Request for module registry not found for agent
I try to register an SLES12SP5 host at the PAM.
as in the doc, I run:
#myhost:/opt/netiq/npum/bin # ./unifi regclnt register
Please provide the DNS name or IP address of the framework manager : () pam.internal
Please provide the port number of the framework manager            : (29120)
Please provide the DNS name or IP address of this agent            : (myhost) myhost.internal
Please provide the registered agent name for this agent            : (myhost)
Framework manager                : pam.internal:29120
Agent DNS name or IP address     : myhost.internal
Agent name                       : myhost
Is this correct: (y)
Please enter the name and password of an account
with permission to register this host.
User name: (admin)
Password:
Confirm password:
Execute the registration process in the background(yes/no)? (yes): no
Starting the registration process...
Updating registry list
Registration successful for myhost to pam.internal:29120
But I get  the line "Request for module registry not found for agent"
in the log at the client.
At the PAM-Server I see only basic info (Agent-Name, DNS-Name/IP, Port and the Status 'Offline')
(unifi is listening at port 29120 at both hosts)
Any hints? Where should this module stored?
Is there a detailed description about the installation of an agent/client (run prm -i [modulename].rpm is not enought documentation)
Tags:
Parents
    Hi
    Go to pam admin console your https://pamserver and not https://pamserver/pam once you have logged in go to hosts select the manager server and select packages on the top right and side
    See if the module registry is available and is showing as primary
    Regards
    Liam O'Dowd
Reply
    Hi
    Regards
    Liam O'Dowd
Children
No Data
