SCC console gets stuck when Sentienl has been running for a while
Hi All
    My have some customer use sentinel 8.5.0.1 /8.6.1.0  . total have 6 sentinel appliances
Within a week after Sentienl starts the service, SCC can be started and used normally.
But when Sentinel has been running for more than a month... I try to open the SCC Console, and it often gets stuck in the SSO step without the user authentication window appearing.
The method I usually use is to restart the Sentinel service, and SCC can smoothly provide users with normal use.
However, restarting the Sentinel service will affect the log collection function (especially UDP Connector events may be lost). Is there any good way to solve this problem without restarting the Sentinel service?
I have confirmed that it is not a problem with the Jre installed on the client... Because as long as the Sentinel service is restarted, SCC can basically be used smoothly no matter when it is turned on within a week.
Tags:
