Greetings.
I've been playing with SA, DMA and CSA in a lab environment as a self study endeavor.
So far SA and DMA are working fine, I'm using a self signed certificate on my DMA server and my deployments work but haven't been able to integrate CSA and DMA.
In an attempt to facilitate de integration CSA - DMA I configured DMA to not use SSL and to listen on port 9090. With this configuration the CSA - DMA integration works but my CSA deployments die miserably with the followin errors:
Error from remote (3056): Handler pre-check failed
The West APX execution was not successful
Is there something specific I must to in order to run DMA without using SSL other than configure the server ? Is this possible ?
