I am running my test on Jenkins slave machine which is connected via Jenkins agent as service.
UFT developer runtime engine is not getting enabled on the slave machine when I trigger build from Jenkins server but when I run directly in Jenkins slave the runtime engine gets started.
I even tried executing leanft.bat file to get engine started via putting it as part of Execute Batch command in Jenkins but sill its not getting started in slave whereas if I directly run the bat file in slave it works fine.
Is there something wrong I am doing.
