PO Client settings, security tab.
There is a checkbox labeled "Use NAM Authentication for GroupWise Web"
I cannot find documentation for what it does, and how it works.
Can someone enlighten me?
Cybersecurity
DevOps Cloud
IT Operations Cloud
Does this one help? www.youtube.com/watch
Use "Verified Answers" if your problem/issue has been solved!
Nevertheless you're right. It is not easy to find hints how to use NAM and GroupWise web client. Yes, there are some documents and videos how to use advanced authentication access for GroupWise
I have found a good description how to use NAM and Filr. I assume it is not far away how it works with GroupWise web.
Hi Diethmar,
Thanks for your responses.
I am afrid the video did not help much.
You mention that you have found a good description on how to use NAM with Filr, that could potentially be of some usem are you able to share details about it (a link, the doc, anything)?
I still wonder where "Use NAM Authentication for Groupwise Web" is documented
As far as I know, the possibility of having SSO between NAM and GroupWise Web is on the product roadmap, but it is not yet supported. Or rather, there is no way to achieve this integration. It's a shame that we have been waiting for this basic functionality for so long.
Maybe I'm wrong and it can already be done. If so, I'll be very happy with it.
We are still working on adding this, this is an option that should not have been available yet as the rest of the configuration needed is not yet activated.
Expect more in the next ( few ) releases as im not able to give an exact ETA for this to be in the product.
This is not yet implemented in the product, On the Roadmap it looks like it is due first half of next year.
