I'm using Visual Studio 2019 version 16.11.40 and Fortify 22.2.2 for windows. I have my license file installed.
For some reason after I select a project on the right, I still can't access Analyze Solution as the menu item is greyed out. Any ideas?
Cybersecurity
DevOps Cloud
IT Operations Cloud
In Visual Studio, you have to open a project or solution in order for these options to be available. If you choose the option to open a folder, these values will be greyed out.
Instead of highlighting the project or solution, you must open the project or solution.
