Function or script to anonymize attribute values
Hi all,
I'm quite new to Designer and IDM as I just (barely) created my first driver... :)
What it does is to take some actions at the very end of a User's lifecycle (event trigger = when the "Status" value from HR goes to a specific value).
So far I have some "cleaning" functions that operate as expected, but
we need to keep the User record for some time (audit/compliance) in the system, and we have been asked to anonymize some data.
I'm wondering if there is any function/library/script that would do that almost out-of-the-box based on whatever standard algorithm out there ?
Any hint much appreciated !
Tx.
Jacques Forster (IGA architect)
Parents
    What about replacing specific attributes with randomly generated strings?
    I found some Java function and converted it to ECMAscript.
    (I'm sure that our Java experts can provide a better version of this function)
    function randomstring(length) {
    result = '';
    const characters = 'ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789';
    const charactersLength = characters.length;
    counter = 0;
    while (counter < length) {
    result += characters.charAt(Math.floor(Math.random() * charactersLength));
    counter += 1;
    return result;
    Simple policy code:
    <rule>
    <description>01 Get Name info</description>
    <conditions>
    <and/>
    </conditions>
    <actions>
    <do-set-local-variable name="lvSurname" scope="policy">
    <arg-string>
    <token-op-attr name="Surname"/>
    </arg-string>
    </do-set-local-variable>
    <do-set-local-variable name="lvGivenName" scope="policy">
    <arg-string>
    <token-op-attr name="Given Name"/>
    </arg-string>
    </actions>
    </rule>
    <rule>
    <description>20 Get Given Name</description>
    <conditions>
    <and>
    <if-local-variable name="lvGivenName" op="available"/>
    <if-local-variable mode="nocase" name="lvGivenName" op="not-equal"/>
    </and>
    </conditions>
    <actions>
    <do-set-local-variable name="lvLength" scope="policy">
    <arg-string>
    <token-text xml:space="preserve">10</token-text>
    </arg-string>
    <do-set-src-attr-value name="Given Name">
    <arg-value type="string">
    <token-xpath expression="es:randomstring($lvLength)"/>
    </arg-value>
    </do-set-src-attr-value>
    </actions>
    </rule>
    <rule>
    <description>30 Get LastName</description>
    <conditions>
    <and>
    <if-local-variable name="lvSurname" op="available"/>
    <if-local-variable mode="nocase" name="lvSurname" op="not-equal"/>
    </and>
    </conditions>
    <actions>
    <arg-string>
    <token-text xml:space="preserve">8</token-text>
    </arg-string>
    <do-set-src-attr-value name="Surname">
    </arg-value>
    </actions>
    </rule>
    Simulation:
    JSON-tests :Applying policy: %+C%14Canonymizer%-C.
    JSON-tests : Applying to instance #1.
    JSON-tests : Evaluating selection criteria for rule '01 Get Name info'.
    JSON-tests : Rule selected.
    JSON-tests : Applying rule '01 Get Name info'.
    JSON-tests : Action: do-set-local-variable("lvSurname",scope="policy",token-op-attr("Surname")).
    JSON-tests : arg-string(token-op-attr("Surname"))
    JSON-tests : token-op-attr("Surname")
    JSON-tests : Token Value: "Jones".
    JSON-tests : Arg Value: "Jones".
    JSON-tests : Action: do-set-local-variable("lvGivenName",scope="policy",token-op-attr("Given Name")).
    JSON-tests : arg-string(token-op-attr("Given Name"))
    JSON-tests : token-op-attr("Given Name")
    JSON-tests : Token Value: "Samuel".
    JSON-tests : Arg Value: "Samuel".
    JSON-tests : Evaluating selection criteria for rule '20 Get Given Name'.
    JSON-tests : (if-local-variable 'lvGivenName' available) = TRUE.
    JSON-tests : (if-local-variable 'lvGivenName' not-equal "") = TRUE.
    JSON-tests : Applying rule '20 Get Given Name'.
    JSON-tests : Action: do-set-local-variable("lvLength",scope="policy","10").
    JSON-tests : arg-string("10")
    JSON-tests : token-text("10")
    JSON-tests : Arg Value: "10".
    JSON-tests : Action: do-set-src-attr-value("Given Name",token-xpath("es:randomstring($lvLength)")).
    JSON-tests : arg-string(token-xpath("es:randomstring($lvLength)"))
    JSON-tests : token-xpath("es:randomstring($lvLength)")
    JSON-tests : Token Value: "VQOlOTVTht".
    JSON-tests : Arg Value: "VQOlOTVTht".
    JSON-tests : Evaluating selection criteria for rule '30 Get LastName'.
    JSON-tests : (if-local-variable 'lvSurname' available) = TRUE.
    JSON-tests : (if-local-variable 'lvSurname' not-equal "") = TRUE.
    JSON-tests : Applying rule '30 Get LastName'.
    JSON-tests : Action: do-set-local-variable("lvLength",scope="policy","8").
    JSON-tests : arg-string("8")
    JSON-tests : token-text("8")
    JSON-tests : Arg Value: "8".
    JSON-tests : Action: do-set-src-attr-value("Surname",token-xpath("es:randomstring($lvLength)")).
    JSON-tests : Token Value: "ksZ0bDFZ".
    JSON-tests : Arg Value: "ksZ0bDFZ".
    JSON-tests : Direct command from policy
    JSON-tests :
    <nds dtdversion="4.0" ndsversion="8.x">
    <source>
    <product version="4.8.7.0000">DirXML</product>
    <contact>NetIQ Corporation</contact>
    </source>
    <input>
    <modify class-name="User" dest-dn="\Users\Samuel">
    <association>1012</association>
    <modify-attr attr-name="Given Name">
    <remove-all-values/>
    <add-value>
    <value type="string">VQOlOTVTht</value>
    </add-value>
    </modify-attr>
    <modify-attr attr-name="Surname">
    <add-value>
    <value type="string">ksZ0bDFZ</value>
    </add-value>
    </modify-attr>
    </modify>
    </input>
    </nds>
    JSON-tests : Direct command from policy result
    JSON-tests :
    <source>
    </source>
    <output>
    <status level="success"></status>
    </output>
    </nds>
    JSON-tests :Policy returned:
    JSON-tests :
    <source>
    </source>
    <input>
    <instance class-name="User" src-dn="\Users\Samuel">
    <attr attr-name="Surname">
    <value type="string">Jones</value>
    </attr>
    <attr attr-name="cn">
    <value type="string">Samuel</value>
    </attr>
    <attr attr-name="Given Name">
    </attr>
    </instance>
    </input>
    </nds>
    Alex
    P.S.
    For me, instead replace it with rundom string better to "encrypt" it, with option to decrypt it back, if it will be required, but "randomize" it also can be good enouph. (Depends from your requirements)
    Thanks Alex, much appreciated!
    I will pass to a developer for further elaboration and "packaging"
Reply Children
No Data
