Issue running script in BPM
Hi All,
We have 1 VUGEN script created in VUGEN for monitoring 1 application using APM tool.
Script is running fine in VUGEN but giving the below errors in BPMs:
02/06/2022 11:58:49 T02_ASR_MRAM.c(17): Continuing after Error -27492: "HttpSendRequest" failed, Windows error code=12002 and retry limit (5) exceeded for URL="">mreus-w46603.munichre.com/.../Workflow.aspx, Snapshot Info [MSH 1 2] [MsgId: MERR-27492]
02/06/2022 11:58:49 T02_ASR_MRAM.c(17): Continuing after Error -26366: "Text=Corporate" not found for web_reg_find, Snapshot Info [MSH 1 2] [MsgId: MERR-26366]
02/06/2022 11:58:49 T02_ASR_MRAM.c(17): web_url("Workflow.aspx") highest severity level was "continue on error", 7967 body bytes, 245 header bytes [MsgId: MMSG-26388]
02/06/2022 11:58:49 T02_ASR_MRAM.c(17): Continuing after error in Vuser script. [MsgId: MMSG-10678]
02/06/2022 11:58:49 RunLogic.c(12): Notify: Transaction "T_ASR" ended with a "Fail" status (Duration: 193.4228 Wasted Time: 0.0002). [MsgId: MMSG-16871]
02/06/2022 11:58:49 RunLogic.c(12): Notify: Transaction "T_ASR" has 2 error message(s). [MsgId: MMSG-16818]
02/06/2022 11:58:49 RunLogic.c(12): Notify: The 1st error message associated with transaction "T_ASR" is "Error -27492: "HttpSendRequest" failed, Windows error code=12002 and retry limit (5) exceeded for URL=""">mreus-w46603.munichre.com/.../Workflow.aspx [MsgId: MMSG-16819]
02/06/2022 11:58:49 RunLogic.c(12): Notify: The 2nd error message associated with transaction "T_ASR" is "Error -26366: "Text=Corporate" not found for web_reg_find" [MsgId: MMSG-16819]
Please check and help us to find the solution of this issue.
Regards,
Rohan
