Problem running diagpwd
Hi!
We need to troubleshoot some universal password errors but having problems running diagpwd utility.
eDirectory runs on OES 24.1 (eDirectory 9.2.8) and when running we get following error:
# diagpwd <serverIP> 636 /etc/opt/novell/certs/SSCert.pem <LDAP DN of user to check> base <LDAP DN of admin account>
ERROR -1 ldap_simple_bind_s
Segmentation fault (core dumped)
Please note that:
- LDAP authentication on that server works without any problems
- LDAP SSL certificate has not expired
- LDAP SSL certificate has both DNS and IP as SAN
- We get same error if we use serverDNS name instead of serverIP whe running diagpwd
diagpwd -v returns "diagpwd version 5"
We tested that on multiple servers in same tree with same result, so either we are using utility wrong way or there is something wrong with that version of diagpwd.
Any help appreciated Blush
Kind regards,
Sebastijan
PS: Just for info, on OES servers diagpwd is automatically installed by edirectory-oes-nmas-ldap-extensions-client-9.2.8-150400.1.46.x86_64 package
Kind regards,
Sebastijan
  • 0   in reply to
    No difference in the symptoms, even after confirming the path is set, and on a box I haven't tried this yet.
    and those ldd commands don't work for me either syntax
    ds2:~ # ldd diagpwd
    ldd: ./diagpwd: No such file or directory
    ds2:~ # ldd ./diagpwd
    ahh, that KB needs updating to include the path.    and both with or without that environment path set, both show
       libnmasext.so => /opt/novell/eDirectory/lib64/libnmasext.so (0x00007f9011a00000)
    something else is afoot.
    ________________________
    Andy of KonecnyConsulting.ca in Toronto
    Please use the "Like" and/or "Verified Answers" as appropriate as that helps us all.
  • 0   in reply to
    I'll update the KB.  the libnmasext.so; which mistakenly got highlighted during formatting, isn't the issue on OES 23 & 24.  It's the version libldap_r-2.4.so.2 which is placed in /usr/lib64
    Adding /opt/novell/eDirectory/eDir-exclusive/lib64 to the LD_LIBRARY_PATH
    OES243:/opt/novell/eDirectory/bin # export LD_LIBRARY_PATH=/opt/novell/eDirectory/eDir-exclusive/lib64:$LD_LIBRARY_PATH
    changes the output of ldd <path>/diagpwd
    from:  libldap-2.4.so.2 => /usr/lib64/libldap-2.4.so.2
    to:  libldap_r-2.4.so.2 => /opt/novell/eDirectory/eDir-exclusive/lib64/libldap_r-2.4.so.2
    The core stack for the core I can duplicate shows:
     Stack trace of thread 77892:
                    #0  0x00007fafacc5bf22 __pthread_rwlock_wrlock (libpthread.so.0 + 0xff22)
                    #1  0x00007fafab6f1149 CRYPTO_THREAD_write_lock (libcrypto.so.1.1 + 0x230149)
                    #2  0x00007fafac5adc0c SSL_CTX_flush_sessions (libssl.so.1.1 + 0x4cc0c)
                    #3  0x00007fafac5a4183 SSL_CTX_free (libssl.so.1.1 + 0x43183)
                    #4  0x00007fafaccc8ec5 ldap_int_tls_destroy (libldap_r-2.4.so.2 + 0x39ec5)
                    #5  0x00007fafacd259b3 _dl_fini (ld-linux-x86-64.so.2 + 0x119b3)
                    #6  0x00007fafac856bd9 __run_exit_handlers (libc.so.6 + 0x4dbd9)
                    #7  0x00007fafac856d6a exit (libc.so.6 + 0x4dd6a)
                    #8  0x00007fafac83e254 __libc_start_main (libc.so.6 + 0x35254)
                    #9  0x0000000000401d2a _start (diagpwd + 0x1d2a)
    If you stack trace is different, please post it for me to review.
  • 0   in reply to
    Core traces are a bit beyond me at this time without more detailed instructions. I am so not a dev guy.
    The cores are just over a quarter Megabyte in size, so should easily be able to post the most recent one and the matching PuTTY log to the case (02974596).
    One thing that is catching my eye in the strace, a bunch of (No such file or directory) referencing /opt/novell/eDirectory/eDir-exclusive/lib64/tls/  which doesn't exist.
  • 0   in reply to
    and I see a typo in today's exports,  a double colon.   fixing that has it working now
    if export is the correct syntax, that would be a good addition to the KB article.
    as well as some consistency on which certs to use.  Local server cert vs CA's public, and pem vs der
    I am getting in with the local server cert to talk to itself.
  • 0   in reply to
    Please check a small addition for validity.. In the field I always have the issue that /etc/ssl/servercerts/ the certifcates have a problem for whatever reason. Please include in the KM to check the certificates with openssl that are in the path and also to check the certificates in the /kmocache directory before starting the diagnosis.
    Thanks
    George
    “You can't teach a person anything, you can only help them to discover it within themselves.” Galileo Galilei
    . /opt/novell/eDirectory/bin/ndspath
    modify LD_LIBRARY_PATH variable :
    LD_LIBRARY_PATH=/opt/novell/eDirectory/eDir-exclusive/lib64:/opt/novell/eDirectory/lib64:/opt/novell/eDirectory/lib64/nds-modules:/opt/novell/lib64:$LD_LIBRARY_PATH
    cd /opt/novell/eDirectory/bin
    ./diagpwd ...
    Everyone is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. [A. Einstein]
  • 0   in reply to
    If I have understood the ndspath script correctly, it is determined at the beginning whether it is a 32 bit or 64 bit operating system. Depending on the version, a libdir path is defined (example linux.mak)
    With the help of awk an export for the ndspath is provided from the result of the check. If I understand this correctly, an export for the corresponding path is then created below for each operating system. With the specification from above to change the path is rewritten by hand. Do I understand something wrong? Have any effects been observed?
    from the script: if [ $OS = “Linux” ] ; then
            export LD_LIBRARY_PATH=$base_dir/opt/novell/eDirectory/lib64:$base_dir/opt/novell/eDirectory/lib64/nds-modules:$base_dir/opt/novell/
    lib64:$LD_LIBRARY_PATH.
    Now I'm not sure if this is dynamically rewritten after each patch or if the export is a static thing after the first installation of eDir.
    the exact export path results from uname, ndsconifg and ndspath and .mak
    My recommendation here is to open a call in conjunction with the experiences you have made in your post. This is the only way to ensure that no side effects occur. It was clear from the beginning after the strace where the rabbit runs.
    George
  • 0   in reply to
    This article has the answer after some clarifications. The most important bit is the export command, i.e.
    #  export LD_LIBRARY_PATH=/opt/novell/eDirectory/eDir-exclusive/lib64:/opt/novell/eDirectory/lib64:/opt/novell/eDirectory/lib64/nds-modules:/opt/novell/lib64:$LD_LIBRARY_PATH
    as without that export, it doesn't do anything for diagpwd.  A little step that is likely obvious to the dev types, but not to the rest of us who didn't go that path in IT.
