Hello!
I noticed that running Purge Execution Summary always returns 0 result.
I'm sure a patch will be released soon regarding this issue, however any work around that you suggest to make the API work?
Thanks in advance.
Regards,
ART
Cybersecurity
DevOps Cloud
IT Operations Cloud
Hello!
Thanks in advance.
Regards,
ART
Hi Art,
I could not find any workaround suggested by OO R&D. Please open a support ticket asking for a suggestion from R&D regarding this issue.
Thank you.
Sam Liu
OO support
