Problem with business role detections
Running Identity Governance 3.6.1 on SLES 15.1. MSSQL 19.
We have an issue with Business role detection. My understanding is that business role detection for "All business roles" should be triggered after publishing identities/applications, but that isn't happening for us.
We have also tried to trigger a business role detection by creating and deleting technical roles without any luck.
If we publish or edit a business role it is detected correctly. Detection types "Eval Date Formulas" and "Check Expirations" seem to run correctly.
I don't see any errors in catalina.21-xx-xx.log. But in catalina.out I see this related to business role detection:
"pool-BusinessRoleDetectionService-1-thread-1" #389 daemon prio=5 os_prio=0 tid=0x00007f4bb4026800 nid=0x4eab waiting on condition [0x00007f4ba412b000] java.lang.Thread.State: WAITING (parking) at sun.misc.Unsafe.park(Native Method) - parking to wait for <0x00000000c6ac8fa0> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject) at java.util.concurrent.locks.LockSupport.park(LockSupport.java:175) at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2044) at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1081) at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:809) at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1074) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1134) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748)
We have a number of business roles with auto-grant and auto-revoke permissions so it's important for us to get this working. Any advice on how to troubleshoot this would be appreciated.
Parents
    We are running IG 3.7.3 on a postgresql 12.7 backend and have the same issue.  Business roles are not doing any detections for quite some time now and I cannot get it to run them without changing each individual business role to force a re-evaluation.
  • 0   in reply to
    Greetings Robert,
            Please be advised that Postgres 12.x is not Certified nor Supported with any version of Identity Governance. ID Gov 3.7.3 is Certified and Supports on Postgres 11.x
    Sincerely,
    Steven Williams
    Principal Enterprise Architect
    OpenText Cybersecurity
    My mistake, IDM is the 12.x DB, this is running on 11.x
Reply Children
No Data
