massstorage device control don't work with client 11.4.1
Hello,
we have update our ZCM from 11.3 to 11.4.1 - when i update the Client Agent on the Workstation, our massstorage device control policy don't work!
I have a policy that disable all storage devices ( USB,DVD,floppy etc) for all Users, then i have a second Policy who allows USB massstorage device for some users. With the Client agent 11.3.1 this work with no problem - with the client agent 11.4.1 USB massstorage device are for all disable. Where is the problem !?
Perhaps you have another solution for make a policy where at first all storage devices ( USB,DVD,floppy etc) for all User are disable, but for only some exclude User there can use it.
A solution with --> Policy A "storage devices Disable" for User "1,3,5,6....34"
and a --> Policy B "storage devices allow" for user "2,4" is not the solution, that i want.
Parents
    frankscharpenack;2416621 wrote:
    Hello,
    Have you tried assigning Policy A to your devices and Policy B only to the users that are allowed to access storage devices?
    Thomas
Reply
    Hello,
    Thomas
Children
    thx, for this note!
    I have now:
    Policy A - disable all --> for all Devices --> This Device Policy is not stronger then a user Policy !
    Policy B - allowed to access--> for simply User
    It works!
    But i have some devices where are "allowed to access" - it is not user defined! I put into Policy A to the Requirement, that the workstation x,y,z not include!
    It works for me fine - thank you :)
