Filr not showing netfolders to users
Hello,
I have setup a filr appliance with netfolders, but netfolders can be seen only from an administrator account in filr.
I have checked user FS rights and they work like supposed, because when I connect to CIFS server I can see and edit all files/folders like here:
Netfolder server is setup as OpenText OES with NMAS Authentication type:
After that I have setup "Net Folder" Deponija like this:
Because I could not see this netfolder in filr I added netfolder right also directly to the user which is supposed to see this folder, but still its not working right.
I can not see an icon for netfolders also on this account:
On admin account I have check API call that is being called when loading screen and found out, that API "library_children" is called. Admin account gets information about this netfolder in API object with binder id 103:
While on API response while called from user account this object is empty:
I would appreciate any kind of help.
With kind regards,
Sebastian Novak
