Move Defect - Synchronize bidirectional two Jira-Projects in one ALM-Project without Defect duplication
Hi There,
I have two agile teams (ADA & MR) working with their own Jira product projects (V8.20.x) where they do their agile stuff, like sprint planing and so on. For each of the projects I have a board and a connection in MF Connect (V4.4.2).
In ALM (V15.0.1) I have one instance for the frontend with tests. When the tester creates a defect he assignes it to a soluton team.
I've gone so far, that I create a connection with the two target boards and two Type Rules for each solution team. The defect is synchronized fine, created in the corresponding jira project, with ALM-ID, ...
When a bug is created it'l be synchronized to ALM with some calculated values like solution team, Jira-ID and so on. The defect handling runs in jira through the solution teams
But sometimes the tester is wrong and the bug is moved in Jira from one project into the other.
Then the fun begins:
The bug is newly created in ALM with its new Jira-Id and the "old" one in ALM stays in zombi mode.
How can i prevent that?
Is it meaningful to use only one board with bugs from both projects?
I'd be very happy for any hints.
Thanks
Pascal
  • Verified Answer
    +1
    MF Connect doesn't support Move. So, this isn;t a Move 'Defect'. (though I'd agree that it is a poor design)
    >>The bug is newly created in ALM with its new Jira-Id and the "old" one in ALM stays in zombi mode. How can i prevent that?
    There is a way to work around this, but it involves manual intervention.
    If a user decides to move a bug across jira projects, they first notify you.
    At this, you
    a) stop the connection.
    b) have the jira user move the bug across projects in jira (this produces a new jira key)
    c) export the cross references for the connection.
    d)   remove the 'old' cross-reference pair (see the 'removes' syntax) {old jira issue key, existing alm/qc defect id}
    e) add the 'new' cross-reference pair (see the 'adds' syntax) {new jira issue key, existing alm/qc defect id}
    Manage cross references (microfocus.com)
    no, we absolutely discourage that anyhow...
    Prepare Jira for synchronization (microfocus.com)
    a)  mixing projects across a joint board introduces it's own set of problems.
    b) even if you could get it to work, it wouldn't tackle the underlying cross reference issue, the new alm/qc defect would still end up being created, the old one left orphaned.
    the root cause of the issue is that mf connect uses jira issue keys (not id's) to track cross reference relationships in its private internal database.
    take care
    anil
