Performance difference SOAP with and w/o SSL
Has anyone compared the same archive job with and w/o SOAP over SSL? What is your experience?
I realized a big slowness archiving with SSL in two environments. 20 to 50 times slower. In my opinion, 50-100% slower can be acceptable.
Support  confirmed it in their lab.
Here are couple of examples. Just using the same Profile (All Items in Mailbox) and switch SSL on or off.
  • 0   in reply to
    Unfortunately I did not really monitor - this test environment is small and does not deliver usable values. My approach was more or less just a trial to find out how easy and fast it is to follow this new idea.
    (my test environment is good old Utopia - I think you remember Utopia .. Wink)
  • 0   in reply to
    in my case ( multiple customers) changing from HTTP to SOAP had zero influence on the archiving speed. Is this setting still valid, because in attachment.properties file is information, that HTTP is STRONGLY recommended. Thinking
    David
    Hi Diethmar,
    I try to test your approach, but I could not start the second POA.
    I created a second POA at the postoffice and maintained the POA-name in both POA-config-files.
    Then I add the second POA to gwha.conf, but there I don't really find the right syntax.
    Put the second POA in the section of the PO or add a complete new section?
    [po_emg.do_emg]
    server=/opt/novell/groupwise/agents/bin/gwpoa
    command=/etc/init.d/grpwise
    startup=/gw/PO_EMG/po_emg.poa
    delay=2
    wait=60
    startup=/gw/PO_EMG/po_emg.poa2
    delay=2
    wait=60
    When I try to start the second POA with:
    /opt/novell/groupwise/agents/bin/gwpoa @/gw/PO_EMG/po_emg.poa2
    I got
    /opt/novell/groupwise/agents/bin/gwpoa: error while loading shared libraries: libpoa.so: cannot open shared object file: No such file or directory
    Any hints for me?
    gw24.1.0-144620-3446
