Hi.
We are using token-attr or token-dest-attr for return the value from Vault, but the value is nothig.
Ist a Text Driver only for update workforceID, Given Name and Surname.
The update works fine, but I need to condition in case the employeeStatus does not meet a condition.
We need query a attribute that not set on filter.
The filter is:
Then in a Match Policy I need validate if the employeeStatus equal to D.
I try to return the value attribute using Nouns Attribute or Destination Atribute, but any way return data.
I am using "trace message" to debug values
It is the log:
PT: Applying rule 'Validate employeeStatus'.
PT: Action: do-trace-message("Attr: "+token-attr("employeeStatus")+"- Dest Att:"+token-dest-attr("employeeStatus",class-name="User")).
PT: arg-string("Attr: "+token-attr("employeeStatus")+"- Dest Att:"+token-dest-attr("employeeStatus",class-name="User"))
PT: token-text("Attr: ")
PT: token-attr("employeeStatus")
PT: Token Value: "".
PT: token-text("- Dest Att:")
PT: token-dest-attr("employeeStatus",class-name="User")
PT: Arg Value: "Attr: - Dest Att:".
PT:Attr: - Dest Att:
Do I need to set some before use its Nouns?
Best,
