MF supplied SQ to build tablespaces and required userids for SBM Oracle db install. Where is the SQL located.?
I'm looking for the SQL supplied from MF to build the required tablespaces and required db userids for SBM 11.0.X inside the Oracle db.  Where can I find this SQL to execute it?  This would be on Windows Server.
TIA
