x14][0xffffffd7]i4N[0xffffffdf][0x8]m3J[0xffffffd1][0xffffff99][0xffffffb9][0xffffffa3]RJj!p[0xffffffeb][0xffffff9d]a[0x1f][0xffffff8c];%[0xffffffc4]:[0xffffffd1][0xffffffbe]M[0x8][0xffffffca]<[0xffffffcf][0xffffffa4][0xffffffef]B[0xfffffffc][0xffffff83][0xffffff95][0xffffff84][0xffffffba]5N[0x6]$[0xffffff96][0xfffffff7][\r][0xffffffc7]i[0xffffff81][0xffffffd4][0xffffff98]A[0xffffffba]+t[0xffffff8c]Z[0x17]q[0xffffffbe]i[0xfffffff2][0xffffffb8][0xffffffda]m[0xffffffd3]x[0xffffff93]5[0xffffffaf]{,[0x0][0xffffff8b]m[0x16][0xffffffbd],[0x15][0x2]Z`[0xffffffe3][0x1d][0xffffff9d]MG[0xffffffca]8m[0xfffffffb][0x1a][0xffffffeb][0xffffffb1][0x14][0xffffff87][0x1e][0x17][0xffffffd0]LZ[0xfffffff4][0xffffffcf][0xfffffff8][0xffffffa1][0x11][\r][0xffffffe1][0xffffffa3]5]T[0x7]-Ni[0x1f][0xffffff87][0xffffffe3]A}[0x2][0xffffff83][0xfffffffa][0xffffff82]oT[0xffffffef][0xffffffd6][0x0]=[0xffffffb8]-Th[0xffffffef][0xffffffa0][0x18]A1[0xffffff82][0xffffffe2][0x19][0x4][0xffffffcd][0xffffffe6]2E6`[0xffffffe9][0xffffffa1][0xfffffff5][0xfffffffc]u[0xffffffc5][0xffffffbf][0xffffffdd][0xffffffbc][0x10][0xffffff9e][0xffffff8d][0xffffff81]M3[0xffffffb8][0xffffffd5][0xfffffff0][0xffffffee][0xffffff93]q[0xfffffff3][0xffffff89]=[0xffffffb1]o[0xffffffa3][0xffffff89][0xffffffb9][0xffffffad]W[0xffffffb7]?[0x0][0x0][0x0][0xffffffff][0xffffffff][\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 200 200
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:21 GMT
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-store, no-cache, must-revalidate
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: Thu Jan 01 03:00:00 AST 1970
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Link: </opr-web/rest>; rel="service"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Vary: Accept-Encoding
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Encoding: gzip
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Set-Cookie: secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; Path=/; Secure;SameSite=none;Secure
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000011 Cookie accepted [secureModifyToken="20f04015f0e9442c0c54f9e92fa5574de3c7a8dd", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000011 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "a[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[0x3][0x0]8[0xffffffd4]~u[0xffffffcb][0x1][0x0][0x0][\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000011 releasing valid endpoint
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000011 releasing endpoint
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000011 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:21,555+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000011 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,555+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.ContentPackConfigurator:23 [main] forwarding content-pack not configured
    2024-11-27T17:50:21,555+03 INFO  com.microfocus.opsbridge.aiops.obmconfigurator.ContentPackConfigurator:23 [main] creating connected server
    2024-11-27T17:50:21,569+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.AuthenticatedClient:179 [main] Performing request: POST /opr-web/admin/rest/connectedServer
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000012 preparing request execution
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000012 target auth state: UNCHALLENGED
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000012 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000012 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000012 acquiring endpoint (300000 MILLISECONDS)
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000012 endpoint lease request (300000 MILLISECONDS) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000012 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000012 acquired ep-0000000012
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000012 acquired endpoint ep-0000000012
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000012 executing POST /opr-web/admin/rest/connectedServer HTTP/1.1
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000012 Cookie spec selected: strict
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000012 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer]
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000012 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer]
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000012 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/opr-web/admin/rest/connectedServer]
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-1 set socket timeout to 300000 MILLISECONDS
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000012 start execution ex-0000000012
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000012 executing exchange ex-0000000012 over http-outgoing-1
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-1 >> POST /opr-web/admin/rest/connectedServer HTTP/1.1
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Type: text/xml
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept: application/json
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Content-Length: 1438
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Host: localhost:443
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Connection: keep-alive
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-1 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "POST /opr-web/admin/rest/connectedServer HTTP/1.1[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Type: text/xml[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept: application/json[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Content-Length: 1438[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "[\r][\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "{[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "   "connected_server":{[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "name":"COSO_Data_Lake",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "label":"COSO Data Lake",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "active":true,[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "server_type":"external_process",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "configuration_item":{[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "label":"Management System",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "type":"management_system"[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      },[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "dns_name":"bvd.stc.com.sa",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "connection_port":"30001",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "username":"stc_obm",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "password":"foo",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "use_secure_http":true,[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "support_back_sync":true,[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "support_transfer_control":false,[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "root_url_path":"",[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "use_groovy_script_integration":true,[\n]"
    2024-11-27T17:50:21,569+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "max_transaction_time_adapter":60,[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "drilldown_node":"",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "drilldown_port":443,[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "use_drilldown_secure_http":true,[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "delivery_mode":"serial_per_source",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "parallel_delivery_count":2,[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "artifact_origin":"custom",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "groovy_script_ref":{[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "@self_type":"urn:x-hp:2009:software:data_model:opr:type:reference:script",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "@version":"1.0",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "@target_role":"urn:x-hp:2009:software:data_model:opr:relationship:resource_base:references:script",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "target_id":"2e798590-b8a4-45d1-838c-20cfbddbd632",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "target_type":"urn:x-hp:2009:software:data_model:opr:type:script",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "target_display_name":"COSO_Data_Lake_Event_Forwarding_Script",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "target_name":"COSO_Data_Lake_Event_Forwarding_Script",[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "target_script_type":"forwarding"[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      },[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      "dns_names":[[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "         "bvd.stc.com.sa"[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 >> "      ]   }[\n]"
    2024-11-27T17:50:21,586+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-1 >> "}"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "HTTP/1.1 409 409[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Date: Wed, 27 Nov 2024 14:50:21 GMT[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Cache-Control: no-store, no-cache, must-revalidate[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Expires: Thu Jan 01 03:00:00 AST 1970[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Link: </opr-web/rest>; rel="service"[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Transfer-Encoding: chunked[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "Content-Type: application/json;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "1e5[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "{[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "   "error" : {[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "      "@self_type" : "urn:x-hp:2009:software:data_model:opr:type:error",[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "      "@version" : "1.0",[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "      "@http_code" : 409,[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "      "message_id" : "opr.object.validate.error",[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "      "message" : "ConnectedServer [COSO Data Lake (ef716683-5da3-4f7b-98ff-8ab9afc24aeb)] failed to validate due to the following errors:\n* A Connected Server with the DNS name [bvd.stc.com.sa] already exists.",[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "      "exception" : "com.hp.opr.SpringValidationErrorException"[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "   }[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "}[\r][\n]"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-1 << HTTP/1.1 409 409
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Date: Wed, 27 Nov 2024 14:50:21 GMT
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Server: Apache
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Cache-Control: no-store, no-cache, must-revalidate
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Expires: Thu Jan 01 03:00:00 AST 1970
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Link: </opr-web/rest>; rel="service"
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Keep-Alive: timeout=15
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Connection: Keep-Alive
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Transfer-Encoding: chunked
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-1 << Content-Type: application/json;charset=UTF-8
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000012 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:22,633+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-1 << "0[\r][\n]"
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000012 releasing valid endpoint
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000012 releasing endpoint
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000012 connection http-outgoing-1 can be kept alive for 15 SECONDS
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000012 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:22,648+03 DEBUG com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.Response:57 [main] response body: {
       "error" : {
          "@version" : "1.0",
          "@http_code" : 409,
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:247 [main] Shutdown connection pool GRACEFUL
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:174 [main] http-outgoing-1 close connection GRACEFUL
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:250 [main] Connection pool shut down
    2024-11-27T17:50:22,648+03 DEBUG com.microfocus.footils.obm.rest.ObmHttpClientProvider:114 [main] Disconnecting by executing GET at /topaz/TopazSiteServlet?requestType=logout
    2024-11-27T17:50:22,648+03 DEBUG com.microfocus.footils.http.AbstractHttpClientProvider:184 [main] Added cookie store to builder.
    2024-11-27T17:50:22,648+03 DEBUG com.microfocus.footils.http.AbstractHttpClientProvider:195 [main] Adding SSL context.
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ex-0000000013 preparing request execution
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000013 target auth state: UNCHALLENGED
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000013 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000013 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000013 acquiring endpoint (3 MINUTES)
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000013 endpoint lease request (3 MINUTES) [route: {s}->https://localhost:443][total available: 0; route allocated: 0 of 5; total allocated: 0 of 25]
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000013 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000013 acquired ep-0000000013
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000013 acquired endpoint ep-0000000013
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:130 [main] ex-0000000013 opening connection {s}->https://localhost:443
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:160 [main] ep-0000000013 connecting endpoint (10000 DAYS)
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:444 [main] ep-0000000013 connecting endpoint to https://localhost:443 (10000 DAYS)
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:138 [main] localhost resolving remote address
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:144 [main] localhost resolved to [localhost/127.0.0.1, localhost/0:0:0:0:0:0:0:1]
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:177 [main] localhost:443 connecting null->localhost/127.0.0.1:443 (10000 DAYS)
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:226 [main] Connecting socket to localhost/127.0.0.1:443 with timeout 10000 DAYS
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:299 [main] Enabled protocols: [TLSv1.3, TLSv1.2]
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:300 [main] Enabled cipher suites: [TLS_AES_256_GCM_SHA384, TLS_AES_128_GCM_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDH_RSA_WITH_AES_256_CBC_SHA, TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDH_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_EMPTY_RENEGOTIATION_INFO_SCSV]
    2024-11-27T17:50:22,648+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:301 [main] Starting handshake (null)
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:59 [main] Secure session established
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:60 [main]  negotiated protocol: TLSv1.3
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:61 [main]  negotiated cipher suite: TLS_AES_256_GCM_SHA384
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:71 [main]  peer principal: CN=obmgw2.stc.com.sa, O=OpenText, C=CA
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:80 [main]  peer alternative names: [localhost, scprwsmr34, obmgw2.stc.com.sa, smartmonitoring.stc.com.sa]
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory:84 [main]  issuer principal: CN=OBM Certification Authority, O=OpenText, C=CA
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:165 [main] http-outgoing-2 set socket timeout to 3 MINUTES
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator:185 [main] localhost:443 connected null->localhost/127.0.0.1:443 as http-outgoing-2
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:456 [main] ep-0000000013 connected http-outgoing-2
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:164 [main] ep-0000000013 endpoint connected
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000013 executing GET /topaz/TopazSiteServlet?requestType=logout HTTP/1.1
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000013 Cookie spec selected: relaxed
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000013 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/TopazSiteServlet?requestType=logout]
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000013 Cookie [name: LWSSO_COOKIE_KEY; value: oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/TopazSiteServlet?requestType=logout]
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000013 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/TopazSiteServlet?requestType=logout]
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000013 start execution ex-0000000013
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000013 executing exchange ex-0000000013 over http-outgoing-2
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-2 >> GET /topaz/TopazSiteServlet?requestType=logout HTTP/1.1
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Host: localhost:443
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Connection: keep-alive
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "GET /topaz/TopazSiteServlet?requestType=logout HTTP/1.1[\r][\n]"
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Cookie: LWSSO_COOKIE_KEY=oZ8TDs-y-qMGitSuhGJqEik4EmIYlmItXcmhvIxg-qfeXD_5iq5i0GPyTNwATygF4rk2hGZrIDxmPsIbqRGj5xMnGFlCEay9K-lyIH5F1_9xgEzE3_J_cXeffT5_aOXKupouxbdSmQBJAuOjzKBSBx-VE-6yEp5aQ3QUkFW5_qjsNwTQ0QSzYhThPnDhWoisbn70ZRK3JqNOG8ybuGsTcQ..; JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:22,664+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "HTTP/1.1 302 302[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Date: Wed, 27 Nov 2024 14:50:22 GMT[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Upgrade: h2,h2c[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Connection: Upgrade, Keep-Alive[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Cache-Control: no-cache[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Expires: Thu, 01 Jan 1970 00:00:00 GMT[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Pragma: no-cache[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Location: /topaz/login.jsp?Action=error&ErrorID=4&requestType=logout[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Content-Length: 0[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Set-Cookie: LWSSO_COOKIE_KEY=""; Expires=Thu, 01 Jan 1970 00:00:10 GMT; Path=/; Secure; HttpOnly;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Content-Type: text/html;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[\r][\n]"
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-2 << HTTP/1.1 302 302
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Date: Wed, 27 Nov 2024 14:50:22 GMT
    2024-11-27T17:50:22,680+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Server: Apache
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Upgrade: h2,h2c
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Connection: Upgrade, Keep-Alive
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Cache-Control: no-cache
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Expires: Thu, 01 Jan 1970 00:00:00 GMT
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Pragma: no-cache
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Location: /topaz/login.jsp?Action=error&ErrorID=4&requestType=logout
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Content-Length: 0
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Set-Cookie: LWSSO_COOKIE_KEY=""; Expires=Thu, 01 Jan 1970 00:00:10 GMT; Path=/; Secure; HttpOnly;SameSite=none;Secure
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Keep-Alive: timeout=15
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Content-Type: text/html;charset=UTF-8
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000013 Cookie accepted [LWSSO_COOKIE_KEY="", domain:localhost, path:/, expiry:1970-01-01T00:00:10Z]
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000013 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000013 releasing valid endpoint
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000013 releasing endpoint
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000013 connection http-outgoing-2 can be kept alive for 15 SECONDS
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000013 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.RedirectExec:132 [main] ex-0000000013 redirect requested to location 'https://localhost:443/topaz/login.jsp?Action=error&ErrorID=4&requestType=logout'
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.RedirectExec:202 [main] ex-0000000013 redirecting to 'https://localhost:443/topaz/login.jsp?Action=error&ErrorID=4&requestType=logout' via {s}->https://localhost:443
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:181 [main] ex-0000000013 target auth state: UNCHALLENGED
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.ProtocolExec:187 [main] ex-0000000013 proxy auth state: UNCHALLENGED
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.ConnectExec:123 [main] ex-0000000013 acquiring connection with route {s}->https://localhost:443
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:101 [main] ex-0000000013 acquiring endpoint (3 MINUTES)
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:296 [main] ex-0000000013 endpoint lease request (3 MINUTES) [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:318 [main] ex-0000000013 endpoint leased [route: {s}->https://localhost:443][total available: 0; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:360 [main] ex-0000000013 acquired ep-0000000014
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:116 [main] ex-0000000013 acquired endpoint ep-0000000014
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:107 [main] ex-0000000013 executing GET /topaz/login.jsp?Action=error&ErrorID=4&requestType=logout HTTP/1.1
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:129 [main] ex-0000000013 Cookie spec selected: relaxed
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000013 Cookie [name: JSESSIONID; value: E8B64E947D01E8EE061CC4B48DA78FD8; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/login.jsp?Action=error&ErrorID=4&requestType=logout]
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.protocol.RequestAddCookies:166 [main] ex-0000000013 Cookie [name: secureModifyToken; value: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd; domain: localhost; path: /; expiry: null] match [(secure)localhost:443/topaz/login.jsp?Action=error&ErrorID=4&requestType=logout]
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:214 [main] ep-0000000014 start execution ex-0000000013
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:710 [main] ep-0000000014 executing exchange ex-0000000013 over http-outgoing-2
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:200 [main] http-outgoing-2 >> GET /topaz/login.jsp?Action=error&ErrorID=4&requestType=logout HTTP/1.1
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Accept-Encoding: gzip, x-gzip, deflate
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Host: localhost:443
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Connection: keep-alive
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.headers:203 [main] http-outgoing-2 >> Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "GET /topaz/login.jsp?Action=error&ErrorID=4&requestType=logout HTTP/1.1[\r][\n]"
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Accept-Encoding: gzip, x-gzip, deflate[\r][\n]"
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Authorization: Basic YWRtaW46JHRjUEBzc3cwcmQyMDI0[\r][\n]"
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "X-Secure-Modify-Token: 20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Host: localhost:443[\r][\n]"
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Connection: keep-alive[\r][\n]"
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "User-Agent: Apache-HttpClient/5.2.1 (Java/1.8.0_422)[\r][\n]"
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "Cookie: JSESSIONID=E8B64E947D01E8EE061CC4B48DA78FD8; secureModifyToken=20f04015f0e9442c0c54f9e92fa5574de3c7a8dd[\r][\n]"
    2024-11-27T17:50:22,695+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 >> "[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "HTTP/1.1 200 200[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Date: Wed, 27 Nov 2024 14:50:22 GMT[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Server: Apache[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "X-XSS-Protection: 1; mode=block[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "X-Content-Type-Options: nosniff[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "X-Frame-Options: SAMEORIGIN[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Strict-Transport-Security: max-age=31536000; includeSubDomains[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Cache-Control: no-cache[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Expires: Thu, 01 Jan 1970 00:00:00 GMT[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Pragma: no-cache[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Vary: Accept-Encoding[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Content-Encoding: gzip[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Set-Cookie: JSESSIONID=51C5CA1ECB0432DE86D92551C622A343; Path=/; Secure; HttpOnly;SameSite=none;Secure[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Content-Length: 1579[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Keep-Alive: timeout=15[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Connection: Keep-Alive[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "Content-Type: text/html;charset=UTF-8[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[\r][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0x1f][0xffffff8b][0x8][0x0][0x0][0x0][0x0][0x0][0x0][0x3][0xffffffbd]X[0xffffffff]O[0x1b]7[0x14][0xffffffff][0xffffff99][0xfffffffc][0x15][0xffffffde]MZ@[0xffffffe3].[0xffffffc0]:[0xffffffad][0xffffff85][0x4])$a*[0x2]J[0x9]l[0xffffffab]Tir[0xffffffee]|[0xffffff89][0xffffff8b]c[0xffffffdf]l_[0xffffffbe][0xffffffb4][0xffffffe2][0xffffff9f][0xffffffd8][0xffffff9f][0xffffffb4][0xffffffbf]l[0xffffffef][0xffffffd9][0xffffff97]p[0xffffff97][0xffffff90][0xffffffc1][0xffffffda]n[0x15]`[0xffffff9f][0xfffffffd][0xffffffde][0xffffffe7]}[0xffffffb7][0xffffff9f][[0xffffffab]}[0xffffffdd][0x7f][0xffffffcd]o[0xffffffba]o:7[0xffffffef][0xffffffae]zdd[0xffffffc7][0xffffffe2][0xffffffb8][0xffffffd6][0xffffffc4][0xffffff81][0xffffffc4][0xffffff82][0x1a][0xffffffd3][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xffffffe4]04[0xffffffb1][0xffffffca]Xp\#[0xffffffa4]9b4[0xffffffc1][0x9]L[0xffffffc7][0xffffffcc]R`[0xffffffb0]Y[0xffffffc8][0xfffffffe][0xffffffc8][0xfffffff9][0xffffffa4][0x15][0xffffffc4]JZ&mh[0xffffffe7]@M[0xffffff8a][0xffffffaf]V`[0xffffffd9][0xffffffcc]6[0x10][0xfffffff1][0xffffff88][0xffffffc4]#[0xffffffaa][\r][0xffffffb3][0xffffffad][0xffffffdb][0xffffff9b][0xffffffd3][0xfffffff0]eP[0xffffffc6]Y[0xffffffec][0x4][0xffffffb9]MW[0xffffffb6]$[0x1d][0xffffffb3]V@[0xffffffb3]L[0xffffffb0]p[0xffffffac][0x6][0x1c][0xffffff86])[0x1b][0xffffff84][0xffffffb0][0x10][0xffffffc6]4[0xffffffa3][0x3]Q[0x16]6g& [0xffffff8d]g[0xffffffb2][0x1b]Kmn[0xffffffc2][0x1][0xffffffd5]0[0xffffff9d]Wp[0x6][0xffffff82][0xffffffc6]w[0xffffff8f]"M8[0xffffff9b]fJ[0xffffffdb][0x12][0xfffffff1][0xffffff94]'v[0xffffffd4]J[0xffffffd8][0xffffff84][0xffffffc7][0x0][0xffffff8e][0x1f][0xffffffbb][0xffffff84]Kn9[0x15][0xffffffe0];*Xk?[0xffffffda][0xb]6[0xffffffb9][0xffffffed][0xffffffb7][0xfffffff0][0xffffffb6][0x1d]v[0xffffffd4]8[0xffffffa3][0xffffff96]W[0xffffff8d]y[0xffffffdd]k[0xffffffb1]d[0xffffff88][0xffffff9e][0xfffffff7][0xffffffac][0xffffff96][[0xffffffc1][0xffffff8e][0xffffffcf][0xffffffd5][0xffffff90]K[0x12][0xffffff92]7[0x19][0xffffffd3][0xffffffc0][0xffffffa2][0xffffffa4]!'[0xffffff9a][0x3][0x1d][0xffffffb9][0xffffffa0][0xffffff92][0xe][0xffffff99]n6<a[0xffffffc1]%[0xffffffb8][0xffffffbc]#[0xffffff9a][0xffffff89]V`F[0xffffffa0]w[0xffffff9c][[0xffffffc2]AD@F[0xffffff9a][0xffffffa5][0xffffffad][0xffffffe0][0xffffffbb]og[0x7][0xffffffe9][0xffffff91]U[0x19][0xfffffffd][0xffffffe8][0xffffffa7][0xffffffe8][0x15][0x1e]7T[0xffffffa6][0x1b][0xffffff9a][0x19][0xffffff95][0xffffffeb][0xffffff98][0xffffff99]FJ'[0xffffffc8][0x14][0xffffffc1][0xffffff9f][0xffffff80]`[0xffffff80][[0x1][0x1f][0xffffff83][0xffffffb0][0xffffffc6],t`[0xffffffc7]k[0xffffffb2][0xffffffd0][0xffffffa1]f[0xffffffc4][0xffffff98]][0xffffffd0][0xffffffbb]<[0xffffff88][0xffffff8d]y[0xffffff8e]`[0xfffffff8][\r][0x5][0xffffffda][0xffffffd9][0xfffffff0]8[0x11][0xfffffff2]-[0xc]2[0xffffffb1][0xffffffe6][0xffffff99]-[0xffffffa3]~[0xffffffa0][0x13][0xffffffea]W[0xb]E[0x8]:[0xffffffd1]X[0x2]Q[0xffffffee][0xffffffe0][0xffffff84]JkH[0xffffff8b]|*6[0x9]qb[0x7f]e[0xffffff83][0xe][0xfffffffa]zf[0xf][0xffffffc9][0xffffff90][0xffffffd9][0x1b]\+[0x16][0xffffffb6]wv[0xffffff97][0xffffffb4]^[0xffffffaf]2e[0xffffffbf][0xffffffbc]R&[0x5][0xffffffbd][0xffffffcb][0xffffffa0]A[0xfffffff0][0xffffffb0]%[0x14]f[0xffffff82]c?w[0xffffffd3]2[0xffffff9f][0xffffffb3][0xfffffff5][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xfffffffc][0xfffffff9][0xb][0xffffffd5][0x1c]S[0xffffffda][0x1c][0xffffff96][0xffffff94]%[0xffffff84][0xffffff9b]>[0xffffffd3][0x13][0xffffffa6][0xffffffbb]j*[0xf]IJ[0xffffff85]a[0xffffffbb][0xffffff95][0xffffffed][0xffffffae][0x1a]S.![0x1][0x12]j[0xffffff95][0xffffff9e][0x1f][0x12][0xffffffab][0xfffffff3][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xffffff89])[0xfffffff1][0xffffffd7]oFls[0xfffffffa][0x14][0xffffffa4][0x0]J[0xffffffe2]\k[0xffffffc8]D1'[0xffffffb9][0x4][0x17]s[0xffffff81][0xffffffaa]E[0xffffffe4]J0j[0x18][0xffffff88][0xffffff98][0x13]:[0x4][0xffffffb1]DP[0xffffffcb]tT/[0xffffffcb][0xffffff93][0xffffffca][0xffffffab][0xfffffff4][0xffffffa4][0xffffffb4][0xffffffdb][0xffffffeb]s2[0xffffffce]!V\[0xffffffc6]"O[0x0][0x16][0xffffffc8]Os[0x1]B[0xffffffdf][0xffffffe6]T[0xfffffff0][0xffffff94][0xffffffb3][0xffffff84]x,r[0x9][0x15]H[0xffffffb6]O[0xffffffdf]v/w[0x1e][0xffffffb4][0xffffff80]4p<1[0xffffff94][0xffffff90]`[0xfffffff6])Y[0x0]3[0xffffff87][0xffffffa4]&[0x3][0xffffffad][0xffffffa6]`[0xffffffe9]_[0x7f][0x1a]B[0xffffff93][0x4]2[0xffffffdd][0x10]8[0x8]"R[0xffffffb1][0xffffff82][0xffffffe6][0xffffff80],![0xffffffd6][0xe][0xffffffaf]o[0x1][0xffffff97][\r][0xffffffe7][0xffffffa8][0x6][0xffffffd8]u[0xffffffde]m_U[0xffffffa8][0xffffffb1][0xffffffaa][0xffffffaf][0xffffffa1][0xffffffaa][0xffffff99][0xffffffb1][0xffffffed][0x7f]b4[0xffffffa5][0xffffffcf][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xffffff80]K[0xffffff83][0xffffff93][0xffffffdc]Z%[0xffffffdb][0xffffffc2][0xffffffa2][0x8]5$[0xffffffaf][0xffffffe5][0xffffff8a]c[0xffffffcf][0xfffffffa][0xffffffb0][0xffffffb3][0xffffffd9]H[0xffffff8d][0xffffffe7][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xffffffd8]S1[0x13][0x12][0xffffff9e][0xc][0x18]9[0xffffff83]([0xfffffff6]}[0xfffffff9]0[0xffffff89][0xffffffc1]LV[0xffffffa3]v[0xffffffaa]A)[0xffffffc8][0xffffffbe][0xfffffffa][0xffffffbb]2w[0xffffffa2][0x0]O*KL[0xffffff9e][0xffffffe1][0xffffffe1][0x7]^[0xffffff84]Rg$u[0xffffffd4]D[0xffffffad]d[0xb][0x14]_[0xffffffca][0xffffff87][0xffffffb9][0xffffff86][0xffffffc8]![0x13][0xffffffc8]N[0xffffffb8][0xffffffc9][0x4][0xffffff9d]W[0xfffffff9][0xffffffaa][0xffffffb2]sY[0xffffff80][0xffffffb3][0x4][0xffffffd5][0xffffffac][0xffffffd8][0xfffffff8]~v[0xffffffb0][0xffffffe7][0xffffffcd][0xffffffc4]Ya)N[0xffffffc7]t[0xffffff8e][0x3]H[0xffffffc1]![0xffffffcd]e[0xffffff8c][0xfffffff4]8[0xffffffcf]4\ZZ[0xffffffcc]#[0xfffffffc][0xfffffff0]\w[0xffffff8e][0xffffffdb][0xffffff80]^8*[0xffffffe9][0xffffff87][0x14][0xffffffff]B[0xffffffb4][0x1c][0xffffff80][0x12]BM[0xffffffb9][0x1c][0xffffffe2][0x7][0x14][0xffffff81]Y[0x8][0xffffffaf]P[0xffffffa1]z8^[0xffffffe7][0x10][0xffffffe1][0xffffffb1][[0xffffffea][0xffffffc9][0x9][0xffffffd7]J[0xffffff8e][0xffffffc1]~[0xfffffffc][0xffffffe4][0xffffff8e])7,[0xfffffff1][0xffffffa8]NW[0x1a][0xffffffc3]Ij[\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xfffffff0][0x2][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xffffffef][0xffffffa5]"I[0xffffffde][0xffffffcf]~h[0xffffffbf][0xffffff9f][0xffffffed][0xffffffb9][0xffffffdf][0xffffffb3][0xffffffeb][0x1e][0xffffffee][0xffffffee]G/g[0xffffff95][0xffffffcf][0xffffff9f][0xffffffa2][0xffffffbd][0xffffffdf]g[0xffffff9b][0xffffffbc]v[0xffffffe2][0xffffff83]u[0xffffffa9]:J[0xffffffdd]q[0x17][0xffffffc4]gxp[0xffffff91].8[0xffffffc7][0xffffff8c][0xffffffc1][0xffffffb1][0x8][0xffffffbb][0xffffffd3]S-T[0xffffffcf][0xffffff9c]e[0xffffffb1][0xffffffc7]vfi5[0xffffffc6][0xfffffff1][0x19]B[0xfffffffc][0xffffff91][0xffffffb2]9[0xffffffe0][0xffffff85][0xffffffea][0x17]*[0xffffffc1][0xfffffffa]x[0xffffff82][0xffffffea]ke[0xffffff86][0xffffffb3][0xffffff94][0xffffffc5][0x14][0xffffffc2]T[0x18][0xffffffef]L[0xfffffff5][0xffffffd9][0xffffff91]/[0x2]E[0x1d]OI[0xffffff8b]Rj[0xffffffb8][0xffffffcc][0xffffffd0][0x1b][0xffffffa9][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "7[0xffffffba][0xc][0xffffffbc]5[0xffffffcf]K[0xffffffba][0xffffff92][0xffffffeb][0xffffffcb][0xfffffff9][0xfffffff7]oR[0x8][0xffffffdc][0xffffffa0]>r!\[0xffffff8e][0xffffff9e]BlS5[0xffffffc3][0xffffffe9][0xffffffab]}[0xffffff97][0xffffffa9]3h.[0x12][0xffffffaf]`[0xffffffdf]k[0xffffffeb]r[0xffffff99][0xffffffb9][0xffffffe3][0xffffffb4]([0xffffff96][0xffffff97][0xffffffbd][0xfffffffe]5[0xc][0xffffffaf][0xffffffbc]i[0xffffff8e][0xffffff96][0xe][0xffffffd4][0xffffff84][0xffffffed][0xffffffe2][0xffffffec]g[0xffffffa5][0xffffff86][0xffffffc2]QvF[0xffffff90][0x2][0xffffffac]Dt[0xffffffc1]c[0xffffffad][0xffffff8c]J[0x1d]d[0xffffffaf][0x8][0xffffffca][0xffffffab][0xffffffc7]a[0xfffffffa]4[0xffffff85][0xffffffcb][0xffffffce][0xffffffe5][0xfffffff5][0xffffff8f][0xffffffd5][0xffffffc4][0xffffff80][0xffffffa3][0xffffffc1]@[0x18]W[0xffffffee]@B[0xffffff98][0xffffffd6]J_[0xffffff98][0xffffffe1][0xffffffe7][0xffffffdd])[0xffffffdd][0xffffffcb]>[0xffffff9c]cx[0xffffff8f],[0xffffffef][0xe][0xffffffcd][0xffffff96][0xffffffb7][0xffffffc7][0xffffff93][0xffffff97][0x6][0x12][0xffffff95]/[0xffffff8a][0xffffff8a][0xffffffc6][0xffffffc5][0xffffffd1][0xffffff8d][0x7][0xfffffffa][0x5]w[0x1][0xfffffff2]j[0xffffffbe]+[\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xffffffca][0xffffffed]:[0xfffffff3][0xffffffad]ec_ISjJ[0x9]jr[0x17][0xffffffda]4[0x17].][0xffffffae][0xffffff96][0xffffffd1][0xffffff80][0x13][0xffffffc5][0xffffffa7][0xffffffc3]|[0x15][0xb][0xfffffffb][0xffffffd1]U52[0xffffffe8][0xffffffd9][0xffffffa7]J'[0xffffffff][0xffffffb9][0x16][0xb]AQ[0xfffffffd][0xffffffbe]r[0xffffff83][0xffffffd1][0x1][0x13]k[0xffffff81][0xffffff83][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:92 [main] http-outgoing-2 << "[0xffffffd3][0xffffffa8][0xffffffed]9[0xffffffee][0xfffffffa]k[0xffffff8d][0xffffffcb][\r][0xffffff9a]/h[0xffffffae][0xffffff8a][0xffffffef][0x15]|[0xffffffdf]([0xffffffe1][0xfffffff5][0x1][\n]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.wire:106 [main] http-outgoing-2 << "[0xffffffa1][0xffffffa0][0xfffffff5][0xffffffed][0x13]*%[0xffffff9e][0x12]U[0x1d][0xfffffff0][0x5][0xffffffb2]z[0xffffffb6]@[0xffffffe7][0xffffff84]M[0xffffffec][0xffffffad]v;[0xffffffa5][0xffffff8d][0xfffffffb]jwu[0xfffffffe][0x0][0xffffffdb][0xfffffff3][0xffffffd7][0xffffffe6]*RQ[0xffffffab][0xffffffb0]|[0xfffffff0]":[0xffffffa8]W[0xffffffd9];4v[0x8][0xfffffffe]xs[0xffffffdd][0xffffffdb]r[0xffffffff][0xffffffbe][0xffffff98][0xffffffdd][0x1f][0xffffffd5][0xffffffb6][0x8])>[0xffffffca]mk[0xffffffb4][0xffffffde][0x1b]F+^[0xffffff88][0xffffffda][0xffffffee]l[0xffffff83][0x6][0xffffffb7][0xffffffee]J[0xffffffa4]~T[0xfffffffb][0x2][0xffffffb0][0x1e]B[0xffffffbc][0xffffffee]"[0xffffffda][0xffffff8b]/C[0xffffffd2][0xffffffbe][0x17][0xffffffba][0xffffffc1][0x1a][0x3]4[0xffffffd8]V[0xffffffb9]-C.N[0xffffffe5]Gz[0xffffffea]e[0xfffffff4][0xffffffa0]Fs-[0xffffffd7][0xfffffffb]s[0xfffffff2]=6R[0xffffffcb][0x17][0x3][0xffffffc0]zwnUaW[0xffffff98]>[0xffffffd5][0xffffffb6][0xffffffb6][0xffffff96][0xffffff98]uH[0xffffffe4]S[0xfffffff7][0x12][0xffffffc0][0xffffffc9][0x12]aU[0xffffffb3]E[0xffffffbb][0xffffffbe][0xffffffaa]R[0xffffff9d][0xffffffc9][0xffffff8d]<[0xffffffed][0xffffff92][0xffffffab][0xffffffd6]9[0xffffffcf][0xfffffffa]o.#[0xffffffe8][0x2][0xffffffa1]By:[0xffffffdf].[0xfffffffb]u[0xffffffe7]1;[0xffffff94]tA[0xffffffd9][0xffffffde]yHi|[0xffffffdf](h[0xffffffc6][0xffffffc1][0xffffffa9][0xffffffdb]u[0xffffffb7][0xb][0xffffffc9]O[0x13]@$[0xfffffffe]%d[0xffffffea];[0xffffff88][0xffffffe1]Uk6[0xfffffffc]b[0xfffffff1][0xffffff84]r[0xffffffee]o6[0x16][0xffffff8f][0xfffffff9][0xffffffe6]@%[0xffffffd0][0xffffff9a]%[0xffffffad][0x0]<[0xffffffe9]2[0x15][0xffffffd4]w/)[0xffffffff][0xffffffd3][0xffffffc4][0xffffffe7][0xffffff98][0x1c][0xffffffce]B[0xffffffad][0xffffff94]u[0xc][0xffffff8d][0xffffffb5][0xffffff95][0xffffffe2]Qft[0xfffffffc][0xffffffdc][0xffffff97][0xffffff9d][0xfffffff6][0xffffffdd]S[0xfffffff4][0xffffffc1],^[0xffffff88]c[0xffffff95][0xffffffe4][0xfffffff8][0x0][0xffffff86]K[0x12][\r][0x2]u[0x16]v[0x7][0xffffffc7][0xf][0x16]|[0xffffff96]0w[0xffffffec][0xffffffff]/[0xffffff92]2%[0xffffffe6])[0xffffffdc][0xffffffbe][0xffffffe6]3[0xffffffc4]9[0xffffffd7]b0[0xffffff8e]k[0xffffffcd][0xffffff86][0xffffffff][0xffffffbf][0xffffff98]Z[0xffffffed]o[0xffffffb9]byx[0xffffffee][0x11][0x0][0x0]"
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:189 [main] http-outgoing-2 << HTTP/1.1 200 200
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Date: Wed, 27 Nov 2024 14:50:22 GMT
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Server: Apache
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << X-XSS-Protection: 1; mode=block
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << X-Content-Type-Options: nosniff
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << X-Frame-Options: SAMEORIGIN
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; font-src 'self' data:; worker-src 'self' blob:; img-src 'self' data: bvd.stc.com.sa; frame-src 'self' blob: bvd.stc.com.sa; frame-ancestors 'self' bvd.stc.com.sa;
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Strict-Transport-Security: max-age=31536000; includeSubDomains
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Cache-Control: no-cache
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Expires: Thu, 01 Jan 1970 00:00:00 GMT
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Pragma: no-cache
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Vary: Accept-Encoding
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Content-Encoding: gzip
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Set-Cookie: JSESSIONID=51C5CA1ECB0432DE86D92551C622A343; Path=/; Secure; HttpOnly;SameSite=none;Secure
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Content-Length: 1579
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Keep-Alive: timeout=15
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Connection: Keep-Alive
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.headers:192 [main] http-outgoing-2 << Content-Type: text/html;charset=UTF-8
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.protocol.ResponseProcessCookies:127 [main] ex-0000000013 Cookie accepted [JSESSIONID="51C5CA1ECB0432DE86D92551C622A343", domain:localhost, path:/, expiry:null]
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.impl.classic.MainClientExec:138 [main] ex-0000000013 connection can be kept alive for 15 SECONDS
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.impl.classic.InternalHttpClient:256 [main] ep-0000000014 releasing valid endpoint
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:389 [main] ep-0000000014 releasing endpoint
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:408 [main] ep-0000000014 connection http-outgoing-2 can be kept alive for 15 SECONDS
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:421 [main] ep-0000000014 connection released [route: {s}->https://localhost:443][total available: 1; route allocated: 1 of 5; total allocated: 1 of 25]
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:247 [main] Shutdown connection pool GRACEFUL
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.impl.io.DefaultManagedHttpClientConnection:174 [main] http-outgoing-2 close connection GRACEFUL
    2024-11-27T17:50:22,711+03 DEBUG org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager:250 [main] Connection pool shut down
    2024-11-27T17:50:22,727+03 ERROR com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow:292 [main] Integration failed: java.lang.Exception: client error occurred - URI: https://localhost:443/opr-web/admin/rest/connectedServer - check log file for details.
    	at com.microfocus.opsbridge.aiops.obmconfigurator.obmclient.ClientErrorResponse.mustBeSuccess(Response.kt:58)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.data.ConnectedServerServiceImpl.create(ConnectedServerServiceImpl.kt:121)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.ContentPackForwardingConfigurator.run(ContentPackConfigurator.kt:58)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow$forwardingContentPackConfigured$2$1.invoke(BasicFlow.kt:229)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow$forwardingContentPackConfigured$2$1.invoke(BasicFlow.kt:211)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow.run(BasicFlow.kt:84)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow$forwardingContentPackConfigured$2.invoke(BasicFlow.kt:211)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow$forwardingContentPackConfigured$2.invoke(BasicFlow.kt:208)
    	at kotlin.SynchronizedLazyImpl.getValue(LazyJVM.kt:74)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow.getForwardingContentPackConfigured(BasicFlow.kt:208)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.BasicFlow.run(BasicFlow.kt:270)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.Runner.run(Runner.kt:20)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.MainKt$main$command$1.invoke(main.kt:9)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.ArgParser.run(ArgParser.kt:198)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.ArgParser.call(ArgParser.kt:202)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.ArgParser.call(ArgParser.kt:47)
    	at picocli.CommandLine.executeUserObject(CommandLine.java:1953)
    	at picocli.CommandLine.access$1300(CommandLine.java:145)
    	at picocli.CommandLine$RunLast.executeUserObjectOfLastSubcommandWithSameParent(CommandLine.java:2352)
    	at picocli.CommandLine$RunLast.handle(CommandLine.java:2346)
    	at picocli.CommandLine$RunLast.handle(CommandLine.java:2311)
    	at picocli.CommandLine$AbstractParseResultHandler.execute(CommandLine.java:2179)
    	at picocli.CommandLine.execute(CommandLine.java:2078)
    	at com.microfocus.opsbridge.aiops.obmconfigurator.MainKt.main(main.kt:13)
    log.txtok pls find the log
  • Suggested Answer
    0 in reply to
    I think due to previous try connected server already exist or the same FQDN is used for another connected server. Try removing it manually if not used for any other purpose.
