Here's my log:
01 2015-11-23 08:13:24 -28800 0 8001 4884 4688 This Logger class instance [000000A4E35AC7E0] was initialized at 2015:11:23:08:13:23 in Process ID # 4884.
01 2015-11-23 08:13:24 -28800 0 8001 4884 4688 OS Version Info = "O.S. Name: Microsoft Windows, Architecture: x86_64, Platform ID: 2, Version: v6.3, Build: 0, SP: v0.0 [], Product Type: 3, Suite Mask: 0x80000110", OS Bits = 64, Application binary file spec = "C:\Program Files\Novell\File Reporter\Engine\NFREngine.exe", Application Bits = 64, Application Version = "v2.6.1.3".
01 2015-11-23 08:13:24 -28800 0 8001 4884 4688 This is the first time that a Logger thread has been started for this class instance.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Validating data path information...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Completed validating data path information, Data Path = "C:\ProgramData\Novell\File Reporter\Engine\data", bOK = 1.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Completed initializing the Configuration, bOK = 1.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Configuring the Logging subsystem [Phase II]...
82 2015-11-23 08:13:24 -28800 0 ff04 4884 4688 <CONFIG><LOGPATH>C:\ProgramData\Novell\File Reporter\Engine\log</LOGPATH></CONFIG>
82 2015-11-23 08:13:24 -28800 0 ff05 4884 4688 <CONFIG><LOGFILEBASENAME/></CONFIG>
82 2015-11-23 08:13:24 -28800 0 ff05 4884 4688 <CONFIG><LOGFILEBASENAME>nfrengine</LOGFILEBASENAME></CONFIG>
82 2015-11-23 08:13:24 -28800 0 ff08 4884 4688 <CONFIG><LEVEL>5</LEVEL><CATEGORY/></CONFIG>
82 2015-11-23 08:13:24 -28800 0 ff07 4884 4688 <CONFIG><ROLLOVERTYPE>2</ROLLOVERTYPE><FILESTORETAIN>10</FILESTORETAIN><FILESIZEMAX>10485760</FILESIZEMAX></CONFIG>
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Completed configuring the Logging subsystem [Phase II], bOK = 1.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Getting Operational Data [Phase II]...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Engine is determining its own NetBIOS node name...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Engine completed determining its own NetBIOS node name, Name = "NFR", Result = 0.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Engine is getting O.S. version information...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Engine completed getting O.S. version information, OS = "O.S. Name: Microsoft Windows, Architecture: x86_64, Platform ID: 2, Version: v6.3, Build: 0, SP: v0.0 [], Product Type: 3, Suite Mask: 0x80000110", Result = 0.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Engine is getting file version information for itself ["C:\Program Files\Novell\File Reporter\Engine\NFREngine.exe"]...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Engine completed getting file version information for itself, Version = "2.6.1.3", Result = 0.
01 2015-11-23 08:13:24 -28800 5 8003 4884 5072 GetServerDSCapabilityFlags() - The Primary Domain SID for the local system is empty. This system is not part of an AD domain.
01 2015-11-23 08:13:24 -28800 5 8003 4884 5072 GetServerDSCapabilityFlags() - The Novell XPLAT API Libraries are loaded.
01 2015-11-23 08:13:24 -28800 5 8003 4884 5072 GetServerDSCapabilityFlags() - The Novell XPLAT API Libraries are initialized.
01 2015-11-23 08:13:24 -28800 5 8003 4884 5072 GetServerDSCapabilityFlags() - The Novell XPLAT API Libraries are using the Windows version of XTIER.
01 2015-11-23 08:13:24 -28800 5 8003 4884 5072 GetServerDSCapabilityFlags() - This system has Novell eDir XPLAT capability.
82 2015-11-23 08:13:24 -28800 0 ff09 4884 4688 <CONFIG><LEVEL>5</LEVEL><CATEGORY/></CONFIG>
82 2015-11-23 08:13:24 -28800 0 ff0f 4884 4688 <CONFIG><LEVEL>5</LEVEL><CATEGORY/></CONFIG>
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Loading saved state information...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Completed loading state information, bOK = 1.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Validating the credentials set...
01 2015-11-23 08:13:24 -28800 3 0001 4884 5072 ML: Credentials "***Windows***" are not valid due to a missing account name, salt value or rights group.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Completed validating the credentials set, bOK = 1.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Configuring the Security Context Pool subsystem...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Completed configuring the Security Context Pool subsystem, bOK = 1, Result = 0.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Starting the Security Context Pool Service...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Completed starting the Security Context Pool Service, Result = 0, bOK = 1.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Waiting for the Security Context Pool to be filled...
01 2015-11-23 08:13:24 -28800 5 8003 4884 4776 CCSecurityContextPoolService - Worker thread has started.
01 2015-11-23 08:13:24 -28800 4 8003 4884 4776 CCSecurityContextPoolService - Detected either updated credentials or an empty security context pool. Attempting to authenticate credentials and fill the pool...
01 2015-11-23 08:13:24 -28800 5 8003 4884 4776 CCSecurityContextPoolService - Successfully authenticated all of the credentials and filled the security context pool with 1 entries.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Finished waiting for the Security Context Pool to be filled, bOK = 1.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Getting Operational Data [Phase III]...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Verifying the license file...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: The license's tree "KFCS" is an eDir tree, and it will be verified against this server's Primary eDir Tree "".
01 2015-11-23 08:13:24 -28800 3 0001 4884 5072 ML: Failed to verify the license file, License Status = 14.
01 2015-11-23 08:13:24 -28800 2 0001 4884 5072 ML: License Key Information: Product Name = "NovellFileReporterV26"; Organization Name = "Klamath Falls City Schools"; Tree Name = "KFCS"; Units = 100000; Expiration TS = 2115317939 [time_t UTC] / "2037:01:11:20:18:59" [UTC], Optional Value #1 (License Type) = 0; Optional Value #2 = "".
01 2015-11-23 08:13:24 -28800 1 0001 4884 5072 ML: Failed to initialize 1 or more components and/or subsystems. Engine is switching to stop-pending state.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Engine is shutting down...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Stopping the Security Context Pool Service...
01 2015-11-23 08:13:24 -28800 5 8003 4884 4776 CCSecurityContextPoolService - Subsystem shutdown detected. The worker thread will terminate cleanly.
01 2015-11-23 08:13:24 -28800 5 8003 4884 4776 CCSecurityContextPoolService - Thread has terminated.
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Saving state information...
01 2015-11-23 08:13:24 -28800 5 0001 4884 5072 ML: Completed saving state information, bOK = 1.
01 2015-11-23 08:13:24 -28800 2 0001 4884 5072 ML: Engine has shut down. Thread is terminating...
01 2015-11-23 08:13:24 -28800 0 8001 4884 4688 Shutting down the Logger. Closing log file "C:\ProgramData\Novell\File Reporter\Engine\log\nfrengine-20151120-151954.log".
81 2015-11-23 08:13:24 -28800 0 8001 4884 4688 <LOGFILECLOSE/>
