Predefined query for Flex Reporting does not show parameter input list for node group
We have defined a new query based on the UIF query for availibility summary for NOM component health. The query contains the variable uifnodegroup, but when I use the query for a graph Widget in a new or copied Flex Reporting dashboard the parameter list to select a node group is not there or has no effect.
Any idea what I missed or if this does not work in general?
Best regards
Allessandro
Allessandro Soloperto
ITC GmbH - Senior Consultant
If this answered your question, please mark it as "Suggest as Answer" or "Verify as Answer".
If you found this response useful, please give it a "Like".
    Hello all,
    finally the parameter ist (here Node Group selection) is shown, but has no affect on the widget. Perhaps someone has an idea about what is wrong in this query in regards to the node group parameter:
    SELECT count (distinct nodeuuid) AS NumberOfNodes,
      ts AS Date,
      AVG(Avail) AS avgMaxAvailability,
      AVG(Reach) AS avgMaxReachability
    FROM (
                                  SELECT DISTINCT node_unique_id AS nodeuuid
                                                ,nodename
                                                ,ts
                                                ,round(avg(availUtil), 2) Avail
                                                ,round(avg(reachUtil), 2) Reach
                                  FROM (
                                                SELECT chmet.node_unique_id,
                                                               chmet.node_name AS nodename,
                                                               chmet.timestamp_tz AS ts,
                                                               date_part('epoch', ${${nomcalendar:start}}::timestamp)::INT startdate,
                                                               date_part('epoch', ${${nomcalendar:end}}::timestamp)::INT enddate,
                                                               node_availability_max_pct availUtil,
                                                               node_reachability_max_pct reachUtil
                                                FROM nom_component_health_1h chmet
                                                WHERE timestamp_utc_s >= startdate AND timestamp_utc_s < enddate
                                                               AND (
        ${ 'ALL' = ${ uifnodegroup}}
        OR chmet.node_unique_id IN (
        SELECT DISTINCT ngroup.node_unique_id
        FROM nom_node_group_relation ngroup
        SELECT max(collection_timestamp_s) ngmaxtime
        ,node_unique_id
        GROUP BY node_unique_id
        ) ngmax
        WHERE ngmax.ngmaxtime = ngroup.collection_timestamp_s
        AND ngmax.node_unique_id = ngroup.node_unique_id
        AND ${ ngroup.node_group_name IN (${ uifnodegroup}) }
                                                ) memutil
                                  GROUP BY node_unique_id, nodename, ts
                                  ) Avail
    GROUP BY ts
    ORDER BY ts desc
    Thanks and best regards
    Allessandro
  • Verified Answer
    +1   in reply to
    Hello all,
    finally the error was found:
    the spaces in the variables are not correct. If they are removed, the query works:
    (${ 'ALL' = ${ uifnodegroup}} must be
    (${ 'ALL' = ${uifnodegroup}} and
    AND ${ ngroup.node_group_name IN (${ uifnodegroup}) } must be
    AND ${ngroup.node_group_name IN (${uifnodegroup}) }
    This query enables the customer to show the availability and reachability over time.
    Thanks to OT support.
    Best regards
    Allessandro
