I face issue after reinstalling vertica because the customer asked to make some changes in the file system on vertica servers so i made uninstall and they made the changes and i installed again but when i arrive to step of putting password for dbadmin, ro_user and rw_user using dbinit script, I face this issue ```
/usr/local/itom-di-pulsarudx/bin/dbinit.sh
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: VERTICA_HOME=/opt/vertica
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: VERTICA_PORT=5433
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: VERTICA_DBA=dbadmin
2024/11/16 11:38:57 environmentLoader.go:37: info GetEnv: VERTICA_DBA_PASS=******
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: VERTICA_DB=itomdb
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: VERTICA_DBA_HOME=
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: VERTICA_RW_USER=vertica_rwuser
2024/11/16 11:38:57 environmentLoader.go:37: info GetEnv: VERTICA_RW_PASSWD=******
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: VERTICA_RO_USER=vertica_rouser
2024/11/16 11:38:57 environmentLoader.go:37: info GetEnv: VERTICA_RO_PASSWD=******
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: TENANT=provider
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: DEPLOYMENT=default
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: MEMORY_SIZE=10%
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: CONCURRENCY=4
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: QUEUE_TIMEOUT=0
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: EXPRESS_LOAD_CONF_PATH=/conf
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: EXPRESS_LOAD_MEMORY_SIZE=5%
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: EXPRESS_LOAD_MAX_MEMORY_SIZE=20%
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: EXPRESS_LOAD_CONCURRENCY=16
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: EXPRESS_LOAD_EXECUTION_PARALLELISM=8
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: EXPRESS_LOAD_QUEUE_TIMEOUT=0
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: CLUSTER_K8S_PROVIDER=
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: CONFIG_STORE_SCHEMA=
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: DBINIT_CONF_FILE=
2024/11/16 11:38:57 environmentLoader.go:39: info GetEnv: VERTICA_VERSION_CONSTRAINT=>= 11.1, <= 24.3.0
Enter the password for User 'dbadmin':
2024/11/16 11:39:09 passwords.go:84: info dbinit: Using the new password for user dbadmin
Nov 16 11:39:09.178167 ERROR driver: FATAL 2248: [28000] Authentication failed for username "dbadmin"
So anyone faced this issue before with knowing that the first installation``, i didn't face this issue and script worked normally
