iprint and imanager screwy after nw65sp7
After installing nw65sp7, when I go to imanager on the netware server to
manage iprint, I get two entries for most choices. This is what is under
the iprint roles
Parents
    You somehow have the options for both the NetWare and the Linux iPrint
    plugins mixed.
    Are you using RBS? If yes, make sure you update your collections. Also, if
    you don't have any OES(2)/Linux server, then simply remove the
    iPrint/Linux plugin from your iManager installation.
    Marcel Cox (Sysop)
    Discover the new Novell forums at http://forums.novell.com
    Why doesn't the iimanager for windows on my xp workstation have the stuff
    for netware?
    >>> On 2/4/2008 at 2:09 PM, in message
    <vpJpj.29140$k06.7783@kovat.provo.novell.com>, Marcel
    > plugins mixed.
    > if
    >for netware?
    Because you didn't install it?
    Marcel Cox (Sysop)
    Like I said in my other post, I installed ALL the plugins when I install
    iManager 2.7 on my xp workstation.
    I just uninstalled the linux iPrint plugin.
    But there are no regular iprint plugins.
    when I click on "
    Some of the roles and tasks are not available."
    I see.
    Client Configuration iPrint Management No pages run in the current
    environment or support the current device.
    Manage Broker iPrint Management No pages run in the current environment or
    Manage Printer iPrint Management No pages run in the current environment or
    Manage Print Service Manager iPrint Management No pages run in the current
    RPM Configuration iPrint Management No pages run in the current environment
    I don't see any plugins related to the above stuff on the available plugins
    page.
    Any idea how I can fix this?
    >>> On 2/4/2008 at 3:53 PM, in message
    <lXKpj.29201$k06.28266@kovat.provo.novell.com>, Marcel
    >>for netware?
Reply
    when I click on "
    I see.
    page.
    >>for netware?
Children
