How to create a REST flow with OAuth2 in OO?
I am unsure on how to create a REST flow with OAuth2 in OO, as the HTTP operations don't seem to have the proper input variables that I need for this.
For OAuth2, I e.g. have the following variables:
  • Ressource Owner Name
  • Ressource Owner Password
  • Client Identification
  • Client Secret
  • Access Token URI
In which operation and in which input-variables would I put all those variables in, so that OO can make a proper REST call using OAuth2?
Is there a sample flow for this somewhere in OO?
I have tried to use the sample flow "Get Auth Token" in Library->Integrations->Micro Focus ->Cloud OS, but I couldn't get it to work.
Any help would be greatly appreciated Slight smile
Tags:
Labels:
RPA
  • Suggested Answer
    Could you try to send a POST REST request to the specified URL with the following body:
    grant_type=client_credentials&client_id=${LV_clientId}&client_secret=${LV_secret}
    I also had to put following in the header, but I am not sure if this is the end point specific:
    cache-control: no-cache, max-age=0
    pragma: no-cache
    accept: application/json
    Leave authType empty.
    As a result you should get a token.
    Good luck
    Unfortunately it did not work, but you have still helped me in showing me as to what variables I have to use for this to work:
    By using just the URL, header and body variables in the HTTP-operations, it should indeed be possible to create a REST flow with OAuth2. I'll see if I can get it to work this way Slight smile
  • 0   in reply to
    Add your credentials in the body to authenticate
    grant_type=password&client_id=${client_id}&client_secret=${client_secret}&username=${admin}&password=${password}
    For me to Snow right Content-Type was application/x-www-form-urlencoded dont know if this is a more general setting.
    Although I am an OpenText employee, I am speaking for myself and not for OpenText.
  • Verified Answer
    +1
    thank you all for your help Slight smile
    It wasn't the complete solution, but you showed me the right direction
    I managed to do it now with the following setup:
    I used the Operation from Base/Library/Operations/HTTP Client/v2.0/Http Client Post
    and then filled out the variables as follows (additional notes are in braces like this sentence):
    url = url for getting the oauth token
    authType = Basic
    username = Client Identification (this username will then be used for the Basic encoding as set by the authType)
    password = Client Secret (this password will then be used for the Basic encoding as set by the authType)
    preemtiveAuth = true (for testing purposes, to ensure the call goes through)
    trustAllRoots = true (again for testing purposes, to ensure the call goes through)
    x509HostnameVerifier = allow_all (again for testing purposes, to ensure the call goes through)
    headers = (nothing, leave this variable empty)
    responseCharacterSet = UTF-8 (this is by default some ISO-8859 and will most likely not work like this, so setting this to UTF-8 is really important!)
    body = grant_type=password&username=${ressource-owner-username}&password=${ressource-owner-password}    (here the "Ressource Owner Name" and the "Ressource Owner Password" are used as a variable within the entry for the body)
    contentType = application/x-www-form-urlencoded
    requestCharacterSet = UTF-8 (again, any other encoding will likely not work)
    method = POST
