Not able to establish connection from mf connect to ALM/QC
I'm trying to sync jira with ALM/QC, using MF Connect. I've successfully made connection to jira from MF Connect, But when I try to establish connection with ALM/QC getting "Failed to Login to Server" Error. I'm able tp login to the server URL mentioned in the browser with the credentials provided during the configuration.
FYI - installed MF Connect on Windows VM.
we used to access the ALM/QC from the local system by Quality Centre Software(which is not present in VM)
