Problem running diagpwd
Hi!
We need to troubleshoot some universal password errors but having problems running diagpwd utility.
eDirectory runs on OES 24.1 (eDirectory 9.2.8) and when running we get following error:
# diagpwd <serverIP> 636 /etc/opt/novell/certs/SSCert.pem <LDAP DN of user to check> base <LDAP DN of admin account>
ERROR -1 ldap_simple_bind_s
Segmentation fault (core dumped)
Please note that:
- LDAP authentication on that server works without any problems
- LDAP SSL certificate has not expired
- LDAP SSL certificate has both DNS and IP as SAN
- We get same error if we use serverDNS name instead of serverIP whe running diagpwd
diagpwd -v returns "diagpwd version 5"
We tested that on multiple servers in same tree with same result, so either we are using utility wrong way or there is something wrong with that version of diagpwd.
Any help appreciated Blush
Kind regards,
Sebastijan
PS: Just for info, on OES servers diagpwd is automatically installed by edirectory-oes-nmas-ldap-extensions-client-9.2.8-150400.1.46.x86_64 package
Kind regards,
Sebastijan
Parents Reply Children
  • 0   in reply to
    No difference in the symptoms, even after confirming the path is set, and on a box I haven't tried this yet.
    and those ldd commands don't work for me either syntax
    ds2:~ # ldd diagpwd
    ldd: ./diagpwd: No such file or directory
    ds2:~ # ldd ./diagpwd
    ahh, that KB needs updating to include the path.    and both with or without that environment path set, both show
       libnmasext.so => /opt/novell/eDirectory/lib64/libnmasext.so (0x00007f9011a00000)
    something else is afoot.
    ________________________
    Andy of KonecnyConsulting.ca in Toronto
    Please use the "Like" and/or "Verified Answers" as appropriate as that helps us all.
  • 0   in reply to
    Please check a small addition for validity.. In the field I always have the issue that /etc/ssl/servercerts/ the certifcates have a problem for whatever reason. Please include in the KM to check the certificates with openssl that are in the path and also to check the certificates in the /kmocache directory before starting the diagnosis.
    Thanks
    George
    “You can't teach a person anything, you can only help them to discover it within themselves.” Galileo Galilei
  • 0   in reply to
    This article has the answer after some clarifications. The most important bit is the export command, i.e.
    #  export LD_LIBRARY_PATH=/opt/novell/eDirectory/eDir-exclusive/lib64:/opt/novell/eDirectory/lib64:/opt/novell/eDirectory/lib64/nds-modules:/opt/novell/lib64:$LD_LIBRARY_PATH
    as without that export, it doesn't do anything for diagpwd.  A little step that is likely obvious to the dev types, but not to the rest of us who didn't go that path in IT.
