ZESService failed to disable USB Mass Storage Device while AV Scan is running
We noticed that the "ZESService" is not able to deactivate a USB mass storage device when an antivirus solution is scanning it.
ZES Agent Version 20.1.0.299
AV Solution: ESET Endpoint Antivirus Version 7.2.2055.0
After the scanning is finshed the devices will be disabled.
The security risk is available if the USB mass storage device contains very many files.
The device is thus accessible.
Is there a solution that ZES gets access to the device before the antivirus solution?
best regards
Andre
(The full log is available - if someone need it)
Parents
    Supposedly, the 2nd time a USB Device is inserted, it can be fully identified w/o the drive fully initializing.  The initial insert for a usb device requires more initialization to get sufficient details used to determine if it should or should not be blocked.
    Clearly, ESET wants to grab the device and scan it w/o delay so it can ensure it is safe so it will be locking the files as fast as it programmatically can do so.  ZESM will be trying to do the same thing on the initial insert of the usb device on a given machine.  I'm not sure ZESM will always be able to win.  I know if there are open locks Windows will not allow the device to be disabled and most certainly ESET has protections against its processes locking the files from being terminated.
     I'm not sure if ESET has a setting to delay the scanning of an inserted device, which may help.  I'm not sure that is a setting they would want and even in your setup, that could open a hole on USB devices that are allowed.
    How are you trying to limit the use of USB devices with ZESM?  Trying to block end-users from ALL Thumbdrives?  Permit Certain ones?  etc....
    Depending on your goal, I may be able to think of some workarounds.
Reply
Children
    USB devices are generally permitted in the ZESM policy.
    The default device access is "Disabled".
    Device Group Access Settings:
    - HID: Enabled
    - Mass Storage Class: Disabled
    - Printing Class: Enabled
    - Scanning/Imaging (PTP): Enabled
    And a list of 60 devices enabled.
    best regards
    Andre
