Issues Recording and Replaying Scripts in LoadRunner with D365 Finance and Operations
Hi All,
I am currently working on recording scripts in LoadRunner for Dynamics 365 Finance and Operations (D365 F&O). However, I am facing some issues both during the recording phase and when replaying the script. I have searched multiple blogs and forums, but I haven’t found much information specific to D365 F&O and LoadRunner integration.
Key Details:
  1. I am using LoadRunner [version] with D365 F&O.
  2. I have followed standard procedures for script recording but encountered errors.
  3. Replaying the recorded script throws errors, and the transactions do not proceed as expected.
I have attached a few screenshots of the errors I am getting during the replay.
Steps I’ve Tried:
  • Checked the LoadRunner recording settings and adjusted protocols.
  • Searched for solutions on Google and blogs but found limited information specific to D365 F&O.
  • Has anyone successfully integrated LoadRunner with D365 F&O for performance testing?
  • Are there specific configurations, protocols, or extensions required to make LoadRunner work seamlessly with D365 F&O?
I would greatly appreciate any guidance, resources, or tips that could help resolve this issue.
Vikash Jain
  • Suggested Answer
    Hi Vikas,
    This is scripting and correlation issue where there may be dynamic IDs/cookies etc that may be involved which would result in these type of failures. Often cases, script record/replay is a bit tricky and the dynamic data still needs to be handled for accuracy. Also it may not be specific to any application (like D365 in this case)
    If you are still running into this issue, your best bet would be to open a new support ticket, attach the full extended log replay of the zipped script folder and reach out to us so we can address it. These type of issues need deeper troubleshooting due to which they fall outside the scope of this forum and may need to be worked through support
    Pls confirm if this answers your question
    Opentext Support
