send attachment from SMAX to another system using integration engine
Hello Dears,
i have a use case to integrate SMAX to another System using REST API, integration will include exchange requests based on condition
i was able to do a lot of stuff using integration engine, however i can't find a way to send the attachment to the endpoint of the other REST system.
 Is There a business rule/method allowing to extract attachments?
Parents
  • Suggested Answer
    As long the target system attachment endpoint supports content-type "multipart/form" you can use Integration Engine to exchange attachments with the target system.
    See Jira integration template with examples how to send attachments to a target system.
Reply
  • Suggested Answer
Children
No Data
