Push data and it's relationship using connect-it
Dears
i create a query that include node and person and group, then i create a scenario to push data from csv file to ucmdb including the person attribue and group and nodes
the person and group are created sucesfully but the relationship between person/group is not created
Any suggestion ?
thank you
Parents
  • Suggested Answer
    1 - Create the records separately, then have another mapping to sync them together, OR
    2 - Use "Follow Link" under reconciliation sub-tab of mapping.
Reply
  • Suggested Answer
Children
No Data
