Hello everyone, I hope you're all doing well!
I'm facing an unexpected issue with the AzureAD connector in IDM, and I was wondering if anyone has experienced something similar or could provide some guidance.
I’m using the connector in hybrid mode, exclusively for assigning and revoking licenses and groups. It was working perfectly until last week, but now I’ve started encountering the following problem:
When I attempt to assign or revoke a license, the Remote Loader enters a continuous loop and fails to return data to the Azure connector on the IDM server. As a result, the connector on the IDM side gets stuck at "wait for receiving," while the RL keeps looping without providing any response or progress.
I’ve reviewed the logs and double-checked the configuration, but I haven’t been able to pinpoint the root cause of the issue.
Has anyone come across this situation or have any suggestions for a solution? I’d greatly appreciate your help!
Versions:
IDM: 4.8.7
AzureAD: 5.1.7.0400
Remote Loader: 4.8.7
Here is the Remote Loader log:
DirXML: [01/21/25 17:13:32.36]: TRACE: Remote Loader: Received command: SUBSCRIBER EXECUTE(4).
DirXML: [01/21/25 17:13:32.36]: TRACE: Remote Loader: Calling SubscriptionShim.execute()
DirXML: [01/21/25 17:13:32.36]: TRACE: <nds dtdversion="4.0" ndsversion="8.x">
<source>
<product edition="Advanced" version="4.8.7.0100">DirXML</product>
<contact>NetIQ Corporation</contact>
</source>
<input>
<modify cached-time="20250121201332.023Z" class-name="user" event-id="xxxx0330#20250121201332#2#1:c7198def-fa66-426d-b4f6-ef8d19c766fa" qualified-src-dn="O=MID\OU=ID\CN=open_azure_99" src-dn="\IDMQAS\MID\ID\open_azure_99" src-entry-id="821110" timestamp="1737490412#4">
<association state="associated">72e9ad33-5bb2-45de-95bb-dd87b9328ce3</association>
<modify-attr attr-name="usageLocation">
<remove-all-values/>
<add-value>
<value type="string">BR</value>
</add-value>
</modify-attr>
<modify-attr attr-name="assignLicense">
<remove-value>
<value type="string">SPE_E3#9a6eeb79-0b4b-4bf0-9808-39d99a2cd5a3</value>
</remove-value>
</modify-attr>
</modify>
</input>
</nds>
DirXML: [01/21/25 17:13:32.36]: TRACE: Azure AD Driver: AZSubscriber.execute()
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.GraphAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: queryHandler
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: queryHandler: class-name == 'users'
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: Query: preparing GET to graph.microsoft.com/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: Resetting headers
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: Setting the following HTTP request properties:
Authorization: <content suppressed>
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: Content-Type:application/json
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: Trying to use existing token
DirXML: [01/21/25 17:13:32.37]: TRACE: Azure AD Driver_Azure: Did a HTTP GET with 0 bytes of data to graph.microsoft.com/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:32.38]: TRACE: Azure AD Driver_Azure: *******************************************************
DirXML: [01/21/25 17:13:32.38]: TRACE: Azure AD Driver_Azure: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:13:32.38]: TRACE: Azure AD Driver_Azure: Request URL :graph.microsoft.com/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:32.38]: TRACE: Azure AD Driver_Azure: Http Method : GET
DirXML: [01/21/25 17:13:32.38]: TRACE: Azure AD Driver_Azure: Sending http request with below headers :-
DirXML: [01/21/25 17:13:32.38]: TRACE: Azure AD Driver_Azure: Authorization: <content suppressed>
DirXML: [01/21/25 17:13:32.38]: TRACE: Azure AD Driver_Azure: Content-Type: application/json
DirXML: [01/21/25 17:13:32.38]: TRACE: Azure AD Driver_Azure: ***************************END**************************
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: ********************************************************
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Http response code : 200
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Http response status : HTTP/1.1 200 OK
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Getting http response with below headers :-
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Cache-Control: no-cache
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Transfer-Encoding: chunked
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Content-Type: application/json;odata.metadata=minimal;odata.streaming=true;IEEE754Compatible=false;charset=utf-8
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Vary: Accept-Encoding
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Strict-Transport-Security: max-age=31536000
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: request-id: 5244c732-2109-48e7-a6ec-08804630297a
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: client-request-id: 5244c732-2109-48e7-a6ec-08804630297a
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: x-ms-ags-diagnostic: {"ServerInfo":{"DataCenter":"Brazil South","Slice":"E","Ring":"3","ScaleUnit":"000","RoleInstance":"CP1PEPF000078C5"}}
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: x-ms-resource-unit: 1
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: OData-Version: 4.0
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Date: Tue, 21 Jan 2025 20:13:31 GMT
DirXML: [01/21/25 17:13:32.65]: TRACE: Azure AD Driver_Azure: Sending http response with body :-
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Azure: **********************END*****************************
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Azure: Response code and message: 200 OK
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Azure: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.GraphAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:13:32.66]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:13:32.73]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:13:32.73]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:13:32.73]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:13:32.73]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:13:32.73]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:13:32 GMT
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver: Object-query User not found.
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.GraphAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: customHandler
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: customHandler: class-name == 'users'
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Custom: preparing GET to graph.microsoft.com/.../licenseDetails
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Resetting headers
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Setting the following HTTP request properties:
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Content-Type:application/json
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Trying to use existing token
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Did a HTTP GET with 0 bytes of data to graph.microsoft.com/.../licenseDetails
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: *******************************************************
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Request URL :graph.microsoft.com/.../licenseDetails
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Http Method : GET
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Sending http request with below headers :-
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Authorization: <content suppressed>
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: Content-Type: application/json
DirXML: [01/21/25 17:13:32.74]: TRACE: Azure AD Driver_Azure: ***************************END**************************
DirXML: [01/21/25 17:13:32.93]: TRACE: Azure AD Driver_Azure: ********************************************************
DirXML: [01/21/25 17:13:32.93]: TRACE: Azure AD Driver_Azure: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:13:32.93]: TRACE: Azure AD Driver_Azure: Http response code : 200
DirXML: [01/21/25 17:13:32.93]: TRACE: Azure AD Driver_Azure: Http response status : HTTP/1.1 200 OK
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Getting http response with below headers :-
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Cache-Control: no-cache
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Transfer-Encoding: chunked
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Content-Type: application/json;odata.metadata=minimal;odata.streaming=true;IEEE754Compatible=false;charset=utf-8
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Vary: Accept-Encoding
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Strict-Transport-Security: max-age=31536000
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: request-id: 3971b9e7-40ac-476b-b65b-e89c6c0217d0
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: client-request-id: 3971b9e7-40ac-476b-b65b-e89c6c0217d0
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: x-ms-ags-diagnostic: {"ServerInfo":{"DataCenter":"Brazil South","Slice":"E","Ring":"3","ScaleUnit":"000","RoleInstance":"CP1PEPF000078C5"}}
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: x-ms-resource-unit: 2
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: OData-Version: 4.0
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Date: Tue, 21 Jan 2025 20:13:32 GMT
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Sending http response with body :-
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: **********************END*****************************
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Response code and message: 200 OK
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver_Azure: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.GraphAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:13:32.94]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.GraphAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: customHandler
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: customHandler: class-name == 'users'
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Custom: preparing GET to graph.microsoft.com/.../licenseDetails
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Resetting headers
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Setting the following HTTP request properties:
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Content-Type:application/json
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Trying to use existing token
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Did a HTTP GET with 0 bytes of data to graph.microsoft.com/.../licenseDetails
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: *******************************************************
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Request URL :graph.microsoft.com/.../licenseDetails
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Http Method : GET
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Sending http request with below headers :-
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Authorization: <content suppressed>
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: Content-Type: application/json
DirXML: [01/21/25 17:13:33.00]: TRACE: Azure AD Driver_Azure: ***************************END**************************
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: ********************************************************
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Http response code : 200
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Http response status : HTTP/1.1 200 OK
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Getting http response with below headers :-
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Cache-Control: no-cache
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Transfer-Encoding: chunked
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Content-Type: application/json;odata.metadata=minimal;odata.streaming=true;IEEE754Compatible=false;charset=utf-8
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Vary: Accept-Encoding
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Strict-Transport-Security: max-age=31536000
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: request-id: 1dc0e9ba-3645-40ce-be61-2af53b5bc63f
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: client-request-id: 1dc0e9ba-3645-40ce-be61-2af53b5bc63f
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: x-ms-ags-diagnostic: {"ServerInfo":{"DataCenter":"Brazil South","Slice":"E","Ring":"3","ScaleUnit":"000","RoleInstance":"CP1PEPF000078C5"}}
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: x-ms-resource-unit: 2
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: OData-Version: 4.0
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Date: Tue, 21 Jan 2025 20:13:32 GMT
DirXML: [01/21/25 17:13:33.19]: TRACE: Azure AD Driver_Azure: Sending http response with body :-
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: **********************END*****************************
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Response code and message: 200 OK
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.GraphAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.GraphAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: modifyHandler
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: modifyHandler: class-name == 'users'
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Modify: preparing PATCH to graph.microsoft.com/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Resetting headers
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Setting the following HTTP request properties:
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Content-Type:application/json
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Trying to use existing token
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Did a HTTP PATCH with 59 bytes of data to graph.microsoft.com/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: *******************************************************
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Request URL :graph.microsoft.com/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Http Method : PATCH
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Sending http request with below headers :-
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Authorization: <content suppressed>
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: Content-Type: application/json
DirXML: [01/21/25 17:13:33.20]: TRACE: Azure AD Driver_Azure: ***************************END**************************
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: ********************************************************
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Http response code : 204
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Http response status : HTTP/1.1 204 No Content
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Getting http response with below headers :-
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Cache-Control: no-cache
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Strict-Transport-Security: max-age=31536000
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: request-id: d22c519a-53e1-4a01-8223-edd17521b556
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: client-request-id: d22c519a-53e1-4a01-8223-edd17521b556
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: x-ms-ags-diagnostic: {"ServerInfo":{"DataCenter":"Brazil South","Slice":"E","Ring":"3","ScaleUnit":"000","RoleInstance":"CP1PEPF000078C5"}}
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: x-ms-resource-unit: 1
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Date: Tue, 21 Jan 2025 20:13:32 GMT
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Sending http response with body :-
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: **********************END*****************************
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Response code and message: 204 No Content
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver_Azure: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.GraphAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:13:33.36]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:13:33.37]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:13:32 GMT
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:13:33.52]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:13:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:13:36.36]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:13:36.36]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:14:03.53]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:14:03 GMT
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:14:03.59]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:14:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:14:06.37]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:14:06.37]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:14:33.61]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:14:33.62]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:14:33.62]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:14:33.62]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:14:33.62]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:14:33 GMT
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:14:33.68]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:14:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:14:36.37]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:14:36.37]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:15:03.69]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:15:03.70]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:15:03.70]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:15:03.70]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:15:03 GMT
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:15:03.80]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:15:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:15:06.37]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:15:06.38]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:15:33.79]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:15:33.79]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:15:33.79]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:15:33.79]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:15:33.80]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:15:33.80]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:15:33.80]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:15:33.81]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:15:33.87]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:15:33.87]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:15:33.87]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:15:33.87]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:15:33.87]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:15:33.87]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:15:33.87]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:15:33.88]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:15:33 GMT
DirXML: [01/21/25 17:15:33.88]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:15:33.88]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:15:33.88]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:15:33.88]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:15:33.88]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:15:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:15:36.39]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:15:36.39]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:16:03.88]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:16:03.89]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:16:03.89]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:16:03.89]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:16:03.89]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:16:03.89]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:16:03.89]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:16:03.89]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:16:03 GMT
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:16:03.96]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:16:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:16:06.39]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:16:06.39]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:16:33.95]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:16:34 GMT
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:16:34.02]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:16:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:16:36.39]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:16:36.39]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:17:04.03]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:17:04.04]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:17:04.04]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:17:04.04]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:17:04.04]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:17:04 GMT
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:17:04.10]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:17:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:17:06.39]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:17:06.40]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:17:34.12]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:17:34 GMT
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:17:34.19]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:17:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:17:36.41]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:17:36.41]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:18:04.18]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:18:04.18]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:18:04.19]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:18:04 GMT
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:18:04.29]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:18:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:18:06.42]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:18:06.42]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:18:34.30]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:18:34.36]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:18:34.36]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:18:34 GMT
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:18:34.37]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:18:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:18:36.42]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:18:36.42]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:19:04.36]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:19:04.36]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:19:04.36]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:19:04.36]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:19:04.36]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:19:04.37]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:19:04 GMT
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:19:04.43]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:19:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:19:06.43]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:19:06.43]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:19:34.44]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:19:34.54]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:19:34.54]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:19:34.54]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:19:34 GMT
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:19:34.55]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:19:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:19:36.43]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:19:36.43]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:20:04.55]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:20:04.55]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:20:04.56]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:20:04.62]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:20:04.62]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:20:04 GMT
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:20:04.63]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:20:05.25]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:20:06.43]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:20:06.43]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:20:34.62]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:20:34 GMT
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:20:34.69]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:20:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:20:36.43]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:20:36.43]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:21:04.70]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:21:04.70]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:21:04.70]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:21:04.70]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:21:04.70]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:21:04.71]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:21:04 GMT
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:21:04.77]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:21:04.78]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:21:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:21:06.45]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:21:06.45]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:21:34.76]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:21:34.76]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:21:34.76]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:21:34.76]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:21:34.76]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:21:34.77]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:21:34 GMT
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:21:34.83]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:21:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:21:36.46]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:21:36.46]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:22:04.84]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:22:04 GMT
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:22:04.91]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:22:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:22:06.47]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:22:06.47]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:22:34.90]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:22:34.91]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:22:34.91]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:22:34.91]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:22:34.92]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:22:34.99]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:22:34.99]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:22:34.99]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:22:34.99]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:22:34.99]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:22:34.99]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:22:35.00]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:22:35.00]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:22:34 GMT
DirXML: [01/21/25 17:22:35.00]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:22:35.00]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:22:35.00]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:22:35.00]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:22:35.00]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:22:35.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:22:36.49]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:22:36.49]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:23:05.00]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:23:05.00]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:23:05.00]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:23:05.00]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:23:05.00]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:23:05.01]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:23:05.11]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:23:05.11]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:23:05 GMT
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Response code and message: 404 User not found.
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberResponse()
DirXML: [01/21/25 17:23:05.12]: TRACE: Azure AD Driver: Received response document from subscriber
DirXML: [01/21/25 17:23:05.24]: TRACE: Remote Loader: Received a 'keep-alive' packet.
DirXML: [01/21/25 17:23:06.49]: TRACE: Remote Loader: Connection monitor thread waking up.
DirXML: [01/21/25 17:23:06.49]: TRACE: Remote Loader: Connection monitor thread going to sleep.
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver: Sending command document to subscriber
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: RESTSubscriptionShim.execute() :
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: Calling document modifier class com.novell.nds.dirxml.driver.azure.apiext.ExchangeAPIExtension.modifySubscriberRequest()
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: queryHandler
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: queryHandler: class-name == 'Users'
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: Query: preparing GET to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: Resetting headers
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: Setting the following HTTP request properties:
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: Content-Type:application/json
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: Did a HTTP GET with 0 bytes of data to 99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:23:35.12]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:23:35.13]: TRACE: Azure AD Driver_Exchange: **********************LOGGING REQUEST******************
DirXML: [01/21/25 17:23:35.13]: TRACE: Azure AD Driver_Exchange: *******************************************************
DirXML: [01/21/25 17:23:35.13]: TRACE: Azure AD Driver_Exchange: Request URL :99.999.9.99:9001/.../72e9ad33-5bb2-45de-95bb-dd87b9328ce3
DirXML: [01/21/25 17:23:35.13]: TRACE: Azure AD Driver_Exchange: Http Method : GET
DirXML: [01/21/25 17:23:35.13]: TRACE: Azure AD Driver_Exchange: Sending http request with below headers :-
DirXML: [01/21/25 17:23:35.13]: TRACE: Azure AD Driver_Exchange: Authorization: <content suppressed>
DirXML: [01/21/25 17:23:35.13]: TRACE: Azure AD Driver_Exchange: Content-Type: application/json
DirXML: [01/21/25 17:23:35.13]: TRACE: Azure AD Driver_Exchange: ***************************END**************************
DirXML: [01/21/25 17:23:35.20]: TRACE: Azure AD Driver_Exchange: ********************************************************
DirXML: [01/21/25 17:23:35.20]: TRACE: Azure AD Driver_Exchange: ***********************LOGGING RESPONSE*****************
DirXML: [01/21/25 17:23:35.20]: TRACE: Azure AD Driver_Exchange: Http response code : 404
DirXML: [01/21/25 17:23:35.20]: TRACE: Azure AD Driver_Exchange: Http response status : HTTP/1.1 404 User not found.
DirXML: [01/21/25 17:23:35.20]: TRACE: Azure AD Driver_Exchange: Getting http response with below headers :-
DirXML: [01/21/25 17:23:35.21]: TRACE: Azure AD Driver_Exchange: Content-Length: 0
DirXML: [01/21/25 17:23:35.21]: TRACE: Azure AD Driver_Exchange: Server: Microsoft-HTTPAPI/2.0
DirXML: [01/21/25 17:23:35.21]: TRACE: Azure AD Driver_Exchange: Date: Tue, 21 Jan 2025 20:23:35 GMT
DirXML: [01/21/25 17:23:35.21]: TRACE: Azure AD Driver_Exchange: Sending http response with body :-
DirXML: [01/21/25 17:23:35.21]: TRACE: Azure AD Driver_Exchange: **********************END*****************************
