Performance difference SOAP with and w/o SSL
Has anyone compared the same archive job with and w/o SOAP over SSL? What is your experience?
I realized a big slowness archiving with SSL in two environments. 20 to 50 times slower. In my opinion, 50-100% slower can be acceptable.
Support  confirmed it in their lab.
Here are couple of examples. Just using the same Profile (All Items in Mailbox) and switch SSL on or off.
Parents Reply Children
  • 0   in reply to
    Unfortunately I did not really monitor - this test environment is small and does not deliver usable values. My approach was more or less just a trial to find out how easy and fast it is to follow this new idea.
    (my test environment is good old Utopia - I think you remember Utopia .. Wink)
