I'm trying to trigger a deployment through a Turnover, but the turnovers doesn't seem to do much. It's only transitioned to the "Deploying.." state and no more.- The turnover has only one automation task - This task automation task is related to a SRA Process that works correctly when I try this directly from the SRA interface.Any idea of what should I check now?thanks!
