Problem with ESM MC Standalone
Hello,
I want to test ZESM.
First I tried to install it with eDirectory as directory-service, with win2003-server and MSSQL 2008 - failed because of many SQL-errors on directory configuration in ZESM management console.
Now because I just want to test ZESM I installed standalone version of ZESM management console with SQL-express 2008 (supported for standalone) on Win2003-Srv.
Management console installation and open works fine - but if I want to create a policy I get a "unrecoverable error" an mc close.
In windows event viewer I could find these errors:
1) Exception Information
Exception Type: Senforce.PolicyEditor.Bll.FatalErrorException
Message: No default policy in policy table. One is required.
Data: System.Collections.ListDictionaryInternal
TargetSite: Void btnRunImport_Click(System.Object, System.EventArgs)
HelpLink: NULL
Source: PolicyEditor
What could I do now?
Thanks for help,
Michael
Parents
    OK - Standalone doesn't work at all.
    So I installed a Win2003Srv (Standard inkl. SP2) and a SLES10Sp3 with OES2 sp2a for testing.
    On Win2003 I also installed MSSQL2008 and SingleServer installation procedure.
    Installation of ZESM management console works also fine - BUT:
    On configuration of directory service there I can't select my context - it only shows my tree name and no further context! But I need context to login to edirectory.
    What I checked until now: no Firewall active, OES has SLP DA, Client Login works, write manually in context doesn't work, Servers could communicate in both ways, login on iManager works.
    If more details are needed I could post them.
    Perhaps anybody could help.
    Michael
    Michael
    The Console will ask you for the LDAP host and port (usualy 389 for NON SSL)
    NDS Partitions
    Contexts for User Accounts
    Contexts for syncronization
    It should then go off and search your NDS tree and populate the console with all your users, you can then assign polices to them.
    I would check what user account you are using to connect to LDAP, I am using an admin equiv. By default if you use Anonymous binds to LDAP you only see restricted attributes, using an admin equiv. might do the trick, as you may not be seeing all of your NDS partitions.
    Simon.
    Hello Simon,
    I am using admin account for LDAP connection - do I have to create a new one with equiv. rights???
    Exactly thats my problem - it doesn't search my NDS tree.
    If I enter my context manually on Console configuration screen I could generate 2 errors:
    "The authentication attempt failed: Object reference not set to an instance of an object" and "username admin invalid".
    For my first failure I found something in forum
    But I don't know how to get this dll from Novell.
    Thanks for help,
    Michael
    sulatna;2045791 wrote:
    Hello Simon,
    Thanks for help,
    Michael
    Michael,
    On the credentials screen, you must use LDAP syntax:
    So if your admin user is at the root of your tree it would be cn=admin,o=treename (it is a comma sepperating the two)
    If you change the password on your admin account regularly I would reccomend creating another equiv. user and exempt that user from password changes. (Use a strong password though)
    Let me know how you get on.
    Simon.
    Hello again,
    it's late - but I want to thank you - with LDAP Syntax it worked.
    Michael
Reply Children
No Data
