Customer is on PPM24.1 and busy wih upgrading to PPM25.1 in OpenText SaaS.
The customer was using MSP (Microsoft Project) with there previous solution and with adopting PPM and using the PPM Work Plan they require a percentage variance in percentage on task slippage.
Our investigation indicate that it's a custom field in MSP but we might be wrong.
Is there a way to add that type of column in PPM Work Plan as a User Data field?
What else would you suggest? (Maybe a Project Overview layout portlet to provide the information)
Regards,
Alfred Puth
iOCO: Senior PPM Consultant
