NNMtrimincident for a specific device
HI Experts,
I want to run the nnmtrimincidents for a specifc devices please do let me know the command as checked from the help it is
nnmtrimincidents.ovpl -date <> -family Node -lifecycle Closed
Here i need to give specific device.
Thanks and Regards
Vinay S Kadival
Parents
  • Verified Answer
    +1
    Hello Vinay,
    Unfortunately, such option is not available for this CLI. You can try NNMi UI. Go to Incident Browsing, All Incidents, filter specific node on the column Source Node and Closed state on Lifecycle State,  select Max 100 incidents (limitation) and delete them. Additionally, and if needed you can also filter on Last Occurance Time column. This should be feasible unless there are thousands of incidents to delete.
    Best regards,
    Sergey
Reply
  • Verified Answer
    +1
    Hello Vinay,
    Best regards,
    Sergey
Children
No Data
