Hi All,
Am very new to QC, and we have an existing QC instance with 17.1 version. And I am working on upgrading Microfocus 17.1 to Open text 24.1. Am basically upgrading on the same machine. Am unable to take a backup of ALM/repository directories to restore projects after upgrade.
These are the steps am following:
1. Take backup of 17.1 by doing these two:
a. SQL Server > DB > Project > tasks > backup.
b. ALMQC SiteAdmin page > Projects > Export to project file.
2. Uninstall the 17.1 version.
3. Install 24.1 version with "Upgrade a copy of the existing schema" option.
4. Am stuck at upgrading the projects now. If I access the old projects or upgrade them via UI - it says schema version is different, so its failing.
24.1 installer doc talks about dbid.xml file, and I cannot trace where it is.
Any help would be really appreciated. Thank you.
