Custom Fortify SSC parser plugin Caused by: oracle.jdbc.OracleDatabaseException: ORA-06553: PLS-306: wrong number or types of arguments in call to 'UPDATEEXISTINGWITHLATEST'
Hello,
I'm developing a custom parser.
The jar file is properly generated and installed on FSSC.
When I upload an artifact to FSSC I always get the following error.
Exception: An unexpected error occurred during scan processing: com.fortify.manager.exception.FMDALGeneralException: An unexpected error occurred.
Checking the logs, the json file with the vulnerabilities is properly is properly parsed but it appears the following exception trace
2023-09-20 11:33:36,908   [WARN] org.hibernate.engine.jdbc.spi.SqlExceptionHelper - SQL Error: 6553, SQLState: 65000
2023-09-20 11:33:36,908   [ERROR] org.hibernate.engine.jdbc.spi.SqlExceptionHelper - ORA-06553: PLS-306: wrong number or types of arguments in call to 'UPDATEEXISTINGWITHLATEST'\n
2023-09-20 11:33:36,909   [ERROR] com.fortify.manager.BLL.impl.FPRBLLImpl - Error processing scan issues from test.zip in project version: 16102572
	at com.fortify.manager.DAL.support.FMDALExceptionTranslationInterceptor.translateException(FMDALExceptionTranslationInterceptor.java:75) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.DAL.support.FMDALExceptionTranslationInterceptor.aroundRepositoryMethod(FMDALExceptionTranslationInterceptor.java:42) ~[ssc-core-23.1.0.0148.jar:?]
	at jdk.internal.reflect.GeneratedMethodAccessor144.invoke(Unknown Source) ~[?:?]
	at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.springframework.aop.aspectj.AbstractAspectJAdvice.invokeAdviceMethodWithGivenArgs(AbstractAspectJAdvice.java:634) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.aop.aspectj.AbstractAspectJAdvice.invokeAdviceMethod(AbstractAspectJAdvice.java:624) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.aop.aspectj.AspectJAroundAdvice.invoke(AspectJAroundAdvice.java:72) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:175) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.proceed(CglibAopProxy.java:763) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:123) ~[spring-tx-5.3.25.jar:5.3.25]
	at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:388) ~[spring-tx-5.3.25.jar:5.3.25]
	at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:119) ~[spring-tx-5.3.25.jar:5.3.25]
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:97) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:708) ~[spring-aop-5.3.25.jar:5.3.25]
	at com.fortify.manager.DAL.impl.ScanManagerImpl$$EnhancerBySpringCGLIB$$62407aab.applyScanIssuesToProjectVersion(<generated>) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl.processScanIssues(FPRBLLImpl.java:2317) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl.processIssuesFromScans(FPRBLLImpl.java:2263) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl$15.run(FPRBLLImpl.java:1946) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FprProcessingRunner.doRunStep(FprProcessingRunner.java:85) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FprProcessingRunner.runStep(FprProcessingRunner.java:61) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl.processScansAndIssuesForArtifact(FPRBLLImpl.java:1943) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl.processArtifact(FPRBLLImpl.java:1898) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl.processArtifactUpload(FPRBLLImpl.java:1758) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl.uploadArtifactJobCallback(FPRBLLImpl.java:1641) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl.uploadArtifactJobCallback(FPRBLLImpl.java:1623) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl$$FastClassBySpringCGLIB$$686a4cd1.invoke(<generated>) ~[ssc-core-23.1.0.0148.jar:?]
	at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218) ~[spring-core-5.3.25.jar:5.3.25]
	at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:793) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163) ~[spring-aop-5.3.25.jar:5.3.25]
	at org.springframework.aop.aspectj.MethodInvocationProceedingJoinPoint.proceed(MethodInvocationProceedingJoinPoint.java:89) ~[spring-aop-5.3.25.jar:5.3.25]
	at com.fortify.manager.logging.ExceptionInterceptor.aroundBll(ExceptionInterceptor.java:72) ~[ssc-core-23.1.0.0148.jar:?]
	at jdk.internal.reflect.GeneratedMethodAccessor254.invoke(Unknown Source) ~[?:?]
	at org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:67) ~[spring-security-core-5.8.2.jar:5.8.2]
	at com.fortify.manager.security.FmMethodSecurityInteceptor.invoke(FmMethodSecurityInteceptor.java:46) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.impl.FPRBLLImpl$$EnhancerBySpringCGLIB$$ee9ff9cb.uploadArtifactJobCallback(<generated>) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.BLL.jobs.ArtifactUploadJob.executeJob(ArtifactUploadJob.java:102) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.service.scheduler.SimpleJob.executeJob(SimpleJob.java:92) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.service.scheduler.SimpleJob.runInternal(SimpleJob.java:67) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.service.scheduler.SimpleJob.run(SimpleJob.java:44) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.service.scheduler.SchedulerManagerImpl.lambda$submitJob$3(SchedulerManagerImpl.java:315) ~[ssc-core-23.1.0.0148.jar:?]
	at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
	at java.lang.Thread.run(Thread.java:829) [?:?]
Caused by: org.springframework.dao.InvalidDataAccessResourceUsageException: could not execute statement; SQL [n/a]; nested exception is org.hibernate.exception.SQLGrammarException: could not execute statement
	at org.springframework.orm.hibernate5.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:195) ~[spring-orm-5.3.25.jar:5.3.25]
	at org.springframework.orm.hibernate5.HibernateExceptionTranslator.convertHibernateAccessException(HibernateExceptionTranslator.java:102) ~[spring-orm-5.3.25.jar:5.3.25]
	at org.springframework.orm.hibernate5.HibernateExceptionTranslator.translateExceptionIfPossible(HibernateExceptionTranslator.java:77) ~[spring-orm-5.3.25.jar:5.3.25]
	at org.springframework.dao.support.ChainedPersistenceExceptionTranslator.translateExceptionIfPossible(ChainedPersistenceExceptionTranslator.java:61) ~[spring-tx-5.3.25.jar:5.3.25]
	at org.springframework.dao.support.DataAccessUtils.translateIfNecessary(DataAccessUtils.java:242) ~[spring-tx-5.3.25.jar:5.3.25]
	at org.springframework.dao.support.PersistenceExceptionTranslationInterceptor.invoke(PersistenceExceptionTranslationInterceptor.java:152) ~[spring-tx-5.3.25.jar:5.3.25]
	at com.fortify.manager.DAL.support.FMDALExceptionTranslationInterceptor.aroundRepositoryMethod(FMDALExceptionTranslationInterceptor.java:40) ~[ssc-core-23.1.0.0148.jar:?]
	... 61 more
Caused by: org.hibernate.exception.SQLGrammarException: could not execute statement
	at org.hibernate.exception.internal.SQLStateConversionDelegate.convert(SQLStateConversionDelegate.java:103) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:37) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:113) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:99) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:200) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at org.hibernate.engine.query.spi.NativeSQLQueryPlan.performExecuteUpdate(NativeSQLQueryPlan.java:107) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at org.hibernate.internal.SessionImpl.executeNativeUpdate(SessionImpl.java:1554) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at org.hibernate.query.internal.NativeQueryImpl.doExecuteUpdate(NativeQueryImpl.java:299) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at org.hibernate.query.internal.AbstractProducedQuery.executeUpdate(AbstractProducedQuery.java:1696) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	at com.fortify.manager.DAL.HibernateDatabaseInterface$2.doInHibernate(HibernateDatabaseInterface.java:966) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.DAL.HibernateDatabaseInterface$2.doInHibernate(HibernateDatabaseInterface.java:952) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.DAL.HibernateDatabaseInterface.executeSQLUpdate(HibernateDatabaseInterface.java:542) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.DAL.impl.ScanManagerImpl.updateOrInsertIssue4LastScan(ScanManagerImpl.java:1256) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.DAL.impl.ScanManagerImpl.postIssueParse(ScanManagerImpl.java:933) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.DAL.impl.ScanManagerImpl.applyScanIssuesToProjectVersion(ScanManagerImpl.java:631) ~[ssc-core-23.1.0.0148.jar:?]
	at com.fortify.manager.DAL.impl.ScanManagerImpl$$FastClassBySpringCGLIB$$131bf6cc.invoke(<generated>) ~[ssc-core-23.1.0.0148.jar:?]
	at org.springframework.dao.support.PersistenceExceptionTranslationInterceptor.invoke(PersistenceExceptionTranslationInterceptor.java:137) ~[spring-tx-5.3.25.jar:5.3.25]
	... 61 more
Caused by: java.sql.SQLException: ORA-06553: PLS-306: wrong number or types of arguments in call to 'UPDATEEXISTINGWITHLATEST'
	at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:629) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:563) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1230) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:771) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:298) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:511) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:162) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:1240) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.OracleStatement.executeSQLStatement(OracleStatement.java:1819) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1471) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3760) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.OraclePreparedStatement.executeLargeUpdate(OraclePreparedStatement.java:4061) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.OraclePreparedStatement.executeUpdate(OraclePreparedStatement.java:4036) ~[ojdbc11-21.7.0.0.jar:?]
	at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeUpdate(OraclePreparedStatementWrapper.java:995) ~[ojdbc11-21.7.0.0.jar:?]
	at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136) ~[commons-dbcp2-2.9.0.jar:2.9.0]
	at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:197) ~[hibernate-core-5.6.12.Final.jar:5.6.12.Final]
	... 61 more
So there is an issue during the execution of the prodecure "UPDATEEXISTINGWITHLATEST".
Any hint about this issue?
Best regards
Parents Reply Children
No Data
