Error when running with PowerShell V3
Hello all,
May I know if you have experience the similar issue as me.
When running in the HPOO, we always got the error as following.
However, the credential was passed, the EXO powershell has already connected as well.  and this issue is randomly occurred.
May I know if you have any idea on this?
System.Management.Automation.MethodInvocationException: Exception calling "GetCurrentConnectionContext" with "1" argument(s): "You must call Connect-ExchangeOnline before calling any other cmdlet." ---> System.Exception: You must call Connect-ExchangeOnline before calling any other cmdlet.
   at Microsoft.Exchange.Management.ExoPowershellSnapin.ConnectionContextFactory.GetCurrentConnectionContext(String connectionContextObjectId)
   at CallSite.Target(Closure , CallSite , Type , Object )
   --- End of inner exception stack trace ---
   at System.Management.Automation.ExceptionHandlingOps.ConvertToMethodInvocationException(Exception exception, Type typeToThrow, String methodName, Int32 numArgs, MemberInfo memberInfo)
   at System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
   at System.Management.Automation.Interpreter.DynamicInstruction`3.Run(InterpretedFrame frame)
   at System.Management.Automation.Interpreter.EnterTryCatchFinallyInstruction.Run(InterpretedFrame frame)
   at PowerShellV2.PSRunspaceV2.RunCommand[T](PSCommand command)
   at PowerShellV2.PSRunspaceV2.RunCommand(PSCommand command)
   at PowerShellV2.PSRunspaceV2.RunScript(String scriptText)
   at dotNETWebActions_PowerShell.IActions.PowerShellBaseAction.ExecutePowerShell(ActionRequest req, ISession s, IActionRegistry reg);returnCode=1;stdout=
Labels:
RPA
  • Verified Answer
    +1
    Hi Helen,
    I have not seen the same issue and have not found other customers reporting the same issue.
    Please open a support ticket and we will help you with a solution.
    Thank you.
    Sam Liu
    Customer care engineer
