stcmd CLI help with set and Checkout of Code
I am very new to Starteam and I am trying to use the CLI from the Starteam SDK version 17.
I can easily use stcmd to connect to the server via the standard command.
stcmd connect "JMARSH:PPASSWORD@ADDRESS:PORT
This works no problem. I can also use the set project command as such
stcmd set project = 'DEVINSPROJECT'
But after those are successful and I try and set view or use CO I get an error.
So this command: stcmd set view = "DEVINSVIEW"
I get this error: Illegal command set view = DEVINSVIEW. The project name cannot be resolved to a project on this server. Same with Folder hierarchy.
What I want to be able to do is select a view and folder and check out the code from that level out to a directed folder using -rp command.
So I can connect and do some stuff but the key elements don't. Anything thoughts?
-Devin
